follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Showing results 1 to 21 of 21
Search took
0.52
seconds.
Search:
Posts Made By:
Poogchomp
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
07-11-2022, 10:06 PM
6
Flex Z wont adjust...
1,158
Posted By
Poogchomp
Disconnect the lower mount from your LCA and to...
Disconnect the lower mount from your LCA and to turn it like that. If the lower mount doesn't move then as stated above, the threads on the shock body are stripped.
Forum:
07-04-2022, 06:10 PM
4
Tarmac 2 or SuperStreet 1.
1,050
Posted By
Poogchomp
I went T2s since my intent for this car was to be...
I went T2s since my intent for this car was to be a streetable track car. I'm running them with vorshlag mounts on front and rear and they're perfectly fine on the street to me. I went from PP...
Forum:
05-13-2022, 10:57 PM
9
Coilover recommendations
1,141
Posted By
Poogchomp
Didn't mean to sound like an ass. The last...
Didn't mean to sound like an ass. The last person who asked for similar advice ended up ignoring everyone and buying BC coils anyways. Most of the time when I see someone ask about a specific thing...
Forum:
05-13-2022, 02:19 PM
9
1,141
Posted By
Poogchomp
My recommendations are csg spec teins, rs-r club...
My recommendations are csg spec teins, rs-r club sports, or rce tarmac 2s. But like the last guy who made a similar post, you're probably going to ignore everyone and buy bc coils anyways.
Forum:
04-02-2022, 03:29 PM
26
Buying coilovers soon and have a few questions
2,965
Posted By
Poogchomp
Didn't realize you didn't make a decision on how...
Didn't realize you didn't make a decision on how low to lower your car. I usually don't tell people what to do if it seems like they know what they already want.
That being said, our cars do...
Forum:
04-01-2022, 12:02 AM
26
2,965
Posted By
Poogchomp
for question 2, you won't rub on the struts at...
for question 2, you won't rub on the struts at all with your wheels. I run 17x9 +35 with 245/40/R17 on mine and they don't rub at all.
3.) It depends on how low you go past stock. lowering the...
Forum:
03-31-2022, 12:03 AM
21
Commuter coils
2,533
Posted By
Poogchomp
You may or may not need rear lower control arms...
You may or may not need rear lower control arms depending on where you camber lands after lowering. More than likely it'll land in an acceptable spot tbh. If it's super off, or you want ocd...
Forum:
Wheels | Tires | Spacers | Hub --
Sponsored by The Tire Rack
03-29-2022, 11:20 AM
4
Subaru lug nut and lock set
831
Posted By
Poogchomp
Subaru thread pitches in that model year range is...
Subaru thread pitches in that model year range is still 12x1.25 so they'll work. At that price I'd just buy some muteki lug nuts instead though.
Edit: Muteki lug nuts cost significantly less than...
Forum:
Forced Induction
03-03-2022, 10:33 PM
36
450 Whp possible with 12.5:1 compression
4,011
Posted By
Poogchomp
You could get an IAG short block instead of...
You could get an IAG short block instead of building it. They also machine it to help the oiling issues.
Forum:
BRZ First-Gen (2012+) -- General Topics
01-29-2022, 11:44 PM
33
I'd like to hear your two cents
4,819
Posted By
Poogchomp
If by proper precautions you mean not shifting...
If by proper precautions you mean not shifting like an a hole then yeah you could extend the life of it. You're already over the torque rating for our transmissions so it's more or less a ticking...
Forum:
01-29-2022, 11:01 PM
33
4,819
Posted By
Poogchomp
If you don't mind hammering your transmission...
If you don't mind hammering your transmission tunnel, you may as well just do the CD009 swap for the transmission. Do that and you wouldn't have to worry about it blowing up.
Forum:
Scion FR-S / Toyota 86 GT86 General Forum
01-12-2022, 12:08 PM
59
FRS MT or AT?
5,343
Posted By
Poogchomp
My foot clipped the brake pedal the first time I...
My foot clipped the brake pedal the first time I stopped in an auto after driving a manual for so long. That's when I found out that the seatbelts worked.
Forum:
01-06-2022, 10:22 PM
40
Suspension advice before I spend my money
4,597
Posted By
Poogchomp
RCE Yellows advertise a 20mm drop, so about .8...
RCE Yellows advertise a 20mm drop, so about .8 inches.
Forum:
FR-S / BRZ vs....
12-06-2021, 11:51 AM
3
BRZ/GT86 vs 350Z/370Z
3,070
Posted By
Poogchomp
Get the nissan and fix the suspension issues with...
Get the nissan and fix the suspension issues with a welded diff (cus drift car). You'd be able to get the power numbers you want out of the Z a lot easier and wouldn't have to worry about the...
Forum:
BRZ Second-Gen (2022+) -- General Topics
12-04-2021, 10:45 PM
18
Gen 2 vs. Supercharged Gen 1
3,944
Posted By
Poogchomp
If/when the ecu gets cracked it can be tuned to...
If/when the ecu gets cracked it can be tuned to ignore the cat ready check so it won't throw the CEL. Depending on what your state requires for emissions testing then yes you would be able to pass...
Forum:
11-28-2021, 11:23 AM
15
Would these wheels and tire setup be too stressful on stock suspension?
2,341
Posted By
Poogchomp
It'll be off by about 1/5 of an inch compared to...
It'll be off by about 1/5 of an inch compared to the car you're using as an example. If you consider that close, then yes it'll be close to perfect.
Forum:
11-27-2021, 01:42 PM
15
2,341
Posted By
Poogchomp
+38 offset pushes the wheel out more by 7mm over...
+38 offset pushes the wheel out more by 7mm over a +45. Spacers would just push it out even further.
Forum:
GR86 General Topics (2nd Gen 2022+ Toyota 86)
11-27-2021, 09:28 AM
43
Poll:
Bmw 230i(G42) vs BRZ/GR86
8,470
Posted By
Poogchomp
They also look like pigs too.
Forum:
11-25-2021, 08:34 PM
43
Poll:
8,470
Posted By
Poogchomp
Not sure about Turkey, but in the US BMW cars...
Not sure about Turkey, but in the US BMW cars don't hold value until they become collector cars. Only ones I know of that have gone up in price after bottoming out are the e30s and e36. If you were...
Forum:
11-25-2021, 09:29 AM
43
Poll:
8,470
Posted By
Poogchomp
Get the twin if you want a manual or a more...
Get the twin if you want a manual or a more sporty leaning car. Get the BMW if you want more of a GT car.
Forum:
Engine, Exhaust, Transmission
09-07-2021, 11:54 PM
29
Gen2 Transmission swap?
6,129
Posted By
Poogchomp
The AISIN gear boxes use removal bell housings so...
The AISIN gear boxes use removal bell housings so even if they were for some reason different (would be very unsubaru like if they were) it wouldn't matter too much. As for electronics, if they were...
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
02:58 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
