follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 3
1
2
3
Showing results 1 to 30 of 64
Search took
0.02
seconds.
Search:
Posts Made By:
BRX
Forum:
Engine, Exhaust, Transmission
07-24-2023, 02:15 AM
6
Any interest in a T56 swap?
1,001
Posted By
BRX
From my limited experience with T56 swaps, I...
From my limited experience with T56 swaps, I wouldn't recommend it to be mated with an FA20.
1. Gearing, way too tall for a low torque/high rpm engine like the FA20. You can mix and match to get...
Forum:
Engine Swaps
05-11-2023, 05:57 AM
1,305
Another V8 Swap
321,220
Posted By
BRX
I know this might be a bit late, but why not go...
I know this might be a bit late, but why not go with a ZF 8HP? There are many sitting behind a 2JZ and at least one in a BRZ. You can even install a clutch pedal and drive it like a manual.
I'm...
Forum:
Engine Swaps
07-23-2021, 12:49 PM
78
3UR-FE Swap
45,337
Posted By
BRX
Thanks brother! You just made me want to update...
Thanks brother! You just made me want to update this thread, a lot has been done to the car since my last update and I've got time to spare so here we go :)
I'll try to keep this in chronological...
Forum:
Issues | Warranty | Recalls / TSB
10-22-2019, 01:22 AM
6
C1237 - Speed Sensor Rotor Faulty
5,088
Posted By
BRX
geraldjust made it for me Thanks, I'll...
Thanks, I'll try this if nothing works.
Well we found the front mount of the lower arm to be cracked on both sides. Just welded those up with a thick metal...
Forum:
Engine Swaps
03-05-2019, 12:21 AM
165
CAN BUS - for DIY swappers, HELP! Engineers / shops welcome
113,415
Posted By
BRX
One guy on Facebook tried to swap a 2AZ-FE using...
One guy on Facebook tried to swap a 2AZ-FE using this method. He actually made it quite far and it started for a second or two before stalling. Eventually he went with the stock 2AZ ECU + an AEM ECU...
Forum:
Engine Swaps
03-04-2019, 03:51 PM
78
3UR-FE Swap
45,337
Posted By
BRX
This is actually the third attempt lol. Looks...
This is actually the third attempt lol. Looks better from this angle.https://uploads.tapatalk-cdn.com/20190304/5e06607061b1933481aabb9604a11921.jpg
Sent from my Pixel 2 XL using Tapatalk
Forum:
Engine Swaps
03-04-2019, 12:09 PM
78
3UR-FE Swap
45,337
Posted By
BRX
I got the hood done and the latest CAN translator...
I got the hood done and the latest CAN translator makes the dash work like factory. Only thing missing or not working properly is the cruise control. The twin disk clutch is a bitch to daily so I...
Forum:
Other Vehicles & General Automotive Discussions
07-30-2018, 01:14 PM
4,232
Poll:
Official: Toyota FT-1 Concept / First New Supra Prototype Spotted!
1,045,926
Posted By
BRX
That's what I would have guessed a month ago or...
That's what I would have guessed a month ago or so. But from the info "A70" from the MKV forum has provided, it is highly likely that link's speculation will be true. He works at Toyota and pretty...
Forum:
07-30-2018, 01:02 PM
4,232
Poll:
1,045,926
Posted By
BRX
https://www.supramkv.com/threads/mkv-supra-faq-rea...
https://www.supramkv.com/threads/mkv-supra-faq-read-this-before-asking-questions.1341/
I stand corrected, it has not been confirmed but probably very likely.
Sent from my Pixel 2 XL using...
Forum:
07-30-2018, 12:55 PM
4,232
Poll:
1,045,926
Posted By
BRX
Even if it was identical to a B58, it has been...
Even if it was identical to a B58, it has been confirmed to have an iron/CGI block. So no, it's not off shelf.
Forum:
Engine Swaps
06-13-2018, 07:50 AM
78
3UR-FE Swap
45,337
Posted By
BRX
Thanks. Engine and all of the required parts...
Thanks. Engine and all of the required parts along with it was about $7k. This includes the whole engine assembly, harness, ECU, throttle body/pedal, sensors, etc.
I would say the labor and...
Forum:
Engine Swaps
06-05-2018, 03:24 AM
25
Cooling Bigger Engines
5,035
Posted By
BRX
Had a lot of testing and troubleshooting done the...
Had a lot of testing and troubleshooting done the past two weeks once I got the twin disk installed and finally no more overheating!
The issue was how over complicated the routing of the coolant...
Forum:
Engine Swaps
05-10-2018, 01:01 AM
78
3UR-FE Swap
45,337
Posted By
BRX
Just recently started doing a minor make over. ...
I was going to custom make a new intake manifold for proper hood fitment but then decided to modify the stock resin/plastic one. Will post the final...
Forum:
Engine Swaps
04-23-2018, 04:42 AM
25
5,035
Posted By
BRX
Would this work? I can feel the heat on the...
Would this work? I can feel the heat on the windshield driving 50 mph... lol
Water spray is not a bad idea either. A friend has it setup to spray water on the radiator same time his water/meth...
Forum:
Engine Swaps
04-23-2018, 12:14 AM
25
5,035
Posted By
BRX
I'm looking at an OBD2 scanner and temps would...
I'm looking at an OBD2 scanner and temps would keep rising while driving and cool down when I let off the throttle.
I will run a cooler thermostat, might make a difference since it is a smaller...
Forum:
Engine Swaps
04-13-2018, 12:18 PM
1,305
Another V8 Swap
321,220
Posted By
BRX
I have another OEM regulator on the fuel rails....
I have another OEM regulator on the fuel rails. Does its job even with the other regulator in the tank.
Forum:
Engine Swaps
04-13-2018, 12:06 PM
1,305
Another V8 Swap
321,220
Posted By
BRX
That's almost exactly what I'm running but I...
That's almost exactly what I'm running but I removed the VitViper FPR. Try going back to the stock FPR and see how it goes. I think the Venturi system doesn't perform as well with a blank FPR.
Forum:
Forced Induction
03-08-2018, 11:47 AM
124
Greddy/Trust T518Z Turbo Kit Owners
95,358
Posted By
BRX
To put it simply, yes. There are a few things you...
To put it simply, yes. There are a few things you can do to make it work.
A lower temp thermostat (not mishimoto).
Remove the lower engine cover (if you do, remove the one behind it too) or get...
Forum:
Forced Induction
03-04-2018, 02:04 AM
124
95,358
Posted By
BRX
I got it installed for about $800. $2500 is...
I got it installed for about $800. $2500 is asking way too much even if it includes a tune.
Forum:
Engine Swaps
02-27-2018, 10:42 AM
78
3UR-FE Swap
45,337
Posted By
BRX
Because I can't delete it without fabricating a...
Because I can't delete it without fabricating a pulley bracket to replace it. I will in the future. Here is the belt routing diagram to have an idea. It's labeled vane pump.
Forum:
Engine Swaps
02-27-2018, 05:21 AM
78
3UR-FE Swap
45,337
Posted By
BRX
Been awhile guys. We've been having issues with...
Been awhile guys. We've been having issues with the power steering pump going out and cutting belts. First time it broke in less than 5 miles because of no oil going through it (stupid I know lol)....
Forum:
02-19-2018, 12:09 PM
4,232
Poll:
1,045,926
Posted By
BRX
It identifies itself as exciting, nothing you can...
It identifies itself as exciting, nothing you can do about it.
Forum:
Engine Swaps
02-18-2018, 10:51 PM
1,305
Another V8 Swap
321,220
Posted By
BRX
"Little bit of work before I went over to help a...
"Little bit of work before I went over to help a friend get his engine out.
His engine is a little worst for wear:]
The other rod in the picture is missing."
Forum:
02-14-2018, 02:35 PM
4,232
Poll:
1,045,926
Posted By
BRX
I always read the comments on these articles for...
I always read the comments on these articles for a good laugh.
Forum:
Engine Swaps
02-11-2018, 12:29 PM
78
3UR-FE Swap
45,337
Posted By
BRX
The hood is installed and I'm really not feeling...
The hood is installed and I'm really not feeling it lol. I guess I'll live with it until I'm about to install the Supercharger then I'll figure out how to make the throttle body and intake pipe sit...
Forum:
Engine Swaps
02-07-2018, 10:21 AM
78
3UR-FE Swap
45,337
Posted By
BRX
Just did a bit of googling and it seems that the...
Just did a bit of googling and it seems that the green piece I removed (I guess it's called a jet pump?) Is used to suck the fuel from the other side. I'll probably throw the stock fuel pump in the...
Forum:
Engine Swaps
02-07-2018, 10:05 AM
78
3UR-FE Swap
45,337
Posted By
BRX
So I deleted the fuel pump assembly all together....
So I deleted the fuel pump assembly all together. The fuel pump sounds like it's flowing more easier than before. It used to sound like it was gurgling even before when I was running the turbo kit....
Forum:
Engine Swaps
02-06-2018, 01:59 AM
78
3UR-FE Swap
45,337
Posted By
BRX
Hood is almost ready to be primed. I'm leaning...
Hood is almost ready to be primed. I'm leaning more and more to painting it black. White just shows too much unwanted details lol.
Forum:
Engine Swaps
02-04-2018, 05:01 AM
7
V8 plug and play ECU
3,616
Posted By
BRX
Contact Gerald: http://www.geraldjustprojects.com...
He made my CAN BUS translator for my 3UR swap. Great guy and very responsive. I don't think the 1UZ had CAN BUS so it should be much easier for...
Forum:
01-24-2018, 01:20 PM
4,232
Poll:
1,045,926
Posted By
BRX
It looks like it is a 2+2 seater in that picture....
It looks like it is a 2+2 seater in that picture. Not sure why everyone is assuming otherwise...
Page 1 of 3
1
2
3
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
02:38 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
