follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Members List
Calendar
Search
Today's Posts
Mark Forums Read
Search Forums
Search Results
Page 1 of 3
1
2
3
Showing results 1 to 30 of 71
Search took
0.01
seconds.
Search:
Posts Made By:
37
Forum:
Engine, Exhaust, Transmission
01-02-2015, 12:38 AM
489
CUSCO 4.55 FINAL DRIVE installed.
259,010
Posted By
37
I get 28+ MPG with a 4.67 and 6MT. Going...
Going from 4.1 to 4.25~4.33 is only a 3.5~5% change and won't be worth the cost or hassle. Don't do it unless you're going 10% or more. Go 4.55+ or keep it stock.
Forum:
Member's Car Journals
12-19-2014, 01:19 PM
244
Zenki 10 series TRD build
96,018
Posted By
37
More than likely it's the fluorescent lighting...
More than likely it's the fluorescent lighting throwing off the auto white balance on the OP's cell phone. It's a common issue.
Forum:
DIY (Do-It-Yourself) Guides
12-12-2014, 09:26 AM
452
DIY - Swap clutch slave cylinder and hydraulic line for improved feel and control
229,901
Posted By
37
Same here. I adjusted my pedal shortly after...
Same here. I adjusted my pedal shortly after buying the car and dialed it in again after installing a lightweight clutch/flywheel. No further adjustments were made after installing the smaller slave....
Forum:
Cosmetic Modification (Interior/Exterior/Lighting)
12-05-2014, 04:37 PM
79
Protek Skid Plate Install
36,130
Posted By
37
My BRZ bumper is scraped on the bottom and would...
My BRZ bumper is scraped on the bottom and would have been protected had these plates been in place. You can't see the scrapes unless looking for them. Very few would expect a plate on the bottom to...
Forum:
12-04-2014, 05:30 PM
25
Final drives and onboard calibrations
5,708
Posted By
37
I have a 4.67. GPS is dead-on against the speedo...
I have a 4.67. GPS is dead-on against the speedo at a +1MPH delta at 60MPH with stock tires at 32F/35R PSI (61MPH indicated / 60MPH GPS). That number didn't change with the FD, only after changing...
Forum:
11-18-2014, 10:39 AM
167
Does the clutch fake you out?
62,638
Posted By
37
Put the car up on a lift or jack stands with the...
Put the car up on a lift or jack stands with the rear wheels removed. Start the car, then push the clutch pedal and release it a few times. See if the rear end moves. If it remains stationary then...
Forum:
11-16-2014, 11:56 AM
20
Clutch, LW flywheel and chatter....
9,989
Posted By
37
The OEM flywheel is heavy to soak up NVH created...
The OEM flywheel is heavy to soak up NVH created by the engine. Using a lightweight flywheel can introduce added noise in the system.
It's usually not the clutch making noise but instead the...
Forum:
11-14-2014, 02:09 PM
21
Reccomendations for clutch set-up.
6,074
Posted By
37
I have an ACT ProLite fly and HDSS clutch in mine...
I have an ACT ProLite fly and HDSS clutch in mine with the smaller slave and haven't found any issues DD'ing my car since last weekend's installation of the slave. The clutch/fly are about 1.5 years...
Forum:
11-10-2014, 05:52 AM
452
229,901
Posted By
37
The factory BRZ/FRS slave is 13/16". The...
The factory BRZ/FRS slave is 13/16". The 30620AA111 is 3/4" and 1/16" smaller than stock (approximately 15%).
By shrinking the slave you reduce the amount of distance that the master needs to...
Forum:
11-09-2014, 09:15 PM
167
62,638
Posted By
37
Posted earlier in the thread:...
Posted earlier in the thread: http://www.ft86club.com/forums/showpost.php?p=2012934&postcount=118
Forum:
11-09-2014, 04:00 PM
167
62,638
Posted By
37
Finally installed mine today. The engagement...
Finally installed mine today. The engagement shrunk enough to where you can feel a definitive grab point versus the vague stock throw. Overall pedal travel feels much closer to what I'd consider...
Forum:
11-06-2014, 03:25 PM
167
62,638
Posted By
37
edit: nevermind. You're correct - I just checked...
edit: nevermind. You're correct - I just checked the action and the spring cams over center. It does appear to assist.
Your CarQuest part number was incorrect but the Subaru part was fine. Your...
Forum:
11-06-2014, 02:51 PM
167
62,638
Posted By
37
30620AA111 is a 1:1 swap with the FRS/BRZ slave....
30620AA111 is a 1:1 swap with the FRS/BRZ slave. It's the same casting with a smaller piston. The slave that @Ultramaroon (http://www.ft86club.com/forums/member.php?u=87905) purchased is for an older...
Forum:
11-06-2014, 09:43 AM
167
62,638
Posted By
37
MTEC makes a replacement spring that might prove...
MTEC makes a replacement spring that might prove to be a good balance. No idea on the spring weight compared to stock. Judging by wire dimensions alone it looks to be 40~50% lighter than stock, right...
Forum:
11-02-2014, 01:15 AM
167
62,638
Posted By
37
I've built and installed both -4 AN and -3 AN...
I've built and installed both -4 AN and -3 AN stainless lines on other clutch systems and the difference is two-fold:
-4 line (0.25" ID) moves fluid slower and allows the slave to return quicker....
Forum:
11-01-2014, 11:31 PM
167
62,638
Posted By
37
Killer. That's exactly what I'm after. ...
Looks like the AutoZone part might be the same as the 30620-AA111. The compound angles on the banjo area look the same to me.
Forum:
Groupbuys
10-30-2014, 01:58 PM
286
Low Profile Carbon Fiber 3rd Brake light GROUP BUY
21,856
Posted By
37
Received mine this morning as well. Outstanding...
Received mine this morning as well. Outstanding construction, especially for a handmade piece. Craftsmanship and attention to detail are 100% and better than you'd see in something mass-produced. I...
Forum:
Wheels | Tires | Spacers | Hub --
Sponsored by The Tire Rack
10-26-2014, 03:17 PM
47
Lightweight wheels in 18x8.5?
19,247
Posted By
37
TWS are the lightest in the $800 range. @CSG Mike...
TWS are the lightest in the $800 range. @CSG Mike (http://www.ft86club.com/forums/member.php?u=15046) should be able to set you up.
http://counterspacegarage.com/products/tws-forged.html?p=1
Forum:
10-26-2014, 03:07 PM
47
19,247
Posted By
37
I'm still editing the list. Don't expect anything...
I'm still editing the list. Don't expect anything cheap. ;)
Sub-18lbs is difficult without going with the standard RPF1 in an 18x8.0 +35 (which I believe is right at 18lbs).
The question comes...
Forum:
10-26-2014, 02:50 PM
47
19,247
Posted By
37
TWS T-66F (86/BRZ spec) 18x8.5 5x100 +42 56.1mm...
18x8.5 5x100 +42 56.1mm bore
6.90 kg (15.21 lbs)
http://www.tws-forged.com/tws_t66-f.html
Volk Racing CE28N
18x8.5 5x100 +44 65mm bore (needs hub-centric rings)...
Forum:
10-10-2014, 06:07 PM
153
3rd Brake Light *Low Profile Carbon Fiber (OMG CARBON) (GB OVER- see link)
41,349
Posted By
37
4949 should work well. It might be a slight pain...
4949 should work well. It might be a slight pain to remove but at least it's only 1/4". :D
Design is looking great, btw. Keep me in the loop on the GB. :thumbsup:
Forum:
09-18-2014, 04:33 PM
153
41,349
Posted By
37
4929 / 4949 / 5952 are all for bonding metal and...
4929 / 4949 / 5952 are all for bonding metal and plastic. 4947F is specifically for bonding various substrates to glass. While all of these should work, my money is on 4947F above all else. I have...
Forum:
09-18-2014, 01:32 PM
153
41,349
Posted By
37
3M 4947F should fit the bill. It's black,...
3M 4947F should fit the bill. It's black, UV-resistant, and 49 mils (1.1mm) to dampen both vibration and be thick enough to wedge something between the glass and carbon housing in the event it needs...
Forum:
BRZ First-Gen (2012+) -- General Topics
02-17-2014, 03:31 PM
47
What would be your mod list if you had $1000 mod money?
5,927
Posted By
37
Skip Barber Teen Safety and Survival School: $995...
Lunch at Burger King: $5
Complimentary paper crown at Burger King: $0
Wear the crown after graduating. You'll feel like a king.
Forum:
01-30-2014, 02:29 PM
120
My final gear swap project
57,449
Posted By
37
Yes... you're missing a manual gearbox. :D ...
5.26 on auto sounds short but isn't far from 4.88 behind a manual. You won't know unless you try. I highly doubt anyone has gone that short on an auto.
Forum:
10-16-2013, 05:55 PM
120
57,449
Posted By
37
Nice! That's an accurate way to describe the...
Nice! That's an accurate way to describe the effect. Glad to hear the 4.88 (most likely) turned out to be the right ratio for you. Keep us posted.
That's a bad idea. If anything you would want...
Forum:
09-10-2013, 08:54 PM
12
Any interest in 4.5 final drive from Auto Factory?
5,430
Posted By
37
Have you found a solid price after shipping/duty?...
Have you found a solid price after shipping/duty? If not then you might want to consider other options. You're probably looking at $600+ per set by the time you get them in-hand. Heavy items are...
Forum:
Announcements, Contests, Giveaways
09-09-2013, 05:16 PM
179
T-shirt giveaway: Win a free Rally Slide from bestwheelbase!
4,799
Posted By
37
Fixed it for ya. I win size medium. :thumbsup: ...
Side note: Ever notice that :thumbup: is called "Thumbup" and :thumbsup: called "Thumbsup"? Strange.
Forum:
09-06-2013, 11:09 PM
99
MISHIMOTO OIL COOLER IS A FIRE HAZARD!!
64,707
Posted By
37
So... in other words you over-torqued everything?...
Couldn't resist. :lol:
Why are they using banjo fittings? This is at the sandwich plate, correct? Perrin uses 90-degree hose ends into...
Forum:
09-04-2013, 12:59 AM
120
57,449
Posted By
37
Sure thing. I hope the 4.88 works and am curious...
Sure thing. I hope the 4.88 works and am curious to see how things turn out. The math is definitely there. Hopefully your results match. :D
np. The speedo works off of a wheel speed sensor and...
Page 1 of 3
1
2
3
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
09:07 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
