follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Members List
Calendar
Search
Today's Posts
Mark Forums Read
Search Forums
Search Results
Page 1 of 17
1
2
3
4
5
11
Last
Showing results 1 to 30 of 500
Search took
3.35
seconds.
Search:
Posts Made By:
kevaughan
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
04-13-2024, 12:59 AM
260
MCA Suspension "Traction Mod"
85,011
Posted By
RToyo86
Fast shipping! Mine arrived today, they're very...
Fast shipping!
Mine arrived today, they're very generous with their swag too! 8 stickers and a jet tag. Thanks McA!
Now just waiting on trailing arm to install everything together.
Forum:
04-05-2024, 10:10 AM
260
85,011
Posted By
Racecomp Engineering
I've made it a practice to order new bolts/nuts...
I've made it a practice to order new bolts/nuts for pretty much every install to just make life easier especially with crusty subframe pieces. Sometimes I even remember to use them!
For the...
Forum:
Engine, Exhaust, Transmission
02-21-2024, 06:26 PM
11
CAE Shifter for Gen-1 + Gen-2 GR86
816
Posted By
ZC6_STi
Will do! Unfortunately, after researching on the...
Will do! Unfortunately, after researching on the Gen 2 market. You need to cut into your console for fitment. This was posted on the CAE website. I believe on another forum for the Gen 2 platform, a...
Forum:
02-21-2024, 05:16 PM
11
816
Posted By
ZC6_STi
Just received mine straight from CAE a couple of...
Just received mine straight from CAE a couple of days ago with the aluminum shifter and blue shift knob. Took 4-5 days to deliver after placing my order. Total cost: $917.39. It would been over $1k+...
Forum:
02-19-2024, 09:24 AM
260
85,011
Posted By
DocWalt
Another alternative version:...
Another alternative version: https://outboundmotorsports.com/products/gr86-brz-anti-squat-bumpsteer-correction-mount
Forum:
Engine Swaps
02-09-2024, 08:55 PM
273
Likely the first FA2/4 hybrid incoming
68,559
Posted By
Opie
For a 2013 - 2016 car, yes.
Forum:
02-08-2024, 06:48 PM
11
816
Posted By
RedReplicant
AAF is bringing their shifter to our chassis too,...
AAF is bringing their shifter to our chassis too, it'll be out soon.
https://advancedautofab.com/p/aaf-bmw-race-shifter-with-adjustable-shift-shaft/
https://i.imgur.com/ErBqmKo.png
Forum:
01-26-2024, 02:48 AM
783
FA20 Engine Oiling, Bearings, and Starvation
356,873
Posted By
Eaton PSI
Pickup, brace, baffles and spacer installed.
Forum:
01-20-2024, 01:01 AM
783
356,873
Posted By
Eaton PSI
sump spacer and mesh screen
10mm thick sump spacer and new mesh screen in pickup. Mesh is the same pitch as OEM, but much larger area. The spacer has tabs on it that I will probably use to add a brace to the pickup. Vibrating...
Forum:
01-17-2024, 02:49 PM
260
85,011
Posted By
DocWalt
I realized I never chimed in here with my...
I realized I never chimed in here with my experience on the GPSports version of this.
No changes in ride height, but 9kg/mm rear springs over here.
I posted initital impressions...
Forum:
01-14-2024, 05:26 AM
783
356,873
Posted By
Eaton PSI
Billet pickup
Change of plan. Billet pickup with 22mm ID tube and a removable/replaceable mesh screen. Tube is longer and aimed at the middle of the sump.
Next to make is a 10mm thick spacer between sump and...
Forum:
Member's Car Journals
10-31-2023, 08:50 AM
99
DocWalt's 2022 WRB BRZ
12,787
Posted By
DocWalt
Installed the GP Sports "rear traction member...
Installed the GP Sports "rear traction member collar" aka the "traction mod" that reduces the rear anti-squat for a more compliant suspension and better ability to put power down. Initial testing on...
Forum:
10-27-2023, 11:36 PM
55
Weir Performance 5.29 Final Drive Video
30,135
Posted By
Mykii
Ooh snap. So I went 5.29 from Weir on my car....
Ooh snap. So I went 5.29 from Weir on my car. It’s pretty fun and goofy. Can’t actually tell if my car is faster or slower, but it feels more fun in the sense that it makes you sink into the seat...
Forum:
Forced Induction
09-25-2023, 01:15 PM
14
TRD Supercharger Build
2,372
Posted By
Bergycheese348
Hello everyone.
I was really intrigued when I discovered the TRD Supercharger while sitting in a high school class two years ago, and now I can say I am the proud owner of one (of the extremely...
Forum:
06-13-2023, 10:54 PM
12
Bilstein B14 questions
7,025
Posted By
Muffled
I've had B14s on for about a year now. Mine came...
I've had B14s on for about a year now. Mine came out of the box set to the lowest height Bilstein recommends (they're threaded to allow you to go lower than this, if you choose to use them with...
Forum:
06-13-2023, 10:28 PM
260
85,011
Posted By
whataboutbob
First autox in 5 years. Changes since last...
Changes since last autox:
MCA traction mod.
Stock powertrain with no tune.
5 year old "new" RC-1s.
New Karcepts front bar on 2nd from softest.
New-ish Essex BBK...
Forum:
06-12-2023, 09:10 AM
12
7,025
Posted By
spcmafia
Update. I've had the B14s on, now fully aligned,...
Update. I've had the B14s on, now fully aligned, and for about 500+ Miles.
The good:
-Excellent ride height using minimal settings set by Bilstein.
-No popping, which is a feedback I saw...
Forum:
06-01-2023, 06:13 PM
7
Shifter bushings
1,255
Posted By
wheelhaus
I tried these recently during a clutch job on my...
I tried these recently during a clutch job on my '13, and there was minimal difference vs OEM, I ended up putting OEM back in because these somehow felt a little harsh. These particular bushings are...
Forum:
06-01-2023, 12:53 PM
7
Shifter bushings
1,255
Posted By
Thefalls
TRD all the engine mounts and use Mtech or Cusco...
TRD all the engine mounts and use Mtech or Cusco shifter springs and you are sorted.
Everything will tight without the added NVH. It just feels firm and comfortable for a daily drive.
Add the...
Forum:
05-31-2023, 11:35 AM
7
Shifter bushings
1,255
Posted By
RToyo86
There is an increase in gear whine with the front...
There is an increase in gear whine with the front bushings carried through the shifter area. With the OEM shifter it's significantly reduced compared to an aftermarket shifter which has a much...
Forum:
05-31-2023, 11:25 AM
7
Shifter bushings
1,255
Posted By
spcmafia
I just had PTSD looking at those things. It was a...
I just had PTSD looking at those things. It was a major PITA when I was putting the transmission back on after the TOB install. Those pins would not go back in, pretty sure I bent the locking tab on...
Forum:
05-31-2023, 09:51 AM
7
Shifter bushings
1,255
Posted By
PulsarBeeerz
I second the front carrier bushings on the...
I second the front carrier bushings on the transmission, the shift action is perfectly tight with no rattling. Along with a poly rear shifter mount the action was even better, but the NVH was too...
Forum:
05-31-2023, 08:05 AM
7
Shifter bushings
1,255
Posted By
RToyo86
There is a good DIY thread Here...
There is a good DIY thread Here (https://www.ft86club.com/forums/showthread.php?t=117270) to install the front carrier bushings.
I did the Cusco fronts and torque solutions rear. Cusco requires...
Forum:
05-07-2023, 09:37 PM
260
85,011
Posted By
NoHaveMSG
Unfortunately our parts bin car has too much anti...
Unfortunately our parts bin car has too much anti squat since our rear suspension is basically from the Impreza . That’s what this solves and nobody that has run it has ever said it did not improve...
Forum:
Tracking / Autocross / HPDE / Drifting
04-19-2023, 11:23 AM
50
Individual Racing Parts (IRP) V3 Short Shifter Rattle Thread
22,161
Posted By
NoHaveMSG
I took video of this a while back wondering if it...
I took video of this a while back wondering if it was contributing.
https://www.youtube.com/shorts/5ZN0nQEFmlc
Forum:
GR86 General Topics (2nd Gen 2022+ Toyota 86)
02-14-2023, 09:05 AM
121
Oil pressure drops on race track in S corners
23,686
Posted By
KillerBMotorsport
No it does not. The baffle is installed with the...
No it does not. The baffle is installed with the pan removed.
Forum:
02-12-2023, 06:20 PM
121
23,686
Posted By
KillerBMotorsport
IMO, braking followed by a right-hand turn is...
IMO, braking followed by a right-hand turn is causing sloshing into the timing cover and into the left had side of the timing cover, where there are no drains. As the car straightens out, oil can...
Forum:
02-06-2023, 08:55 PM
420
Sticky:
Track Brake Pad Discussion Thread
228,501
Posted By
Lynxis
Brake Pad Manufacturer (F/R): Carbotech Caliper...
Caliper (F/R): OEM F/R
Rotor Size (F/R - IE OEM or specify): OEM F/R
Compound (F/R): XP10 F/R
Tires: Falken RT660 245/40r17
Feedback:
For reference,...
Forum:
01-24-2023, 09:15 PM
121
23,686
Posted By
nissanfanatic
Graph'd this data to visualize it: ...
https://i.imgur.com/3UDz4x9.png
Forum:
01-24-2023, 03:34 PM
121
23,686
Posted By
Dzmitry
You had spoken about this briefly before with...
You had spoken about this briefly before with some good insight on why we may see oil pressure drop at high RPM. You are newer to the platform as I recall, so you may not exactly be aware of the...
Page 1 of 17
1
2
3
4
5
11
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
07:35 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
