That's cool, might have to do this one
Does it work off 6Volt too? That would mean convenience of integration with the Toyota86 head unit. Does it have a wire to cut to remove the guidelines?
Not sure about the 6 volt issue, I have installed a couple of reverse cameras in to a few different vehicles (including my FRS) and have not had any issues with power off the main head units. There is no guide lines to speak of since this particular camera is designed for the BRZ head unit and that has guide line built in to it. I am not clear from the pics but it looks as if the video cable does not go inside the light. I could be muddled about this as I have forgotten the exact setup within, but if it does then it may not be necessary to go through the grommet?[/QUOTE] There is a "notched" slot in the upper portion of the lens, just below and behind the camera itself. That is where you route the cable through. The cable does not go in to the light housing itself but in to the slot provided. |
OK just bought the camera/lens combo (http://www.ebay.com/itm/Car-RearView...item5d46de615f)
I will get pictures of the install and let everyone know what I think of it. The Camera I have in there now got damaged when someone closed the deck lid down on to something. Anyway I will do a quick DIY of this camera once I get it and install it. |
Reason for this was a cleaner install by not having to many wires running through the vehicle, not wanting to deal with more then one cable (lazy), the 6volt issue and having to wire in a relay. Besides when the reverse lights come on the camera comes on and that is fine by me. |
Have you integrated yours into the Fujitsu-Ten satnav headunit? Does it work reliably? I am proud of my DIY effort as suggested by another forum member (thanks GreenCounty). It has an advantage as it uses a single switch which allows full time front or rear view at any time. Also, neither camera is powered if not giving a picture. But as it sometimes fails to work correctly I would consider getting this system. |
I am still waiting for an auto bumper raiser system. I would trade that for heated seats or the sound tube feature any day! |
It would be marvelous you put the full tutorial front and rear camera installation :)
This link lacks info on fitting the rear cam but there are many other posts on how to do that. One tip is to send the wiring down the center of the car rather than the side. I am pretty sure I posted other rear-cam tips ... search under Advanced with User Name notout86 |
very interesting thread the cable through the center of the car ..... do you have pictures of this?
I found this connector to two chambers .... It would be possible to use it? http://www.aliexpress.com/item/front...675896600.html |
Sorry ..... no pictures. Take a rear seat out.(Undo the bolt, press down hard near the rear of where you sit to free a hook, and lift up the front edge while still pressing Just run the wiring under near the center then to the front dash and tuck the wiring up under the edge of the center console.
ist not necessary do all this disassembly?
http://www.ft86club.com/forums/showp...48&postcount=3 http://www.ft86club.com/forums/showp...87&postcount=4 cable slides well without difficulty to the front without removing anything else? You pull the cable through the side where the leg rests driver? |
No dissassembly necessary. Just push the wiring up under the lower console edge with your finger and it is jammed into the carpet and stays there. I have run wiring down the door sides as well the first time but would never again.
The cable passes through the side of the shifter? or the lateral plastic upholstery
and .... as you do to bring the cable to touch screnn area? It would be possible for you to paint the cable run over a photo of the car? Thank you very much for your instructions;) |
| All times are GMT -4. The time now is 04:25 AM. |
User Alert System provided by
