follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 17
1
2
3
4
5
11
Last
Showing results 1 to 30 of 500
Search took
1.73
seconds.
Search:
Posts Made By:
BirdTRD
Forum:
BRZ First-Gen (2012+) -- General Topics
10-01-2023, 09:47 PM
19,878
WHAT DID YOU DO TO YOUR BRZ TODAY?
8,802,621
Posted By
blsfrs
And here I thought you lost a 10mm socket.
Forum:
DIY (Do-It-Yourself) Guides
03-13-2023, 09:12 AM
7
Rear OEM shock direction.
1,047
Posted By
Opie
The correct orientation of the top hats will...
The correct orientation of the top hats will ensure the bottom mount lines up propery with the lower control arm, forcing, or twisting it to fit is not advisable and will likely result in binding and...
Forum:
Engine, Exhaust, Transmission
03-10-2023, 09:11 AM
10
Blox Uel, tomei uel, plm uel, skunk2 uel. Which is best?
1,381
Posted By
blsfrs
IMHO: Knock the cat out of the jdl and have the...
IMHO: Knock the cat out of the jdl and have the cracks welded up.
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
03-09-2023, 02:36 AM
11
Suspension Installation Tips
1,148
Posted By
MrSkubi
Second this. For me this was the most frustrating...
Second this. For me this was the most frustrating part of coilover install.
My 2 cents:
1. Check every bolt and locking collars on your new suspension that it's torqued to manufacturer recommended...
Forum:
Issues | Warranty | Recalls / TSB
03-06-2023, 08:03 AM
6
Automatic trans problem need help to diagnose please
1,039
Posted By
Have somebody pull the codes as to why you have...
Have somebody pull the codes as to why you have the lights on. It may have happened 9 months ago but things are escalating and now issues are appearing.
Forum:
Scion FR-S / Toyota 86 GT86 General Forum
10-30-2022, 04:11 AM
24,605
WHAT DID YOU DO TO YOUR FRS TODAY?
7,232,504
Posted By
Sam86
What was meant to be simply adding quad tip...
What was meant to be simply adding quad tip garnishes to a MY17 bumper turned into a lot more work. I bought a bumper online that had much more severe damage than described and shown in the pictures....
Forum:
Forced Induction
10-27-2022, 12:58 PM
4,964
Edelbrock E-force Owner's thread and FAQs (Frequently Asked Questions)
1,478,055
Posted By
Jeff86
Christmas came early
Forum:
10-25-2022, 04:50 PM
24,605
7,232,504
Posted By
DarkPira7e
Replaced some crusty bolts with zinc plated bolts...
Replaced some crusty bolts with zinc plated bolts or fresher looking ones (if I didn't have the right size in zinc).
Mostly chassis hardware that wasn't touched when doing the engine. Zinc bolts...
Forum:
09-12-2022, 12:39 AM
19,878
8,802,621
Posted By
Ace23_BRZ
Installed my DSS LV4 800HP axles today
LoL, I saw some other people install axles and I'm gonna be honest, these bitches were not that easy to come out :lol:
The second pic is a side-by-side OEM axle vs DSS LV4 axle...OEM looks like a...
Forum:
GR86 General Topics (2nd Gen 2022+ Toyota 86)
07-20-2022, 06:31 PM
1,217
Potential Cause of rumored GR86’s blown engine? Seal packing(RTV) was peeled off
215,978
Posted By
DocWalt
I was due for an oil change so I poked my crappy...
I was due for an oil change so I poked my crappy old borescope in the pan. Plenty of excess RTV. Not as bad as that above example from the Toyota tech, but still.
Subaru is in for a rude awakening...
Forum:
07-07-2022, 09:41 AM
14
Stalling, power steering out, melted battery cover. Help
2,939
Posted By
Colin86
New fuse block installed, sanded things, put it...
New fuse block installed, sanded things, put it back together and everything runs great. The old fuse block had plastic melted across nearly the entire bottom of the contact point -definitely what...
Forum:
Forced Induction
07-02-2022, 12:00 AM
10
Belt snapped...dont know what to do
3,131
Posted By
FunnyGopher
Yeah, you really just need the length of the...
Yeah, you really just need the length of the belt. If you can find that, you can find a replacement. Hard to tell what the problem with idle is. I'd either find the tuner who tuned it and have them...
Forum:
07-01-2022, 07:33 PM
14
2,939
Posted By
soundman98
looks to me like a loose connection. it didn't...
looks to me like a loose connection. it didn't blow the fuse, which rules out a failed device. 7.5A is much lower than the wire should be rated for, so a loose ground issue would result in a blown...
Forum:
06-04-2022, 11:05 PM
33
Lugnuts rusting and falling apart?
2,324
Posted By
The problem with some shops (there are probably...
The problem with some shops (there are probably more good than bad) is that hand starting all those nuts takes time and time is money. They end up sticking them in an impact gun and however they...
Forum:
Cosmetic Modification (Interior/Exterior/Lighting)
05-26-2022, 09:54 PM
6
Sequential Centre Brake Light. So Groovy!
1,177
Posted By
T.Q.
Today I installed a custom-made sequential brake light, with pulsating/breathing effect, on my 86.
and boiii, it does look absolutely fantastic! it's also blacked out which visually makes the rear...
Forum:
11-15-2021, 07:38 AM
24,605
7,232,504
Posted By
StraightOuttaCanadaEh
Had a friend help me sort out the wiring for the...
Had a friend help me sort out the wiring for the lighting of the new gauge cluster face. And by "help me" I mean he did the whole thing lol. I am completely useless when it comes to electrics. But...
Forum:
08-18-2021, 03:19 PM
24,605
7,232,504
Posted By
Cephas
Installed the brake light lowering kit from SKR ...
Installed the brake light lowering kit from SKR (http://skronline.net/)the other day. Really well-thought-out kit, very simple install, and (to me) dramatically improves the look of the rear deck....
Forum:
08-09-2021, 08:19 PM
21
Grey sealant chunks in oil filter..engine failure imminent?
4,264
Posted By
NoHaveMSG
It was easier to make a quick video then to...
It was easier to make a quick video then to upload a bunch of pictures and explain what is going on. I am actually surprised, it does connect to more head drains. One goes to the PCV. The other goes...
Forum:
08-07-2021, 09:25 PM
24,605
7,232,504
Posted By
https://i.imgur.com/8XYa7b3l.jpghttps://i.imgur.co...
https://i.imgur.com/8XYa7b3l.jpghttps://i.imgur.com/BKnMPUO.jpg
Forum:
07-19-2021, 05:34 AM
24,605
7,232,504
Posted By
Wally86
So... post accident remark quad exhaust was...
So... post accident remark quad exhaust was melting the passenger side on top of the driver side and sitting forward of it's normal placement (super tweaked even though it isn't obvious where it's...
Forum:
07-16-2021, 10:29 PM
24,605
7,232,504
Posted By
MCTeeJ
Haven't posted on the forum in over a year but...
Haven't posted on the forum in over a year but just recently got my car back from the wrap shop. Went from the stock 37j whiteout to 3m Gloss Dragon Fire. I find myself staring at it often.
Forum:
07-16-2021, 07:36 AM
24,605
7,232,504
Posted By
new gauge cluster face ...
https://i.postimg.cc/ZnGLcKn5/5260-A09-E-6805-4-DF9-90-C6-029-C87-B98-BD1.jpg
Forum:
07-10-2021, 08:22 PM
24,605
7,232,504
Posted By
Wally86
https://live.staticflickr.com/65535/51302302987_15...
https://live.staticflickr.com/65535/51302302987_15a505c6bd_c.jpg
https://live.staticflickr.com/65535/51302301967_e8e3c5ac7f_c.jpg
Forum:
Off-Topic Lounge [WARNING: NO POLITICS]
07-07-2021, 07:20 PM
1,617
Thread trolling 101
163,632
Posted By
There can never be a new Pantera. It just would...
There can never be a new Pantera. It just would not be the same without Dimebag!
Forum:
07-07-2021, 07:16 PM
19,878
8,802,621
Posted By
soundman98
you know, when my parents where kids, when they...
you know, when my parents where kids, when they got a free tire, they were happy about it.
Forum:
07-04-2021, 01:28 PM
26
New to welding...recommendations/tips?
3,676
Posted By
nextcar
Lots of good advice so far... but I cannot...
Lots of good advice so far... but I cannot believe no one has said:
Buy a good grinder! (Especially useful as you are learning).
There are good welders, and there are good grinders. For a long...
Forum:
07-02-2021, 12:33 PM
24,605
7,232,504
Posted By
Wally86
Backtracking just a little... May 29th,...
May 29th, after 39 years of living on this planet and 22 years of legally driving (26 otherwise), I finally hydroplaned. It was like a weird rollercoaster... and...
Forum:
06-22-2021, 04:05 PM
26
3,676
Posted By
Rent a MIG unit with a bottle of CO2-argon mix. ...
Rent a MIG unit with a bottle of CO2-argon mix. Get some scrap steel. Read up as best you can and go to town.
After a couple hours, you'll know if you want to own one. Best bang-for-buck...
Forum:
06-22-2021, 10:17 AM
26
3,676
Posted By
It is sort of a chicken and egg situation when...
It is sort of a chicken and egg situation when new to welding and using cheaper equipment. The cheaper stuff is often harder to use and beginners get frustrated with their results which means they...
Forum:
06-22-2021, 08:19 AM
26
3,676
Posted By
Check reviews very carefully before springing for...
Check reviews very carefully before springing for a welder. There are good inexpensive ones and there are cheap ones. They are not the same thing!
Also take a look at your local online market...
Page 1 of 17
1
2
3
4
5
11
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Site Announcements / Questions / Issues
01:04 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
