follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Showing results 1 to 26 of 26
Search took
0.50
seconds.
Search:
Posts Made By:
Open Loop
Forum:
Engine, Exhaust, Transmission
05-02-2023, 06:14 AM
12
Direct Injectors stuck in head.
2,106
Posted By
Open Loop
It went great. It seems like putting them on the...
It went great. It seems like putting them on the rails first is the only way to go. I put them in the freezer first. Required a bit of a push to get them going. Car runs noticeably smoother, and...
Forum:
GR86 General Topics (2nd Gen 2022+ Toyota 86)
04-14-2023, 11:37 AM
1,392
GR 86: Orders /Reservation /Waitlist Chat
223,652
Posted By
Open Loop
Got an email from the dealer today saying "YOUR...
Got an email from the dealer today saying "YOUR NEW VEHICLE HAS ARRIVED!!!" Made arrangements to pick it up this afternoon. Steel Premium Manual. Very excited.
Forum:
04-02-2023, 10:18 PM
12
2,106
Posted By
Open Loop
Thanks - they are new OE injectors with seals...
Thanks - they are new OE injectors with seals preinstalled. I really don't want to screw them up when installing.
Forum:
Issues | Warranty | Recalls / TSB
08-05-2021, 04:21 PM
8
Battery boiling over causing misfire cyl. 2 on track.
1,828
Posted By
Open Loop
Thanks for all the responses. I am more...
Thanks for all the responses. I am more concerned about hurting performance than damaging a replaceable cat. I am slow enough as it is and don't want a clogged cat holding me back.
Forum:
08-04-2021, 11:01 PM
8
1,828
Posted By
Open Loop
The caps don't appear removable to me but I have...
The caps don't appear removable to me but I have not tried prying at them to confirm. The car is reading 13.1 volts when I turn it off, and 13.0 an hour later (off). It is charging at 14.7 with all...
Forum:
08-04-2021, 10:30 AM
8
1,828
Posted By
Open Loop
Thank you - in process of cleaning it now. There...
Thank you - in process of cleaning it now. There was quite a bit of battery acid. There were drops of dried acid on the cyl. 2 coil last night which is some distance from the battery. I am...
Forum:
08-04-2021, 07:54 AM
8
1,828
Posted By
Open Loop
I have a 2013 FR-S with nearly no engine modifications other than a Jackson Racing Oil Cooler (SSC autocross setup).
I was in my third 20-minute track session last night when the car suddenly...
Forum:
Tracking / Autocross / HPDE / Drifting
07-29-2019, 03:56 PM
12
Safety question around harnesses
2,624
Posted By
Open Loop
I recommend considering a Simpson Hybrid S head...
I recommend considering a Simpson Hybrid S head and neck restraint (the one designed to work with three point belts) before changing the belts in your car at this point.
Forum:
07-25-2019, 09:48 PM
14
Two transmission issues
2,443
Posted By
Open Loop
Sorry - It was Mobil 1 in the diff. Motul 300 in...
Sorry - It was Mobil 1 in the diff. Motul 300 in the transmission at 46,000 miles. Thank you.
Because it is SSC, I can't put a transmission brace mount or bushing upgrades in. However,...
Forum:
06-17-2019, 05:45 PM
104
No Issue After J02 Recall: Registry Thread
33,873
Posted By
Open Loop
I want to append this a little bit: After about...
I want to append this a little bit: After about 50 miles following the recall, I drained the oil (taking the quick-drain plug out to allow for a larger opening) and ran it through a filter and it...
Forum:
04-29-2019, 07:56 AM
104
33,873
Posted By
Open Loop
I am at about 3,000 miles post-recall with about...
I am at about 3,000 miles post-recall with about 5-6 hours of track driving. I think I am in the clear. I had the work done at Rohrich Toyota in Pittsburgh. I don't know if I would get this recall...
Forum:
03-20-2019, 10:11 PM
47
Valve spring recall is ridiculous
8,745
Posted By
Open Loop
I would add to this one point: Take lots of...
I would add to this one point: Take lots of photographs of your engine compartment before the repair is done - many photos with details of all pulleys, etc. After you get it back you may want to...
Forum:
03-19-2019, 05:46 PM
489
Registry Thread: Failure After J02 Recall
218,187
Posted By
Open Loop
The upper part of the engine work not causing...
The upper part of the engine work not causing botton end issues is obviouly a stupid excuse. I think they are trying to take advantage of you.
Forum:
03-19-2019, 03:48 PM
1,654
Failure After J02 Recall - Discussion Threads
382,483
Posted By
Open Loop
I am assuming that the tech that removed this...
I am assuming that the tech that removed this from the car deliberately ripped open the screen and pulled out some of the sealant to get a sense of what there was and how much behind it.
Are the...
Forum:
03-18-2019, 06:32 PM
28
Update on J02 recall failure.
5,622
Posted By
Open Loop
That first video should be shown to every tech...
That first video should be shown to every tech that is doing this repair.
Forum:
03-17-2019, 09:53 PM
104
33,873
Posted By
Open Loop
I have 45,000 miles and I went with the spark...
I have 45,000 miles and I went with the spark plugs and TOB. Unless you are really hard on the clutch it should last many more years.
Forum:
08-16-2018, 11:07 AM
14
Safety Equipment for Track Days?
3,046
Posted By
Open Loop
Sorry I didn't see this earlier, or I would have...
Sorry I didn't see this earlier, or I would have contacted you.
Forum:
Brakes, Suspension, Chassis
03-10-2018, 09:00 PM
7
Koni Yellows and Front Strano Front Sway Bar
2,424
Posted By
Open Loop
SOLD
Forum:
03-09-2018, 06:22 PM
1,281
Spec Twin?
201,635
Posted By
Open Loop
Another question for y'all. Per the installation...
Another question for y'all. Per the installation instructions at the Tire Rack website:
After the alignment is completed. The steering angle must be re-calibrated for the OEM stability control...
Forum:
03-09-2018, 12:29 PM
1,281
Spec Twin?
201,635
Posted By
Open Loop
https://www.koni.com/en-US/Cars/Technology/Adjustm...
https://www.koni.com/en-US/Cars/Technology/Adjustment-Guides/
The shocks have an adjustable rebound. Compression is not affected by adjustment. Make sure you got at least one of the adjustment...
Forum:
11-20-2017, 04:31 PM
1,281
Spec Twin?
201,635
Posted By
Open Loop
If it adds weight and offers no performance...
If it adds weight and offers no performance benefit for AX I don't see how it becomes considered a need in the class. It is not on my shopping list.
Forum:
09-14-2017, 10:01 PM
1,281
Spec Twin?
201,635
Posted By
Open Loop
I also am using the stock sway bar links with my...
I also am using the stock sway bar links with my Strano front bar and I have no clunks. I HAD clunks and it took me a while to chase it down but it turned out to be a lose sway bar end link nut. ...
Forum:
09-10-2017, 07:08 AM
1,281
Spec Twin?
201,635
Posted By
Open Loop
We have a very similar setup, but I really like...
We have a very similar setup, but I really like my Strano bar. I love my DS setup and it is one of the things that is making me question whether to make the switch to SSC, but I am 95% sure I will...
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
06-01-2017, 07:30 AM
25
Clunking on hard cornering from front suspension
6,659
Posted By
Open Loop
It is possible to have the Strano bar with Konis...
It is possible to have the Strano bar with Konis and stock end links be completely quiet. I would double check to see if the sway bar is centered (which you can do by eyballing it) and the two...
Forum:
05-22-2017, 07:26 AM
25
6,659
Posted By
Open Loop
Crash bolts remain tightened to 120 lbs and no...
Crash bolts remain tightened to 120 lbs and no sign of shifting. Fsb supports are tight. End links were not hitting control arms 3 days ago and i double checked the clamps that keep the fsb from...
Forum:
Scion FR-S / Toyota 86 GT86 General Forum
08-31-2016, 05:47 PM
8,168
Sticky:
New here? Come say hi =)
1,935,097
Posted By
Open Loop
Chiecking in from Pittsburgh
Greetings everyone! Yesterday I picked up a 2013 FRS manual Whiteout that is stock with the stock spoiler, with the exception of the tires, which are Michelin Pilot all seasons. I have a set of...
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
10:41 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
