-   -   WHAT DID YOU DO TO YOUR FRS TODAY? (https://www.ft86club.com/forums/showthread.php?t=11036)
Mithosphere 03-20-2017 04:58 PM
I switched out my stock air filter with a K&N - about 15 seconds.
trvth 03-20-2017 05:12 PM
Originally Posted by Shinchu (Post 2875764)
holy wow!
I plan on doing those mods (maybe different header) and you did it all in one shot!
you have a build thread? if not, you need one! looking forward to seeing how the car does with all that. should be almost night and day!
Thanks! No build thread yet, but maybe I'll start one now that I'm planning to track the car this summer. This purchase was financed with this year's tax refund. Next year I'll go with wheels and tires.
Shinchu 03-20-2017 05:19 PM
lol I did the opposite?
I put on the perrin cold air 3 days after purchase (got a crazy deal from a member here)
PBM coilovers went on 2 months later.
1 year later I got my wheels (mounting tires this Saturday)
next is headers and tune, maybe beef up brakes.
who knows after that. maybe there will be an ITB kit out by then??? ITB and cams is my ultimate goal.
YES! you need a build thread!
nextcar 03-20-2017 07:07 PM
Plasti-dipped some center caps in preparation for changing out my wheels...
First time I have worked with plasti-dip and it seems very forgiving. Not sure I want to commit to the color, so I thought this would be a good way to test it out prior to powder coating...
Ashikabi 03-20-2017 07:33 PM
Originally Posted by arxm (Post 2875685)
guys I'm having a problem with my car and i don't wanna start a new thread just yet. A week ago i tried driving my car and it would not go into gear at all, i had to put an ungodly amount of force to get it into gear and even then it would only go into 3rd or 4th, r,1,2,5 and 6 were not useable, the car shifted fine when the engine was not running, to me this screamed throwout bearing however, and heres what i don't get, i managed to get it into 1st and just didn't stop at all for a while and when everything warmed up it shifted perfectly, I don't know what to do and I haven't driven the car since that night. I thought maybe water froze on the shifter bushing but that wouldn't explain why it shifted with the car off. I haven't had any anomalies with the car before it started doing that, no missed shifts, no grinding, no stalling, it just started doing this all of a sudden, any help would be appreciated and my warranty is not valid if it helps
Make a thread in tech section. Check clutch fluid. Could try replacing transmission fluid
Fyi cams don't do squat on the 86 because there is so little room for the valves to open farther unless you replace your pistons too. Flex fuel is your best bet if it's available in your area
humfrz 03-20-2017 07:39 PM
hmmmm.........sounds to me like the clutch disk is not being released.
The first thing that I would recommend is that you check the fluid level in the clutch fluid reservoir, if it's low, fill it up (then find out where the fluid went).
If it's full, I'd suggest you bleed the hydrolytic clutch system to purge the system of any air.
If all that doesn't help, I'd adjust the clutch ..... (have you been messen with the adjustment .. ??)
Come back.
humfrz
humfrz 03-20-2017 08:12 PM
15 seconds .... huh?
Did you oil it ..?
Too much oil will gum up the MAF .. :confused0068:
Are you sure you got it in with the correct end up and situated so as the direction of air flow is proper .. ??
Are you sure you got the bottom of the case positioned correctly before snapping the top closed .. ??
Are you sure it's all the way closed .. ??
Did you put the sticker on .. ??
15 seconds, huh ........ :)
Are you going out to check it ......;)
(jest ah messen wich ya)
humfrz
Kestrel 03-20-2017 09:45 PM
https://uploads.tapatalk-cdn.com/201...596bae67e7.jpg
Deleted the 3rd brake light and child seat anchors then covered the shelf in fresh felt. 🏎
Sent from my SAMSUNG-SM-G900A using Tapatalk
Ashikabi 03-20-2017 09:52 PM
Deleted or relocated? They are legally required but location can change so long as it's above your other brake lights
Crashdummy 03-21-2017 12:10 AM
While waiting on the bumper cover and front lip to be painted from the racoon damage, :mad0260:had some time this weekend to install the some parts!!
Mishmoto Oil Cooler
Greddy Air Intake Snorkel
Replaced the damaged Hella Horns
Replaced Condenser bug screen
Mishmoto Oil Cooler
The oil cooler was pretty easy install, fun part was getting the lines in a position they were happy about. Not easy bending braided lines, a lil heat from a heat gun helps.
Chose the thermostat sandwich plate at 185/F
http://www.exoticautorestylers.com/i...318_172402.jpg
http://www.exoticautorestylers.com/i...318_235229.jpg
http://www.exoticautorestylers.com/i...318_235239.jpg
http://www.exoticautorestylers.com/i...318_235505.jpg
http://www.exoticautorestylers.com/i...318_235248.jpg
http://www.exoticautorestylers.com/i...318_235352.jpg
http://www.exoticautorestylers.com/i...318_235434.jpg
I
cut about an inch off the snorkel so it doesn't hang down so low, to block the oil cooler. left it just low enough to be in position to catch the air flow.
http://www.exoticautorestylers.com/i...318_233453.jpg
Took some 3/4 in velcro strip and used it as a gasket. The stuff the came with the snorkel was a joke :thumbdown:
Fits nice and tight for no leaks. Also channeled out the styrofoam bumper cover support for the snorkel
http://www.exoticautorestylers.com/i...318_235211.jpg
New Condenser screen
http://www.exoticautorestylers.com/i...319_122058.jpg
Wating for its clothes
http://www.exoticautorestylers.com/i...319_124816.jpg
damn racoons
humfrz 03-21-2017 12:44 AM
Originally Posted by Crashdummy (Post 2876244)
[SIZE=3]While waiting on the bumper cover and front lip to be painted from the racoon damage,
damn racoons
Nice stuff.......:thumbsup:
I suggest the next time you go raccoon hunting, use a good coon dog and a shotgun ....don't use your car to run over them ......:D
humfrz
notout86 03-21-2017 01:39 AM
Deleted the 3rd brake light and child seat anchors then covered the shelf in fresh felt. ��
You may find the felt fades with time. Spray with SATIN black paint (which looks blacker than matte) to reduce reflection in the glass above.
I got the lights module out of the "spaceship", covered it in felt and just pushed it into the crack at the base of the glass. Very stealth. Next time I would try
one of those flexible tape-strips of LEDs backed with a black strip of black felt for even more "stealthlinessity".
guybo 03-21-2017 01:48 PM
Radium Engineering adjustable front strut tower bar
Itsthebeast 03-21-2017 03:45 PM
Took a 200 mile joy ride theough the mountains around Massachusetts, New Hampshire, and Vermont. :-D Startin to warm up, hopefully the snow's all done!https://uploads.tapatalk-cdn.com/201...7afb98a35a.jpg
Sent from my SM-N920P using Tapatalk
