follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 2
1
2
Showing results 1 to 30 of 44
Search took
0.36
seconds.
Search:
Posts Made By:
Joeyb860
Forum:
Forced Induction
03-24-2018, 07:01 PM
9,139
Innovate (Sprintex) Supercharger Owners Topic
2,809,822
Posted By
NIKOLA
Just curious..... I haven't done a zero to 60 run...
Just curious..... I haven't done a zero to 60 run yet since my area is so full of cops hiding around every corner. However, I was wondering what kind of zero to 60 times has any one gotten after...
Forum:
Forced Induction
03-13-2018, 09:34 AM
17
Sprintex Survey/Feedback Re Heat Soak
5,196
Posted By
sam69
Mmmm striped the engine and found not 1 or 2 bent...
Mmmm striped the engine and found not 1 or 2 bent rods which was my guess before I pulled it apart but 4 yes 4 bent rods:eyebulge:
Will never run one of these things without a catch can again went...
Forum:
Forced Induction
02-28-2018, 01:52 PM
9,139
2,809,822
Posted By
continuecrushing
hmm, I'll just leave this here... ...
Supercharged FRS With UEL Header Revving - YouTube
Forum:
Forced Induction
02-25-2018, 10:11 AM
9,139
2,809,822
Posted By
PitViper
Core temps and intake temps were what I was...
Core temps and intake temps were what I was referring to. And it will get toasty without an intercooler. Results are variant based off of pulley size. Larger pulley, less heat.
Also, if you run...
Forum:
Forced Induction
02-25-2018, 05:39 AM
9,139
2,809,822
Posted By
86 South Africa
I can’t compare to the stock pulley cos I never...
I can’t compare to the stock pulley cos I never had it, but I’ve got the SPS kit with the smaller 69mm pulley and it’s an awesome upgrade for me. Plenty of additional mid range and I don’t feel any...
Forum:
Forced Induction
02-25-2018, 01:33 AM
9,139
2,809,822
Posted By
Hill
Thanks for sharing. Are you intercooled as well?...
Thanks for sharing. Are you intercooled as well? Also, did you ever run just water injection?
Forum:
Forced Induction
02-10-2018, 07:53 AM
9,139
2,809,822
Posted By
Kodename47
Yes it helps and also helps add a little extra...
Yes it helps and also helps add a little extra boost pressure. Rich196 ran a WMI kit on his Sprintex before swapping for a Cossie blower.
Forum:
Forced Induction
02-07-2018, 09:07 PM
9,139
2,809,822
Posted By
ajcarson11
Sounds like the common issue with the MAP sensor....
Sounds like the common issue with the MAP sensor. On the intercooled kit you have to run the stock one... or something like that otherwise you end up without much top end power on the intercooled...
Forum:
Forced Induction
02-05-2018, 04:54 PM
9,139
2,809,822
Posted By
riboyster
I've run my supercharger with no oil for the last...
I've run my supercharger with no oil for the last year. There was a drop on the sight glass that threw me. It handles just fine but you do lose performance.
Needless to say, I have replaced the oil...
Forum:
Forced Induction
02-04-2018, 11:53 PM
9,139
2,809,822
Posted By
sroby
Joey glad you got it squared away. Keep a chk...
Joey glad you got it squared away. Keep a chk on your oil level in the charger at least once every 7 days. Don’t forget to chk the level with the car raised in the rear to get an actual good...
Forum:
Forced Induction
02-04-2018, 05:56 PM
9,139
2,809,822
Posted By
riboyster
Any codes? If it doesn't start now, and you...
Any codes?
If it doesn't start now, and you were messing with your coils then that is probably the problem. Maybe you did something wrong and blew the ignition fuse.
Forum:
Forced Induction
01-15-2018, 11:40 PM
1,935
AVO Turbo Kit Owners Topic
689,630
Posted By
tyler_win_photo
It was nice meeting you at 86 Sessions yesterday....
It was nice meeting you at 86 Sessions yesterday. Can't wait to see your turbo build come to life :cheers:
Forum:
Forced Induction
01-13-2018, 07:07 PM
4,960
Edelbrock E-force Owner's thread and FAQs (Frequently Asked Questions)
1,474,171
Posted By
Barefootdan
Nope, it doesn’t fit due to the alternator and...
Nope, it doesn’t fit due to the alternator and ecu bracket. If they made it fit then they had to either replace the alternator with a 13-16 model or redo the connector. The ecu bracket just needs a...
Forum:
Forced Induction
01-13-2018, 06:35 PM
4,960
1,474,171
Posted By
Teseo
Maybe it fit cuz kit replace the intake?
Forum:
Forced Induction
01-09-2018, 04:00 PM
188
Want to turbo my BRZ...Ideas?
30,544
Posted By
CSG Mike
GReddy + Delicious Tuning FF kit + Tune. PM...
PM me if you want to replicate any part of my setup. I make that power on a *stock* clutch.
Forum:
Forced Induction
01-03-2018, 12:08 AM
1,935
689,630
Posted By
tyler_win_photo
Technically the 1.5 is the stage 2. Difference...
Technically the 1.5 is the stage 2. Difference between stage 2 and 1 is that stage 2 has a catch can, overpipe, and front pipe as well as different wastegate spring. If you get an electronic boost...
Forum:
Forced Induction
12-30-2017, 07:33 PM
1,935
689,630
Posted By
tyler_win_photo
Kit has option of catted or catless.
Forum:
Forced Induction
12-30-2017, 07:32 PM
1,935
689,630
Posted By
tyler_win_photo
Contact them as prices may have changed. They had...
Contact them as prices may have changed. They had me at $1500 install, $775 for ecutek + dyno tuning.
Forum:
Forced Induction
12-27-2017, 08:33 AM
1,935
689,630
Posted By
Grady
I got the new stage 1. Catch can, MAP sensor, air...
I got the new stage 1. Catch can, MAP sensor, air filter, ect included. I do not beleive they make the striped down kit anymore. $4900. For the new stage 1 kit. If the one you are looking at is the...
Forum:
Forced Induction
12-27-2017, 02:17 AM
1,935
689,630
Posted By
tyler_win_photo
Noticed you were in the area. Should try hitting...
Noticed you were in the area. Should try hitting up Drift Office in Auburn, WA; it's the go to shop for tuning 86's in our area. They can do install and dyno tuning for you.
And the $4400 you're...
Forum:
Software Tuning
12-22-2017, 07:20 PM
579
OpenFlash Tablet: OTS v3.0 tune files ready for beta testing
141,286
Posted By
FRSBRZGT86FAN
You'd have to email...
You'd have to email openflash:sales@openflashperformance.com
http://www.openflashtablet.com/contact/
I asked about that awhile back (almost a year ago) and he said although they have tunes from...
Forum:
Forced Induction
12-22-2017, 09:16 AM
1,935
689,630
Posted By
ShibusaTouge
You'd want wider tires/wheels, per say, not just...
You'd want wider tires/wheels, per say, not just "bigger". You'd want stickier tires too. It's different for everyone, but if you're set on getting new wheels/tires, I'd get 17x9s with 245/40/17s
Forum:
Engine, Exhaust, Transmission
12-11-2017, 03:01 AM
17
Interesting findings with exhaust mods and tuning
2,872
Posted By
NRXRaptor
I'd just email Shiv on the OFT website. I had...
I'd just email Shiv on the OFT website. I had questions about my setup and he answered them. He'd know better than anyone on here
Forum:
Software Tuning
12-09-2017, 04:11 PM
579
141,286
Posted By
steve99
P2096 is a code that indicates the ecu THINKS you...
P2096 is a code that indicates the ecu THINKS you car is running too lean.
P0420 is the code disavled for catless header related to cat performance.
P2096 indicates you have a real problem, if...
Forum:
Scion FR-S / Toyota 86 GT86 General Forum
12-05-2017, 07:27 PM
153
Sticky:
New Member & have question? Read here first!
129,435
Posted By
Hey ....... just hold up here ....... this...
Hey ....... just hold up here ....... this section is for "new members who have a question"!
NOW, new members who come here will think ol humfrz can't drive a car worth a damn and has to take it...
Forum:
12-05-2017, 04:42 PM
153
Sticky:
129,435
Posted By
He still needs to stop backing into posts at 100...
He still needs to stop backing into posts at 100 or so mph. My lawyer is still working on my whiplash claim.
Forum:
12-05-2017, 02:40 AM
153
Sticky:
129,435
Posted By
Ah....ha..... good eye!........:thanks: I'll...
I'll let you know what ails it when I find out tomorrow.....:thumbsup:
Forum:
12-05-2017, 12:15 AM
153
Sticky:
129,435
Posted By
Nah, not at all. Joke flopped. Won't be my...
Nah, not at all. Joke flopped. Won't be my last. :cheers:
Wish I had more to offer regarding tuning but I'm just getting my own feet wet.
Forum:
12-03-2017, 11:04 PM
153
Sticky:
129,435
Posted By
Let's not forget what @bcj...
Let's not forget what @bcj (http://www.ft86club.com/forums/member.php?u=35696) said about the stock tune being thrown out of whack. He has an excellent point. Even a canned tune will help, so your...
Forum:
12-03-2017, 10:55 PM
153
Sticky:
129,435
Posted By
Well now, Joeyb860, ol Ultramaroon was .... jest...
Well now, Joeyb860, ol Ultramaroon was .... jest ah messen wich ya ..... to a large degree. He is one of the "good guys" here on the forum.
I feel badly that I thought that you might be a...
Page 1 of 2
1
2
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
04:26 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
