follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 17
1
2
3
4
5
11
Last
Showing results 1 to 30 of 491
Search took
0.89
seconds.
Search:
Posts Made By:
justinco
Forum:
Member's Car Journals
03-26-2024, 04:34 PM
264
Honda K24 Swapped 2015 BRZ Ship of Thesus (NASA TT5)
35,335
Posted By
justinco
I have a set in the garage as well. I'll probably...
I have a set in the garage as well. I'll probably mount them up soon since I now have one nearly bald RE71RS.
Sent from my SM-S926U1 using Tapatalk
Forum:
03-26-2024, 12:57 PM
32
BTR Justin - 2022 GR86 journey
5,444
Posted By
justinco
Maybe next time, I did 20psi pre-charge and this...
Maybe next time, I did 20psi pre-charge and this was the result. Bright purple line with accumulator, dim line without:
Forum:
03-26-2024, 12:09 AM
32
5,444
Posted By
justinco
Latest lap around Chuckwalla CCW with 86 Cup this...
Latest lap around Chuckwalla CCW with 86 Cup this past weekend.
New PB and inching closer to the sub-2 point, with a 2:00.683 lap.
Also ran the Moroso accumulator at 20psi pre-charge and it...
Forum:
03-05-2024, 07:14 PM
32
5,444
Posted By
justinco
Latest lap from around Chuckwalla CCW, little...
Latest lap from around Chuckwalla CCW, little late as it was end of January. No PB's as I think the RE71RS's are about done. This was a lap with the accumulator as well.
Forum:
02-19-2024, 09:22 PM
32
5,444
Posted By
justinco
Moroso says 6psi. I had about 8-10psi precharge....
Moroso says 6psi. I had about 8-10psi precharge. I will also be testing a higher pre-charge next month when back at Chuck.
Forum:
02-19-2024, 02:38 PM
32
5,444
Posted By
justinco
Forgot to post this, but here is the first round...
Forgot to post this, but here is the first round of testing with the Moroso oil accumulator:
https://youtu.be/treM6_JBEKA
Forum:
Brakes, Suspension, Chassis
02-19-2024, 02:37 PM
3
CSG brake pads, C21 front and C11 rear
777
Posted By
justinco
Great pads, great price!
Forum:
Tracking / Autocross / HPDE / Drifting
02-13-2024, 05:22 PM
8
75W140 Motul Gear Oil
747
Posted By
justinco
No, not really. Sent from my SM-S926U1...
No, not really.
Forum:
01-31-2024, 10:49 PM
32
5,444
Posted By
justinco
The before/after data with the Eibach springs is...
The before/after data with the Eibach springs is that they don't make you go any faster on the track, if that's what you meant. They are slightly stiffer spring rate but it's barely noticeable.
Forum:
01-24-2024, 09:22 PM
32
5,444
Posted By
justinco
I may test it without the pressure switch as...
I may test it without the pressure switch as well. I think I can just swap the hot wire from the switch directly to the solenoid valve.
Forum:
01-21-2024, 09:09 PM
32
5,444
Posted By
justinco
Moroso accumulator installed along with a Canton...
Moroso accumulator installed along with a Canton 35-40psi pressure switch on an electric valve.
Back to Chuckwalla this weekend to test and see how it goes.
Forum:
BRZ Second-Gen (2022+) -- General Topics
01-06-2024, 01:15 PM
2
Lowering springs for 2nd gen?
1,142
Posted By
justinco
I don't *think* the new cars are lower. Here are...
I don't *think* the new cars are lower. Here are a couple pics of mine with stock springs and Eibach lowering...
Forum:
12-30-2023, 01:15 AM
32
5,444
Posted By
justinco
No, not really. I may go back to the Cusco strut...
No, not really. I may go back to the Cusco strut bar with integrated master cylinder brace. Easier to fit/route things like the oil pressure sensor and oil accumulator. Plus, I'm getting it powder...
Forum:
12-13-2023, 11:03 PM
32
5,444
Posted By
justinco
New PB (CW) at the SoCal 86 Cup Chuckwalla rounds...
New PB (CW) at the SoCal 86 Cup Chuckwalla rounds a couple weeks ago. CCW day was 2nd place in Unlimited class (went slower than previous visit though) and CW day was 1st place (new PB by few...
Forum:
11-14-2023, 09:51 PM
698
Sticky:
Track Videos - Directory and Discussion
204,954
Posted By
justinco
I always forget to share videos here...anyways,...
I always forget to share videos here...anyways, here is a catch up of the last 3 track days. Chuckwalla 2x with sub 2 times in sight and a relatively new track in Spring Mountain Charleston Peak.
Forum:
11-09-2023, 10:45 PM
32
5,444
Posted By
justinco
Changed up the engine bay a little bit with some...
Changed up the engine bay a little bit with some Perrin parts and did another 2 day track weekend with PCA at Spring Mountain Charleston Peak full track.
First time at Charleston Peak and it was...
Forum:
09-27-2023, 02:44 PM
32
5,444
Posted By
justinco
Did some more oil pressure testing while back at...
Did some more oil pressure testing while back at Chuckwalla this past weekend. That video is below, along with some hot laps on the fast tires. Despite the sad baffle results, this car rips, sub 2 is...
Forum:
Engine, Exhaust, Transmission
09-26-2023, 12:06 AM
7
Differential breather, stuck after track day?
1,024
Posted By
justinco
The exhaust pipe is a 4-5" away from the side of...
The exhaust pipe is a 4-5" away from the side of the diff housing (Borla). I may wrap it as well, per DocWalt suggestion. I had over 12k miles plus all the track/autox on that original fluid, so...
Forum:
09-19-2023, 09:16 PM
32
5,444
Posted By
justinco
Glad they are helpful, that's my goal, thanks!
Forum:
09-18-2023, 06:54 PM
32
5,444
Posted By
justinco
Kazama baffle installed this past weekend....
Kazama baffle installed this past weekend. Testing this Saturday/Sunday!
https://youtu.be/M9Mx4EmLHLA
Forum:
09-10-2023, 04:01 PM
32
5,444
Posted By
justinco
Also, here is the oil pressure testing video from...
Also, here is the oil pressure testing video from the same Chuckwalla track day. Going back in 2 weeks with the Kazama baffle installed!
https://youtu.be/epuQNOGVkR0
Forum:
09-09-2023, 04:51 PM
32
5,444
Posted By
justinco
First event at Chuckwalla post summer break....
First event at Chuckwalla post summer break. Track was super dusty and slick, add GT Radials to that and it was a slow drift fest most of the morning. This was one of the few tame laps I got in...
Forum:
08-24-2023, 12:47 AM
32
5,444
Posted By
justinco
Chuckwalla track day on 9/2, running both CW and...
Chuckwalla track day on 9/2, running both CW and CCW so it will be good opportunity to test oil pressures on the track (pre-baffle). Several tests planned for baseline oil pressure testing on 2...
Forum:
08-16-2023, 09:06 PM
32
5,444
Posted By
justinco
Acquired the Kazama oil pan baffle today. Hoping...
Acquired the Kazama oil pan baffle today. Hoping to get my baseline testing done in early September, then get the baffle installed for follow up testing.
Forum:
08-16-2023, 01:02 PM
264
35,335
Posted By
justinco
Well what I meant was, in AZ we race in the...
Well what I meant was, in AZ we race in the winter, typically 60's and 70's temps. With early/late season being hot af.
Colorado races in the summer, 80's and 90's typically, but colder during the...
Forum:
08-06-2023, 06:39 PM
32
5,444
Posted By
justinco
Picked up a couple parts so I can remote mount my...
Picked up a couple parts so I can remote mount my oil pressure sensor off the block. Won't be able to get to it for a couple weeks as I'll be out of town racing my BMW this next weekend.
Oil...
Forum:
08-04-2023, 12:49 PM
264
35,335
Posted By
justinco
They are great dry tires too, just not as fast as...
They are great dry tires too, just not as fast as some others is all. They just happen to be really good in the wet, where the faster dry tires are not.
Forum:
08-02-2023, 01:13 AM
32
5,444
Posted By
justinco
If anyone knows how to make the forum not...
If anyone knows how to make the forum not automatically change my YouTube links into video embeds, lmk (rather have links that are clickable).
The past couple...
Forum:
08-02-2023, 12:56 AM
32
5,444
Posted By
justinco
Well, I haven't done a build thread in about 15 years (https://honda-tech.com/forums/showthread.php?t=2238922), but suddenly got the motivation to do one for my GR86.
Not sure where to start,...
Forum:
08-01-2023, 10:11 PM
264
35,335
Posted By
justinco
Nice, glad to hear you're making the trip too! ...
I got a hotel in Las Vegas, NM on the way back, Sunday night. I'll let you sleep in the bathtub, lmk.
Page 1 of 17
1
2
3
4
5
11
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
11:22 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
