-   -   WHAT DID YOU DO TO YOUR FRS TODAY? (https://www.ft86club.com/forums/showthread.php?t=11036)
Teseo 01-20-2017 11:10 AM
Originally Posted by nextcar (Post 2835704)
If you enable the gear display the ECU will compute what gear you are in via a lookup table matching engine rpm with wheel speed. When you change the differential gear ratio the lookup table is wrong...
When I am in gears 4-6 the indicated gear is off by one
4th shows as 3rd
5th shows as 4th
6th shows as 5th
Thats dangerous
Ashikabi 01-20-2017 11:11 AM
Originally Posted by Teseo (Post 2835709)
Thats dangerous
I don't use the indicator so I guess if it's a problem, just turn it off
Overdrive 01-20-2017 11:54 AM
Thats dangerous
Only for someone not familiar with the car who also relies on the display more than the physical orientation of the shifter...which is a personal problem at that point.
nextcar 01-20-2017 12:06 PM
That was my solution! I may look into editing the lookup table some day - just because it would be fun.
No danger whatsoever as far as I am concerned. Purely cosmetic, and I have never had a manual before that showed gear on the dash - so I am perfectly happy turning the display off. Speedometer and tachometer are correct - they are what matter!!!
:burnrubber:
D_Thissen 01-20-2017 04:07 PM
After a week of positive temperatures and a lot of rain, and being in storage for a few months, I had to take it out for drive. Felt great to be behind the wheel again. https://uploads.tapatalk-cdn.com/201...056feee643.jpghttps://uploads.tapatalk-cdn.com/201...428b6db6ee.jpghttps://uploads.tapatalk-cdn.com/201...bbe9a51024.jpg
Sent from my Nexus 6P using Tapatalk
Overdrive 01-20-2017 04:17 PM
Very nice. I'm stealing for wallpaper slideshows and screensavers
canyons 01-20-2017 07:15 PM
Permanent pinch weld adapters
http://i.imgur.com/1iRj12i.jpg
Sourced from amazon and epoxied in place. Good contact on inside upper surface. Filled interior of adapter with construction adhesive. They won't fall off!
Outside upper gaps filled with JB Weld steel stick to prevent twisting. Touched up with black paint. One of my pinch welds was mostly collapsed (lazy shop.)
weederr33 01-20-2017 08:59 PM
OEM oil cooler installed today after having everything sitting around for a month. :D
http://i.imgur.com/LMlwcek.jpg
Overdrive 01-20-2017 11:18 PM
Mmmmmm...Cosworth.
Quentin 01-21-2017 07:46 PM
New car seat for my daughter.
https://uploads.tapatalk-cdn.com/201...811fe2e9ba.jpg
Teseo 01-21-2017 08:07 PM
Bottle holder?
Overdrive 01-21-2017 10:07 PM
Looks like it. Just like dad has in his door. :party0030::w00t::thumbup::cheers:
Quentin 01-21-2017 11:27 PM
Originally Posted by Teseo (Post 2836635)
Bottle holder?
Water bottle, maybe. At nearly 5, she is a little old for a bottle. ;)
dejahboi 01-22-2017 01:27 PM
I did this :D
https://uploads.tapatalk-cdn.com/201...20673a36ff.jpg
Sent from my SAMSUNG-SM-G935A using Tapatalk
