Kind of hard to see in the pics in a phone. It fits in the OEM reflector and lights up with tail lights. Brighter when braking. Try this link http://www.nsidiusindustries.com/pro...t-wire-harness Sent from my iPhone using Tapatalk |
OK, that makes more sense now: http://images.bigcartel.com/product_...&h=1000&w=1000
I wonder if just the dongle part would work for Valenti 4th TL. I want to ditch the stock one. Quote:
@Ashikabi and @humfrz I had my grandpa take a look at it (he's a mechanic) and he says its my clutch, i guess i notice it now too cuz if i don't rev match perfectly when i downshift i can feel the car lurch a split second after i release the pedal as if its slipping before it catches and spins the engine up, new clutch will be in shortly and if anyone wants i can do a quick write up of it (Excedy oem) and compare it to the stock clutch, i guess the previous owner couldn't drive stick very well, ill use this as a good time to change my trans and diff fluid, thanks for the help guys :bonk:
humfrz |
Unpack the Varis!
http://i.imgur.com/HiA4aCj.jpg?1 |
Today I wrapped my rear seat delete center channel. I am almost complete with my RSD! I still need to install some more velcro on the underside of the center channel and repaint and rivet the hinge. Then I have the seat back panel door to upholster. That one will be tricky because I want both sides to be upholstered as clean as possible.
Check out my build thread to see more... link in sig. http://i41.photobucket.com/albums/e2...0Complete.jpeg I will use this as a pull handle... http://i41.photobucket.com/albums/e2...ll%20Strap.jpg And these to secure the door... http://i41.photobucket.com/albums/e2...ini%20.875.jpg __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram @zeal.eightsix |
Actually occurred yesterday, but took my boss for a ride on our way to a facility inspection, and his first question about 14 seconds in was, "So, what made you want to get this car?" While I proceeded to explain in some detail, in my mind I was just immediately like:
Took a nap in my car and reserved the 860 in Halo when it comes in.
| All times are GMT -4. The time now is 12:44 PM. |
User Alert System provided by
