follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 3
1
2
3
Showing results 1 to 30 of 77
Search took
0.01
seconds.
Search:
Posts Made By:
prandelia
Forum:
Brakes, Suspension, Chassis
04-02-2024, 11:38 PM
5
FS: Ultimate Track/Race - Ohlins R&T-revalved w/ springs/camber plates- NEW PRICE
1,333
Posted By
prandelia
OK guys these need to go. $2500 shipped. Lowest...
OK guys these need to go. $2500 shipped. Lowest price I will go.
Forum:
Engine, Exhaust, Bolt-Ons
06-20-2022, 02:44 PM
15
Huge Track-car Bolt-on Sale - ACE/Cusco/TODA/JUN/Grimspeed etc. etc.
4,689
Posted By
prandelia
They are the updated style
Forum:
05-11-2022, 04:04 PM
0
Huge Track-car Bolt-on Sale - all my goodies
774
Posted By
prandelia
See my huge sale here, a ton of go-fast bolt-ons.
https://www.ft86club.com/forums/showthread.php?t=149752
Forum:
Tracking / Autocross / HPDE / Drifting
02-26-2021, 06:36 PM
93
JUN GT Intake Manifold - It's finally here!
14,325
Posted By
prandelia
bro. When you race in a series that is governed...
bro. When you race in a series that is governed by hp/wt ratio, torque becomes a real factor. It's not just about how much hp you have, it's also about using the torque you have on the few, slower...
Forum:
02-26-2021, 12:57 PM
93
14,325
Posted By
prandelia
I would argue otherwise. The whole point is to...
I would argue otherwise. The whole point is to avoid having to open this engine up because it's a nightmare to pull and work on, compared to say a K24 or something. Nothing is easy to do on it. So...
Forum:
02-26-2021, 11:57 AM
93
14,325
Posted By
prandelia
THIS. Exactly. I will say, you do have the V3...
THIS. Exactly. I will say, you do have the V3 version of the valvetrain which is arguably the best, but the 2015 version seems very robust as well, and I'm not concerned about it. My plan is to...
Forum:
02-26-2021, 11:53 AM
93
14,325
Posted By
prandelia
You clearly don't understand just how much the 4...
You clearly don't understand just how much the 4 factors I listed affect dyno numbers. I do, I've seen it, on my car. I've paid to test it. I've had my car on the dyno countless times testing all...
Forum:
02-25-2021, 09:26 PM
93
14,325
Posted By
prandelia
The torque that the 350 gives is actually more...
The torque that the 350 gives is actually more beneficial for racing....the flat torque curve is one of the reasons this car can punch so far above it's weight. I've toyed with the idea of testing...
Forum:
02-25-2021, 09:22 PM
93
14,325
Posted By
prandelia
Exactly. For my race series, I already make all...
Exactly. For my race series, I already make all the power I need, and anything beyond 200whp, I have to detune anyway (which is fine). I can't really remove any more weight. I'm about 2350#, so...
Forum:
02-25-2021, 02:40 PM
93
14,325
Posted By
prandelia
E85 Yes. 2015+ valvetrain is a bit...
E85
Yes. 2015+ valvetrain is a bit more robust than early cars. I don't plan to rev to 8K all the time, I just need those few extra RPM's for a few places on tracks now that I am geared...
Forum:
02-25-2021, 10:28 AM
93
14,325
Posted By
prandelia
The numbers don't look good, but that's not the...
The numbers don't look good, but that's not the whole picture. There are alot of factors that are also definitely costing me WHP from my previous dyno, that have nothing to do with the JUN manifold....
Forum:
02-23-2021, 06:58 PM
93
14,325
Posted By
prandelia
Manifold installed. Dyno tomorrow. Let's see...
Manifold installed. Dyno tomorrow. Let's see what this thing can do.
Forum:
02-06-2021, 10:41 AM
93
14,325
Posted By
prandelia
Already have a TODA big TB installed, but thanks...
Already have a TODA big TB installed, but thanks for the head's up.
Adding some heat resistance before install.
Forum:
02-03-2021, 02:53 PM
93
14,325
Posted By
prandelia
Wow, this manifold is like art. Handmade, welds are amazing, and can't wait to see what kind of power this makes spinning to 8k. This is also probably the only manifold that can make use of...
Forum:
02-03-2021, 12:19 PM
76
coil packs Replacements OEM or Aftermarket
15,519
Posted By
prandelia
Just adding cooling doesn't fix the real issue,...
Just adding cooling doesn't fix the real issue, especially with hot tunes or cars making more power and running high RPM. You need a coil pack designed to handle the higher current and heat load. ...
Forum:
12-07-2020, 04:48 PM
53
CV joint issues on track cars
9,003
Posted By
prandelia
Stiffer spring rates Raised rear subframe (SPL...
Raised rear subframe (SPL subframe bushing kit)
Max out rear droop travel with tender springs
Cusco heat shield
OE axles re-packed with hi-temp grease (Redline CV for...
Forum:
Engine, Exhaust, Transmission
11-20-2020, 03:16 PM
60
JUN GT SURGE TANK FOR FT86/BRZ
26,939
Posted By
prandelia
That's the conclusive data I like seeing. ...
That's the conclusive data I like seeing. :thumbup:
Expecting my new peak hp to be around 7600-7800rpm from 7150, on E85 spun to 8K for racing. Hoping it shows up in time as my Xmas present.....
Forum:
10-23-2020, 03:37 PM
29
Diff Cover
6,855
Posted By
prandelia
+1 I mounted up a axle shield as well. ...
+1
I also re-packed my axles with Redline CV2 grease. Full spare set re-packed as well. The OE grease is junk, even with just street use.
Forum:
10-20-2020, 11:12 PM
24
Learn Me - Square F/R Pads with/without ABS
4,950
Posted By
prandelia
Thanks! C1 and CE2 are prob what I'm looking to...
Thanks! C1 and CE2 are prob what I'm looking to try for the CP9660 for casual track day use. The DS1.11 is just too on-off to really finesse the car while on the brake, IMO. I honestly cannot...
Forum:
10-20-2020, 07:12 PM
24
4,950
Posted By
prandelia
You are totally right about pricing. I've had my...
You are totally right about pricing. I've had my eye on that pad before. Trust me, I don't love the Pagids or PFC's as much anymore, both have flaws. Pagids lose performance big time after 50%...
Forum:
10-16-2020, 02:06 PM
28
NASA TT5/ST5 setup
6,895
Posted By
prandelia
That's retarded. Not to get off topic, but...
That's retarded.
Not to get off topic, but you should come run a weekend with GLTC next season.
Forum:
10-15-2020, 11:32 PM
28
NASA TT5/ST5 setup
6,895
Posted By
prandelia
If you plan to take some points, I took kind of...
If you plan to take some points, I took kind of hybrid approach where I put sphericals in the two places where they need it the most, and utilize cheaper, but good parts elsewhere to give nice...
Forum:
10-15-2020, 03:19 PM
28
NASA TT5/ST5 setup
6,895
Posted By
prandelia
Sometimes. My teammates/buddies are who...
Sometimes. My teammates/buddies are who basically brought the K24 miata to racing (Winning Formula), Aaron Leichty, Rob, and Emile....my car is also prepped at Winning Formula. I have a miata too,...
Forum:
10-15-2020, 02:23 PM
60
26,939
Posted By
prandelia
Yeah, no lie, the 4.3 is damn near perfect from...
Yeah, no lie, the 4.3 is damn near perfect from the standpoint of mph and shifting at all the tracks I race at (Mid-O, NCM, Road America, Autobahn, Barber, Gingerman, etc.), but to keep up with these...
Forum:
10-15-2020, 02:12 PM
28
NASA TT5/ST5 setup
6,895
Posted By
prandelia
I run no splitter, and a rear wing, for the same...
I run no splitter, and a rear wing, for the same reason, to avoid modifier weight. The balance is phenomenal, and easy to tailor to your preference using alignment and rake. A bit more rear spring...
Forum:
10-15-2020, 01:56 PM
60
26,939
Posted By
prandelia
Bringing this thread back from the dead. The...
Bringing this thread back from the dead. The forum now has one more person crazy enough to do this. I just bought a JUN GT surge tank (manifold), and will post up some E85 dyno numbers from my race...
Forum:
10-14-2020, 06:40 PM
28
NASA TT5/ST5 setup
6,895
Posted By
prandelia
I haven't yet actually, because we are running...
I haven't yet actually, because we are running peak hp in GLTC, but my focus was always on fattening up the powerband, and not worrying about the peak as much. I'll calculate it once I get ready to...
Forum:
10-14-2020, 06:14 PM
28
NASA TT5/ST5 setup
6,895
Posted By
prandelia
Totally agree. Can't imagine racing at any of...
Totally agree. Can't imagine racing at any of these without one.
My question is, who is making 199 avg. hp, and if so, how?
I'm at 200whp now with E85, ACE350, TRD intake, 3"exhaust, Toda big...
Forum:
10-14-2020, 05:28 PM
58
Mid Div TT development thread
7,096
Posted By
prandelia
206whp sounds super strong, but certainly...
206whp sounds super strong, but certainly possible, especially with a newer '17+ motor. FWIW - for help with your build, I also have a '15, and has just about every mod imaginable, as my car is a...
Forum:
09-30-2020, 10:11 AM
116
FA20 Rocker Retainer Kit
31,232
Posted By
prandelia
Bingo. Oil is rated at 212F. Know your temps...
Bingo. Oil is rated at 212F. Know your temps and monitor pressure, and use the oil accordingly. At redline, my pressures are routinely 88-90+psi at 215-230 temps, I virtually never see anything...
Page 1 of 3
1
2
3
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
01:25 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
