follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Members List
Calendar
Search
Today's Posts
Mark Forums Read
Search Forums
Search Results
Page 1 of 4
1
2
3
4
Showing results 1 to 30 of 92
Search took
0.02
seconds.
Search:
Posts Made By:
Ace23_BRZ
Forum:
Electronics | Audio | NAV | Infotainment
11-04-2023, 04:57 AM
3
Part Number for Horn Connector
953
Posted By
Ace23_BRZ
For the low-pitched horn assembly, which is a...
For the low-pitched horn assembly, which is a 1-pin connector - 90980–10619
For the high-pitched horn assembly, which is a 2-pin connector - 90980–11235
Forum:
Member's Car Journals
07-03-2023, 05:40 PM
114
Ace23_BRZ's DSport FA225 Boosted Build
36,607
Posted By
Ace23_BRZ
Quick Test Fitment
Still a work in progress, but I just wanted to see how far off the stance is/was prior to any additional adjustments, I.E. suspension upgrades, fender adjustments, etc...
Either way, we'll get her...
Forum:
07-01-2023, 07:24 AM
114
36,607
Posted By
Ace23_BRZ
Rocket Bunny v1 Fender Install
Worked on my front passenger side fender today.
All I did was measure thrice and drilled once!
Came out perfect!
This kit will be molded, which IMO, comes out cleaner!
Regardless, stay...
Forum:
04-08-2023, 06:12 PM
114
36,607
Posted By
Ace23_BRZ
Man Cave!
It's all about the workspace!
Building my mancave bit-by-bit, dollar-by-dollar!
Waiting for my hexagon ceiling lights to arrive 😍
Forum:
03-25-2023, 05:30 PM
114
36,607
Posted By
Ace23_BRZ
Relocation of Fusebox & VDC (ABS) Control Unit
Feeling out where I want to relocate these guys.
Still up in the air, but here are some possible spots
Forum:
03-25-2023, 05:17 PM
114
36,607
Posted By
Ace23_BRZ
Oil Cooler Kit
Working on my oil cooler kit install.
Customizing my vents to produce maximum air flow directly into my oil cooler kit 😎.
Forum:
03-09-2023, 06:52 PM
114
36,607
Posted By
Ace23_BRZ
Front Grill Delete / Carbon Fiber Stache Install
Working on this front grill delete...
Fitting my new carbon fiber bumper guard to match the rest of my CF 😍
Forum:
03-09-2023, 05:43 PM
114
36,607
Posted By
Ace23_BRZ
Haha, then I gotta make room for these guys.... ...
System schematics down below
Forum:
03-09-2023, 05:38 PM
114
36,607
Posted By
Ace23_BRZ
Trying to mess around with some trunk...
Trying to mess around with some trunk configurations...
Forum:
DIY (Do-It-Yourself) Guides
03-09-2023, 05:28 PM
4
Orientation of high frequency horn installation?
834
Posted By
Ace23_BRZ
Glad you were able to find the original OEM...
Glad you were able to find the original OEM locations.
I ditched those guys and got creative with these lol.
Forum:
03-07-2023, 05:07 AM
114
36,607
Posted By
Ace23_BRZ
Driver Door Harness Completed Today
So I finished my driver door harness today
Again, all new tefzel wire, connectors, pin terminals, and loom.
Up next, I still need to install my Focal door speakers, dynamat the door, then seal...
Forum:
03-03-2023, 05:59 PM
114
36,607
Posted By
Ace23_BRZ
3rd Times a Charm LoL
A Thing Of Beauty!
Trust in the process, and it will come together.
Done wiring my driver side harness in absolute stealth mode 🥷
Yes, the second or third time was a charm.
This time...
Forum:
02-27-2023, 10:56 PM
114
36,607
Posted By
Ace23_BRZ
Just know that when I am completely done with...
Just know that when I am completely done with this bad boy, I will build another, however, it will be a full YouTube series, from beginning to end type build .
Also, if I find time, I'll try...
Forum:
02-25-2023, 07:51 PM
114
36,607
Posted By
Ace23_BRZ
LoL, yeah, it's also helpful having my car...
LoL, yeah, it's also helpful having my car stripped down to the frame 😅.
But yeah, it's not that difficult...just plan it out and you should be fine.
Forum:
Cosmetic Modification (Interior/Exterior/Lighting)
02-25-2023, 07:25 PM
5
Part number for window switch connector terminal?
1,641
Posted By
Ace23_BRZ
It's a Furukawa Caselanceless Standard・NS-LC...
It's a Furukawa Caselanceless Standard・NS-LC type, NS16FW-LC, PK415-16017.
Forum:
02-25-2023, 06:20 PM
114
36,607
Posted By
Ace23_BRZ
Courtesy Light OEM Install
Got around to the doors this time around so I decided to install courtesy lights, however, the correct/OEM way.
While I was at it, of course I ditched the ugly ass OEM harness and made my own.
Forum:
02-07-2023, 07:12 AM
114
36,607
Posted By
Ace23_BRZ
Made My Own SRS Delete Kit
After seeing the SRS delete kits out there, I decided to make my own.
I didn't feel too confident in the DIY kits I've seen, especially the ones that just shove the resistor in and tape it down.
Forum:
01-26-2023, 06:07 AM
114
36,607
Posted By
Ace23_BRZ
Yeah, still in the works with that...I have...
Yeah, still in the works with that...I have rubber grommets for that hole, however, I think I'm going to redo the harness with an autosport/mil spec quick disconnect harness at those points.
If...
Forum:
BRZ First-Gen (2012+) -- General Topics
01-21-2023, 05:20 PM
19,877
WHAT DID YOU DO TO YOUR BRZ TODAY?
8,796,892
Posted By
Ace23_BRZ
Unfortunately, I cannot tell you. My car is...
Unfortunately, I cannot tell you. My car is completely stripped down to the frame pretty much.
I'm still in the process of rewiring the entire car in tefzel wire, mil spec connectors, etc.
Forum:
01-20-2023, 03:02 AM
114
36,607
Posted By
Ace23_BRZ
Brake Booster Delete Kit 'Installed'
Took a break from the wiring today to install this guy...
Forum:
01-20-2023, 01:24 AM
19,877
8,796,892
Posted By
Ace23_BRZ
Brake booster delete... Installed my...
Installed my Chasebays dual piston brake booster delete kit today..."finally," 🤦
Got so caught up with this wiring project that everything else got the shaft.
God, I...
Forum:
01-12-2023, 12:03 AM
5
Anyone Wire Tucks Out There? If so, let's see em!
1,061
Posted By
Ace23_BRZ
Agreed! This company did a great job with this...
Agreed! This company did a great job with this build.
Hopefully, I too can inspire others with my individual build once she is revealed.
I will say though, I think I might be going a little too...
Forum:
01-01-2023, 12:31 PM
114
36,607
Posted By
Ace23_BRZ
Passenger Side Front Harness
So I finally got around to working on my front passenger side headlight harness.
Forum:
12-09-2022, 03:58 PM
19,877
8,796,892
Posted By
Ace23_BRZ
Re did the previous tuck...this time my OCD...
Re did the previous tuck...this time my OCD approves!
Forum:
12-09-2022, 03:25 PM
114
36,607
Posted By
Ace23_BRZ
Don't Mind Sharing
Hey guys...here's my finished driver side harness 'exterior' .and ah, I don't mind sharing the tricks of the trade.
I remember back when everyone was so secretive of their tucks...the way I see...
Forum:
12-08-2022, 02:37 AM
114
36,607
Posted By
Ace23_BRZ
LoL, well, when you're trying for SEMA, gotta aim...
LoL, well, when you're trying for SEMA, gotta aim for the stars 🌟 🤩 ✨️
Forum:
12-04-2022, 01:08 PM
19,877
8,796,892
Posted By
Ace23_BRZ
Yezur, wire tuck, shaved bay, etc.
Forum:
12-04-2022, 07:16 AM
114
36,607
Posted By
Ace23_BRZ
Headlights
Decided to start working on the front of the car now.
Gonna start the wire tucking process.
I started with my OEM headlight wiring and will loom in my Circuit Demon Morimoto headlights as...
Forum:
12-04-2022, 06:59 AM
19,877
8,796,892
Posted By
Ace23_BRZ
Ace's 2013 Subaru BRZ Build
Got around to wiring my driver side headlight harness along with installing my Chasebay's windshield reservoir as well.
LoL, I was going to tuck my VDC control module there, but my ChaseBay's...
Forum:
11-26-2022, 11:22 PM
37
Dream BRZ Build..Suggestions
4,004
Posted By
Ace23_BRZ
LMAO...I noticed that everyone else is keeping...
LMAO...I noticed that everyone else is keeping this thread alive!
Either way, that guy's budget plan is way south of his target goals...sadly, I can speak from personal knowledge because I am on a...
Page 1 of 4
1
2
3
4
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine, Exhaust, Transmission
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
01:38 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
