follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 3
1
2
3
Showing results 1 to 30 of 67
Search took
0.13
seconds.
Search:
Posts Made By:
jrhudson
Forum:
Issues | Warranty | Recalls / TSB
02-21-2023, 12:39 PM
11
P0455 - Large evap leak
1,757
Posted By
jrhudson
an attempt to feel smart it looks like here. lol
Forum:
Member's Car Journals
02-09-2023, 02:52 PM
281
FR-S Turbo Build
59,549
Posted By
jrhudson
Yea i had fitment issues with it contacting the...
Yea i had fitment issues with it contacting the subframe with others but now im contacting the block. I got sti engine mounts
Ahh ecutek, i always wanted to dabble in tuning even if its a little...
Forum:
02-09-2023, 12:03 PM
281
FR-S Turbo Build
59,549
Posted By
jrhudson
Probably just a problem im having but check your...
Probably just a problem im having but check your clearance on the bottom of your block. For some reason my 3in front overpipe combo makes contact with my heads. Maybe mine is just an older model than...
Forum:
02-06-2023, 11:28 PM
11
1,757
Posted By
jrhudson
My tuner has already disabled the EVAP codes. I...
My tuner has already disabled the EVAP codes. I haven't been going into boost at all when i brought it to work. Highway cruising only. i know fuel mileage is going to be bad, but I feel like I...
Forum:
Transmission and Driveline
12-15-2022, 12:23 AM
16
M85 3.73 Diff SOLD
2,599
Posted By
jrhudson
I remember you selling this one. Shoot. I want...
I remember you selling this one. Shoot. I want this..but need stop buying car parts. Payday is next wednesday if you still got it, ill likely scoop this up. Been looking for one since your last ad a...
Forum:
Engine, Exhaust, Transmission
07-26-2022, 04:20 PM
234
Direct Injector Seal Installation | Video and Issues
132,123
Posted By
jrhudson
Yup. Well it works fine. Theyre in the motor and...
Yup. Well it works fine. Theyre in the motor and no issues.🤷*♂️ Like over 5k miles already. Also..you can get them checked and cleaned.
Forum:
07-12-2022, 08:25 PM
31
To Rebuild or not, but with no Experience with Engine Rebuilds
4,514
Posted By
jrhudson
i agree 100%. man, you just listing what to do...
i agree 100%. man, you just listing what to do gave me ptsd. cleaning those parts took a while not to mention all other parts on the heads. cam carrier, cam caps, shims, roller rockers, oil spout...
Forum:
07-11-2022, 08:10 PM
31
4,514
Posted By
jrhudson
that short block is trashed. maybe your heads are...
that short block is trashed. maybe your heads are useable wont know until the teardown. i would put that on the back burner after you pull out the motor. id focus on trying to find a good longblock...
Forum:
07-11-2022, 07:53 PM
31
4,514
Posted By
jrhudson
oh yea the vacuum pump. yes the upper oil pan is...
oh yea the vacuum pump. yes the upper oil pan is lil different and the coolant crossover tube/pipe thing on top of the engine has another sensor for the autos. you can buy some plate to cover it.
Forum:
07-11-2022, 05:52 PM
31
4,514
Posted By
jrhudson
i went this route and its really not as simple as...
i went this route and its really not as simple as you making it out to be. I was on the same boat as you. novice "mechanic"(meaning not real mechanic, does it for a hobby on my car), mechanically...
Forum:
07-04-2022, 01:32 AM
15
Trunk button inside car doesnt work
2,933
Posted By
jrhudson
Story time* this was the state of the...
Story time*
this was the state of the interior when i got it. it was so gross, like just trash inside the entire car, old receipts, food, gum, trash in general. I couldn't believe it crazy how...
Forum:
07-04-2022, 12:38 AM
15
2,933
Posted By
jrhudson
okay...so the button wasn't even plugged...
okay...so the button wasn't even plugged in....wtheck. whomever had the car really didnt take care of it. i got it cheap but yea..:bonk:
Forum:
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
06-26-2022, 07:32 PM
37
Transmission rattle in Neutral
7,062
Posted By
jrhudson
Its probably the clutch disc. Pulled the motor...
Its probably the clutch disc. Pulled the motor swapped out jank oem clutch disc and put in the aftermarket south bend. Dropped it in and got the car button up and no rattles. Even with the ac on. So...
Forum:
06-19-2022, 09:57 PM
37
7,062
Posted By
jrhudson
i suspect it might just be the clutch disc...
i suspect it might just be the clutch disc itself. the clutch i have in it is some junk OEM one with over 70k miles, and when received it, it didnt look so great.
i dont recall feeling anything...
Forum:
06-04-2022, 01:27 AM
20
Positive battery terminal damage
2,256
Posted By
jrhudson
it was coming out for a different reason already.
Forum:
06-03-2022, 07:45 PM
20
2,256
Posted By
jrhudson
Thanks! i dont have anything on hand to burns...
Thanks!
i dont have anything on hand to burns that hot. i tried with a propane burner thing and yea didnt get hot enough and this was just so i could move the car :burnrubber: move the car around,...
Forum:
06-03-2022, 02:08 AM
20
2,256
Posted By
jrhudson
I found the whole battery harness for $45 on ebay...
I found the whole battery harness for $45 on ebay so if i need i could just get that.
Forum:
05-25-2022, 04:03 PM
37
7,062
Posted By
jrhudson
The motor and trans were put in together btw...
The motor and trans were put in together btw (mated/bolted the motor and trans outside of car, this is alot easier IMO than only installing the motor to the trans inside the car) dropped in the...
Forum:
04-24-2022, 09:17 PM
16
built motor woes. leaky exhaust valve
1,394
Posted By
jrhudson
They machined and assembled them. Sent it back to...
They machined and assembled them. Sent it back to me and i installed it onto the short block.
Forum:
04-24-2022, 09:16 PM
16
1,394
Posted By
jrhudson
I was under the impression that IAG would do a...
I was under the impression that IAG would do a teardown but from their email it seems they finished it. wasnt the most detailed of emails so i asked if they did a teardown and did vacuum tests on the...
Forum:
04-01-2022, 09:51 PM
15
Building a FA20
4,576
Posted By
jrhudson
As someone that is a novice mechanic that did...
As someone that is a novice mechanic that did most of the work myself it can be done. BUT whats in bold is key...my built engine is sitting garage right now. Ive pulled that thing wayy too many times...
Forum:
02-19-2022, 07:54 PM
11
Boosted motor mounts
1,581
Posted By
jrhudson
I have the STI mounts and i feel like almost no...
I have the STI mounts and i feel like almost no difference but i'm on a built motor with a turbo so might be different.
These are the part numbers for them. i saw bought mine at rallysportdirect...
Forum:
Software Tuning
01-29-2022, 10:11 PM
110
Replacing a Bricked damaged or faulty ECU with new or used ECU FRS BRZ GT 86
72,006
Posted By
jrhudson
Couldn't get my key fob to disable the alarm even...
Couldn't get my key fob to disable the alarm even after the 30 min relearn period. I have a manual frs and accidentally got an auto ECU as the replacement but thanks to steve99 assisting me in...
Forum:
Forced Induction
01-03-2022, 02:19 PM
232
Built engine - GEN-2 GTX3076r
87,934
Posted By
jrhudson
I have, i think it was just a tune issue. Getting...
I have, i think it was just a tune issue. Getting the turbo installed and getting the base tune for it seemed to solve the issues. But im having another issue. Front timing cover is coming off again....
Forum:
12-18-2021, 06:23 PM
8
Noise on deceleration
1,869
Posted By
jrhudson
:iono::iono::iono::iono: Thanks, Ive done...
Thanks, Ive done that many times. Theres no more rattle when im hitting the springs or anywhere now but that annoying rattle noise is still there at the speeds/rpms i...
Forum:
11-27-2021, 02:52 PM
21
Intermittant P0219a and P0119f
3,495
Posted By
jrhudson
i read thru the thread and it does seem you have...
i read thru the thread and it does seem you have some fueling issue. Your AFR looks where it should be but youre getting those codes for misfires and bank 1 afr being off.
i would log cylinder...
Forum:
11-22-2021, 12:36 PM
42
POP while installing crank bolt, now CEL and TCS!
4,266
Posted By
jrhudson
Okay first, DO NOT TURN ON YOUR CAR ANYMORE until...
Okay first, DO NOT TURN ON YOUR CAR ANYMORE until you get it checked out/fixed. If you need to move it, roll it or tow it.
I had a similar issue that ended in catastrophic failure. You may have...
Forum:
11-14-2021, 12:33 PM
75
New motor starts then dies.
15,444
Posted By
jrhudson
Not really sure why i had the issues i had, but...
Not really sure why i had the issues i had, but they've been resolved, I think. Giving an update to give this thread to give it closure, so-to-speak.
Only thing i suspect is, i still had somewhat...
Forum:
09-29-2021, 01:14 AM
75
15,444
Posted By
jrhudson
Welp, woohoo. Then, back in the box. Good thing...
Welp, woohoo. Then, back in the box. Good thing JDL said they’ll do it whenever they get it same day and try to even send it out the same day.
Forum:
09-29-2021, 12:53 AM
75
15,444
Posted By
jrhudson
not sure on that. thanks, i might...
not sure on that.
thanks, i might just follow IAG's recommendations and run it with the turbo kit since they said might be a tuning issue.
I began asking IAG for some assistance/advice....
Page 1 of 3
1
2
3
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
05:52 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
