follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Members List
Calendar
Search
Today's Posts
Mark Forums Read
Search Forums
Search Results
Page 1 of 2
1
2
Showing results 1 to 30 of 58
Search took
2.78
seconds.
Search:
Posts Made By:
highway7
Forum:
Issues | Warranty | Recalls / TSB
12-18-2019, 12:19 PM
17
Recurring issue: suspension mount popping (TSB 05-61-16)
3,757
Posted By
highway7
I had this problem as well, reversing while...
I had this problem as well, reversing while turning the wheel led to multiple audible pops
I fixed by tightening the 3 strut tower nuts, and also cleaning and re greasing the front brake pads.
Forum:
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
12-18-2019, 12:17 PM
33
Need help extracting drain plug...
8,188
Posted By
highway7
6 point Then remove splash panel and use...
6 point
Then remove splash panel and use vice grips
How did you manage to round off the bolt? Unless the 12 pt wasn't on properly?
Forum:
11-12-2019, 11:53 PM
46
Is it normal that the coolant gets low in time?
10,329
Posted By
highway7
Known problem with this car. I top off the...
Known problem with this car. I top off the coolant every year or so with dealership OEM coolant. No overheating problems.
To everyone suggesting that it's due to the water "evaporating". Has...
Forum:
06-12-2019, 08:24 PM
33
AC not blowing any cold air
13,686
Posted By
highway7
Just wanted to update Brought my car in...
Brought my car in to the dealership, paid for an AC recharge
They tested with a dye and also pressure tested prior to recharging with new R134A, no signs of serious...
Forum:
02-15-2019, 03:04 PM
85
VALVE SPRING WORLD - PRESS RECALL
35,683
Posted By
highway7
Agreed... Subaru / Toyota really dropped the ball...
Agreed... Subaru / Toyota really dropped the ball by expecting regular techs to rip apart an entire engine to replace valve springs and one-use items. It would have been better to have dedicated...
Forum:
02-15-2019, 12:51 PM
16
Best place for towel to check if I have a motor oil leak? Also question about low oil
3,255
Posted By
highway7
Not for me. I drain exactly 5.4L (~100mL less due...
Not for me. I drain exactly 5.4L (~100mL less due to spillage) as the manual states every time I do an oil change. When I check the oil in the morning it is right at the max dot. Engine doesn't burn...
Forum:
DIY (Do-It-Yourself) Guides
01-30-2019, 07:56 PM
123
Toyota USDM fog light kit install
93,141
Posted By
highway7
The fog lights were a factory option AFAIK. ...
And yes, the actual fog light indicator in the dash does turn on and off with the official OEM (not eBay "OEM") kit.
Forum:
Scion FR-S / Toyota 86 GT86 General Forum
01-07-2019, 04:25 PM
43
What is the factory battery lifespan of the FR-S?
5,973
Posted By
highway7
Original Aug 2013 battery, still going strong....
Original Aug 2013 battery, still going strong. Never left me stranded. If I feel like I need more power, I will turn off fan, radio, lights, and unplug accessories before cranking.
Forum:
12-29-2018, 03:37 PM
28
Oil Level Confusion
8,785
Posted By
highway7
Check the dipstick first thing in the morning,...
Check the dipstick first thing in the morning, make sure you are on level ground. The "Wait at least 10 minutes" is for the oil to drain back into the drain pan to give you the most accurate reading,...
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
12-27-2018, 09:49 PM
54
Chuhatsu Plus Lift springs review for the BRZ
20,424
Posted By
highway7
Came in expecting this ...
http://www.rally.com.au/wp-content/uploads/2018/08/180808_BRZ1-890x606.png
Forum:
12-05-2018, 06:31 PM
39
Is my car done
6,257
Posted By
highway7
Just because it's being done at the dealership...
Just because it's being done at the dealership doesn't mean it will be done correctly. Especially at the Toyota dealership working on a Subaru engine.
IMO, a full engine swap from a shop...
Forum:
Cosmetic Modification (Interior/Exterior/Lighting)
12-05-2018, 06:27 PM
17
So how do you clean the inside of the rear window?
2,570
Posted By
highway7
Just climb in the back. Only tip I have is run...
Just climb in the back. Only tip I have is run your microfiber cloth parallel to the heater elements and not against
Forum:
12-03-2018, 06:52 PM
39
Is my car done
6,257
Posted By
highway7
Yep... bottoming out could have cracked the oil...
Yep... bottoming out could have cracked the oil pan and caused you to lose a significant amount of oil over a short period of time, possibly overnight. If there was barely anything in the dip stick...
Forum:
Engine, Exhaust, Transmission
11-25-2018, 11:42 PM
49
Is my motor built?
8,033
Posted By
highway7
https://i.imgur.com/QONVIyz.gif
Forum:
11-25-2018, 11:39 PM
28
I think I have a blown head gasket; what would you do?
7,469
Posted By
highway7
White smoke from exhaust - It's winter and you...
White smoke from exhaust - It's winter and you live in maine...
Weird trunk smell - Can be anything
Disappearing coolant - Common issue with this car, doesn't mean HG is gone (Not to...
Forum:
11-21-2018, 06:54 PM
129
The 86 on Toyota's Chopping Block ?
23,755
Posted By
highway7
So true. The same people that diss on the FRS/BRZ...
So true. The same people that diss on the FRS/BRZ for being slow are the same people that praise the ND Miata as perfect, even though both vehicles are designed with handling over raw power in mind.
Forum:
11-15-2018, 11:16 PM
5
Mysterious missing fuses?
6,165
Posted By
highway7
RR FOG my guess is the rear fog in UKDM 86s
Forum:
11-14-2018, 06:41 PM
20
common faults
7,001
Posted By
highway7
TOB as stated by others Disappearing...
Forum:
11-13-2018, 12:53 AM
1,037
valve spring issue?
215,326
Posted By
highway7
Good to see that Toyota will reimburse the people...
Good to see that Toyota will reimburse the people who have had their valve springs fail on them previously and had to pay out of pocket for repairs, and good on Subaru for not trying to sweep this...
Forum:
Wheels | Tires | Spacers | Hub --
Sponsored by The Tire Rack
11-09-2018, 08:06 PM
3
Wheels in storage
959
Posted By
highway7
Why would you remove the air? Make sure...
Make sure they are clean and dry, pump them up to 35 psi, stack ontop of each other, done
If they are indoors just don't put them by a window or in direct...
Forum:
11-09-2018, 03:36 PM
129
23,755
Posted By
highway7
I agree... the circle LED is very iconic and at...
I agree... the circle LED is very iconic and at night will not be mistaken for another car. The new 17+ tail lights still look good, but are too common to every other car with LED straight line tail...
Forum:
11-09-2018, 03:12 PM
129
23,755
Posted By
highway7
Release Toyota 86 final edition with all...
Release Toyota 86 final edition with all improvements done over the years, with original 13-16 bumper design, DONE
Forum:
11-05-2018, 06:52 PM
51
2017 BRZ trunk hard to close?
10,429
Posted By
highway7
MY trunk doesn't have any problems. I would take...
MY trunk doesn't have any problems. I would take off the plastic trim and adjust the striker plate
Forum:
11-03-2018, 01:04 AM
1,037
valve spring issue?
215,326
Posted By
highway7
I don't think the VINs are linear. My car is...
I don't think the VINs are linear. My car is manufactured a month after yours at 08/13 and final 6 is 733602.
My car is not in the recall, but who knows what will happen in the future, the...
Forum:
10-19-2018, 02:45 PM
14
10 Cars Most Likely To Get Ruined By Their Owners
2,993
Posted By
highway7
For sure all the 18 year old privileged kids...
For sure all the 18 year old privileged kids who's parent bought them this car usually ended up wrecking in less than 6 months.
Forum:
10-16-2018, 06:40 PM
19
Brake Rotor Blunder
4,632
Posted By
highway7
The pads should just slightly ride ontop of the...
The pads should just slightly ride ontop of the rotors, so a scraping noise is normal. Otherwise, if there is a gap between the pad and rotors dirt will get inbetween.
On RockAuto, you are...
Forum:
10-14-2018, 11:04 PM
5
Which Manual for 2013 FRS? (2 versions)
2,303
Posted By
highway7
From the Canadian website- OM18012U is...
OM18012U is for vehicles produced from March 2012 to May 2012, OM18024U is for vehicles produced in June 2012 and later.
I have gone through both manuals and...
Forum:
08-31-2018, 11:46 AM
184
Manual or Automatic? Why?
28,959
Posted By
highway7
It's in neutral....? Do you even manual?...
Do you even manual? Serious question
Forum:
08-31-2018, 11:41 AM
184
28,959
Posted By
highway7
https://previews.123rf.com/images/tangducminh/tang...
https://previews.123rf.com/images/tangducminh/tangducminh1207/tangducminh120700219/14639217-telegraph-hill-neighborhood-in-san-francisco-viktorianischen-h%C3%A4user-an-einem-steilen-stra%C3%9Fe-.jpg...
Forum:
08-24-2018, 06:16 PM
25
First FRS Purchase - Question !!
3,753
Posted By
highway7
Giant ugly wing, plastidipped stock wheels, ebay...
Giant ugly wing, plastidipped stock wheels, ebay halo fog lights, screw holes from some sort of bodykit
AVOID AVOID AVOID
Page 1 of 2
1
2
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
06:54 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
