follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 15
1
2
3
4
5
11
Last
Showing results 1 to 30 of 430
Search took
1.85
seconds.
Search:
Posts Made By:
Ohio Enthusiast
Forum:
Scion FR-S / Toyota 86 GT86 General Forum
04-15-2024, 12:15 PM
24,605
WHAT DID YOU DO TO YOUR FRS TODAY?
7,226,477
Posted By
Ohio Enthusiast
Don't forget that the bolts holding the aluminum...
Don't forget that the bolts holding the aluminum skid plate that have a 12 mm head are the right size to thread into the rotors to push them off the hub.
Forum:
04-11-2024, 10:10 AM
24,605
7,226,477
Posted By
Ohio Enthusiast
To be frank it's only torqued to 39 ft-lb. ...
There are rounded nut extractors that you should still be able to use - they look like a regular socket with a left-handed twist in them. Some penetrating...
Forum:
Engine, Exhaust, Transmission
04-07-2024, 09:06 AM
6
Replacing bypass coolant hose without flushing coolant?
330
Posted By
Ohio Enthusiast
Replaced the coolant hose yesterday. Raised the...
Replaced the coolant hose yesterday. Raised the driver's side with a jack from the front pinch weld, and put jack stands around the car for safety.
I had the idea to use rubber stoppers to plug...
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
04-05-2024, 10:55 AM
260
MCA Suspension "Traction Mod"
85,152
Posted By
Ohio Enthusiast
Ah, now I see what you mean. Yeah, I don't see a...
Ah, now I see what you mean. Yeah, I don't see a need to loosen them. This installation video shows the two small bolts loosened, but when they actually install the MCA mod it doesn't seem to matter....
Forum:
04-05-2024, 08:01 AM
260
85,152
Posted By
Ohio Enthusiast
Not sure how he determined they're stretch bolts....
Not sure how he determined they're stretch bolts. The repair manual marks them as non-reusable, yes, but so are the bolts holding the subframe to the car and the nuts holding those trailing arm bolts...
Forum:
04-04-2024, 01:12 PM
260
85,152
Posted By
Ohio Enthusiast
I installed the GP Sports one a few days ago, but...
I installed the GP Sports one a few days ago, but with the rainy weather I don't have too much to report.
Ride quality does seem to be more compliant in the rear, especially on sharp bumps (like...
Forum:
04-01-2024, 08:51 AM
6
330
Posted By
Ohio Enthusiast
Quick update - the patch leaked a drop every few...
Quick update - the patch leaked a drop every few seconds with the engine running. I only drove a couple of miles, and didn't have long drives planned until the replacement hose arrived, but I still...
Forum:
Wheels | Tires | Spacers | Hub --
Sponsored by The Tire Rack
03-31-2024, 08:16 AM
11
DD/Canyon Tire Recommendations?
736
Posted By
Ohio Enthusiast
I don't think it's an unpopular opinion. They're...
I don't think it's an unpopular opinion. They're often recommended for track work on a low budget, together with the SX2.
But OP already has RS4's, which fill the same niche as the RT615K+ of long...
Forum:
03-30-2024, 10:14 AM
6
330
Posted By
Ohio Enthusiast
Yeah, I'm not too concerned about reusing the...
Yeah, I'm not too concerned about reusing the coolant. Just don't want to go through the hassle of full drain and refill... I'll report back after I've replaced the hose.
Forum:
03-30-2024, 08:25 AM
4
Whiteline KCA434 can reduce anti-dive?
463
Posted By
Ohio Enthusiast
Whiteline did not respond, but I think it would...
Whiteline did not respond, but I think it would be a bad idea. When installed on the car and in full droop the two outside bushings are the ones allowing the control arm to pivot. Without them I'm...
Forum:
03-24-2024, 11:38 AM
9
Help needed for budget fast road/track suspension build
627
Posted By
Ohio Enthusiast
Yep, looking at the pictures in the MCA site I...
Yep, looking at the pictures in the MCA site I tend to agree that it's quite a bit less than the GP Sport's 60mm. Your ~45mm feels about right.
Edit: actually, I measured my GP Sport mod (waiting...
Forum:
03-24-2024, 11:31 AM
24,605
7,226,477
Posted By
Ohio Enthusiast
It's called E-Torx (for External) or external...
It's called E-Torx (for External) or external star. Interestingly enough I bought a set of E-Torx sockets thinking I'd need to take out the seats for some modifications, only to discover that they...
Forum:
03-24-2024, 09:32 AM
9
627
Posted By
Ohio Enthusiast
Not sure if MCA published their offset, but the...
Not sure if MCA published their offset, but the GPSports version (https://www.rhdjapan.com/gp-sports-racing-equipment-design-rear-rigid-traction-member-collar-set-brz-zc6-86-zn6.html) of this lists a...
Forum:
03-12-2024, 01:40 PM
7
Front bumper material?
4,579
Posted By
Ohio Enthusiast
On the other hand, PP lends itself very well to...
On the other hand, PP lends itself very well to plastic welding. I've repaired several household items with a cheap soldering iron and some doner PP (from plastic jar lids). Using a purpose made...
Forum:
Tracking / Autocross / HPDE / Drifting
03-11-2024, 08:30 PM
3
Steering Lock Removal
4,438
Posted By
Ohio Enthusiast
Many old guide posts lose their pics over time,...
Many old guide posts lose their pics over time, typically from hosting them on sites that no longer have them (or the sites are dead entirely). This post stored it's picture files on gspeed.com...
Forum:
03-04-2024, 11:22 AM
260
85,152
Posted By
Ohio Enthusiast
Well, my impatience got to me, I ordered the GP...
Well, my impatience got to me, I ordered the GP Sports mod from RHDJapan (https://www.rhdjapan.com/gp-sports-racing-equipment-design-rear-rigid-traction-member-collar-set-brz-zc6-86-zn6.html). I...
Forum:
03-02-2024, 08:34 PM
260
85,152
Posted By
Ohio Enthusiast
I noticed that MCA has this notice on their...
I noticed that MCA has this notice on their traction mod page (https://mcasuspension.com/gt86-and-brz-traction-mod/):
I sent them a request for more details, hopefully they can provide some.
Forum:
GR86 General Topics (2nd Gen 2022+ Toyota 86)
03-01-2024, 08:48 PM
26
Early announcement for the 86BUTTDROP lowering brackets for OEM seats
5,586
Posted By
Ohio Enthusiast
I not an engineer, but isn't the seat strength...
I not an engineer, but isn't the seat strength moot in frontal and side collisions? Sure, you wouldn't want it detaching and getting tossed around the cabin, but the actual occupant load is being...
Forum:
02-19-2024, 01:02 PM
117
Oil weight for track only car with a lot of cooling?
11,037
Posted By
Ohio Enthusiast
Higher number is thicker, so 50 is thicker than...
Higher number is thicker, so 50 is thicker than 40, not the other way around.
A 5W30 will behave like 5 in cold temps (W rating is at 0 degrees Fahrenheit) and like 30 in working temps.
Forum:
Electronics | Audio | NAV | Infotainment
02-16-2024, 08:00 AM
2
Driver side Window Switch Panel Wont Turn Off
292
Posted By
Ohio Enthusiast
If you put back the stock panel does it show the...
If you put back the stock panel does it show the same behavior? If so, I suspect a pinched wire in the wiring harness shorting out something. If not, the problem is with the aftermarket...
Forum:
BRZ Second-Gen (2022+) -- General Topics
02-09-2024, 06:20 PM
1,504
What did you do to your 2nd gen BRZ today?
274,189
Posted By
Ohio Enthusiast
AFAIK the gen 2 OEM oil cooler is actually an oil...
AFAIK the gen 2 OEM oil cooler is actually an oil warmer meant to eke out a little better emissions by warming the oil faster on cold start. The fact that it also acts as a cooler is an added benefit.
Forum:
01-05-2024, 08:00 AM
44
Tires for track/HPDE - anything better than RS4?
7,879
Posted By
Ohio Enthusiast
Yep, they look great stored on the shelf in the...
Yep, they look great stored on the shelf in the basement :lol:
Seriously, the quoted impressions were from the last track day of the season. Next time would be in 3-4 months.
Forum:
12-30-2023, 11:24 AM
20
Steering!
3,231
Posted By
Ohio Enthusiast
The Twins' steering was always lauded as one of...
The Twins' steering was always lauded as one of the best EPS units from any manufacturer, so this is not a new sentiment from Car and Driver. Still, nice to hear this repeated in such lofty company...
Forum:
11-16-2023, 10:59 AM
11
-3 degrees camber in the front on stock suspension
1,362
Posted By
Ohio Enthusiast
Yes, that's the route most people take. I...
I started from camber bolts in the top hole and then added bottom hole camber bolts. Cammed camber bolts like SPC make it easier to adjust and/or maximize...
Forum:
11-16-2023, 08:09 AM
11
1,362
Posted By
Ohio Enthusiast
I agree in theory, but in practice there is. I...
I agree in theory, but in practice there is. I don't have the exact numbers, but the 20mm drop from the Yellows was quite significant for camber, I think around 0.5-0.6.
No, you'd need camber...
Forum:
11-15-2023, 09:26 PM
11
1,362
Posted By
Ohio Enthusiast
I don't think you can get -3 without lowering. I...
I don't think you can get -3 without lowering. I have Pedders and both top and bottom camber bolts together with RCE Yellows and I could get around -3.2 but I dialed it back to -3. Without the...
Forum:
11-13-2023, 08:09 AM
6
Looks like oil starvation issue in the right handers solved
5,631
Posted By
Ohio Enthusiast
Comment says 1 liter overfill. 900BRZ tried...
Comment says 1 liter overfill. 900BRZ tried overfill (IIRC 1 quart, which is almost the same) and that didn't help much.
Before declaring the problem solved I would say we'd want to see a before...
Forum:
Other Vehicles & General Automotive Discussions
11-10-2023, 09:51 AM
790
The All-New GR Corolla World Premiere April 1, 2022
68,113
Posted By
Ohio Enthusiast
savagegeese released an in-depth ownership review...
savagegeese released an in-depth ownership review of their GRC. They touched on track-readiness and modifications which I found very interesting. It seems to me that the Corolla roots heavily affect...
Forum:
11-05-2023, 05:10 PM
55
New EV Caterham
5,167
Posted By
Ohio Enthusiast
Wake us up when someone actually drives the thing...
Wake us up when someone actually drives the thing or they start selling them. Bonus points for US registered cars (which I doubt would ever happen, but one can hope). My money is still on Mazda for a...
Forum:
BRZ First-Gen (2012+) -- General Topics
10-26-2023, 12:34 PM
2
Child seat
576
Posted By
Ohio Enthusiast
My youngest used a Britax Boulevard ClickTight...
My youngest used a Britax Boulevard ClickTight front facing behind the passenger seat from 2 years old to 5 and a half years old. For most of that time he sat cross-legged and the passenger seat was...
Page 1 of 15
1
2
3
4
5
11
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
DIY (Do-It-Yourself) Guides
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
07:27 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
