follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 3
1
2
3
Showing results 1 to 30 of 65
Search took
0.25
seconds.
Search:
Posts Made By:
Hags86
Forum:
Forced Induction
05-21-2019, 03:00 AM
10
Who Uses Oil Scavenging Pump for Turbo Drain
4,077
Posted By
Hags86
I found the TurboWerx is overpriced and poor...
I found the TurboWerx is overpriced and poor quality. Failed after about three months and left me stranded on the highway (blowing huge plumes of smoke as the oil leaked past the seal into the...
Forum:
Forced Induction
05-01-2019, 01:13 AM
51
Lower compression effects
13,604
Posted By
Hags86
Stay with 12.5:1 because - smaller turbo for...
- smaller turbo for same power
- smaller turbo spools faster
- you get a high compression NA engine at the low rpm range rather than a low compression NA engine...
Forum:
Forced Induction
04-02-2019, 04:42 AM
5
AIT relocation - Bias resistor values - HKS SC - ECUTEK
1,466
Posted By
Hags86
Scratch that. Saw your photo of the wiring from...
Scratch that. Saw your photo of the wiring from the MAF sensor. Makes sense.
I'd be willing to bet its 1kOhm. Turn it on with the engine at room temp and that is a good sanity check.
But to...
Forum:
AUSTRALIA
03-23-2019, 03:56 PM
44
JO2 RECALL - ENGINE FAILURE
12,886
Posted By
Hags86
So I had a failure years ago (Direct Injector...
So I had a failure years ago (Direct Injector Seal) which was due to an early ECU ignition map error - since fixed with a software update.
Read about it here...
Forum:
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
08-11-2018, 09:31 PM
10
Throttle Position Sensor [Suspected Faulty]
6,750
Posted By
Hags86
So, I installed a new accelerator pedal and the...
So, I installed a new accelerator pedal and the problem remains.
The logs show the Main position voltage OK but the Tracking (safety) one drifting up. I've repinned this to a spare analogue...
Forum:
08-11-2018, 03:29 AM
9
Diagram to show all suspension/chassis bolts
1,619
Posted By
Hags86
I have a buddy that works in a few pit crews on...
I have a buddy that works in a few pit crews on endurance race cars. You just put a spanner (wrench) on everything and make sure it's tight. Don't need torque specs. It's either still a tight as...
Forum:
08-07-2018, 01:23 PM
10
6,750
Posted By
Hags86
So I spoke to MoTec to see if it might be a...
So I spoke to MoTec to see if it might be a hardware fault of the ECU (reading the wrong voltage on the sensor).
Turns out a failed accelerator pedal is a known fault and they've replaced lots of...
Forum:
Forced Induction
07-28-2018, 04:45 PM
4
Exhaust Manifold Absolute Pressure Sensor (EMAP)
1,173
Posted By
Hags86
I have 1x EGT measured directly before the turbo...
I have 1x EGT measured directly before the turbo I use as a safety for the anti-lag. "Collector' exhaust gas temp is not particularly useful in tuning though as it is an average across the 4...
Forum:
Forced Induction
07-27-2018, 07:50 PM
78
NA Motor Can Handle 350 Crank HP?
14,891
Posted By
Hags86
Yep. Oil cooler, brake pads (maybe a front brake...
Yep. Oil cooler, brake pads (maybe a front brake kit) some semi-slicks and suspension. I had heaps of track time in that configuration, had lots of fun and really improved as a driver. Now I'm...
Forum:
Forced Induction
07-27-2018, 06:34 PM
78
14,891
Posted By
Hags86
I bought a brand new block from Outfront...
I bought a brand new block from Outfront Motorsports with a closed deck. Didn't even have a serial number stamped on it. I asked my engine builder to just stamp on the same number as my old block.
Forum:
Forced Induction
07-26-2018, 06:42 AM
78
14,891
Posted By
Hags86
Very restrained of you :)
Forum:
Engine, Exhaust, Transmission
07-26-2018, 05:45 AM
19
Installing Rods/Pistons, etc Is it Worth It?
3,457
Posted By
Hags86
I don't see why you couldn't do the assembly if...
I don't see why you couldn't do the assembly if you want to learn and are willing to buy a few tools such as torque wrench, micrometers etc. Check out HP Academy. Their course are OK and they have a...
Forum:
Forced Induction
07-24-2018, 11:23 PM
78
14,891
Posted By
Hags86
In my view the answer is no, not reliably. Bent...
In my view the answer is no, not reliably. Bent all 4 rods at 240 rwkw (320whp) after 7,000km.
It's a sh*!load of fun to drive though.
Forum:
Forced Induction
07-23-2018, 04:40 PM
23
Lightweight vs OEM flywheel for FI
21,188
Posted By
Hags86
I have a Holinger sequential gearbox and Motec...
I have a Holinger sequential gearbox and Motec ECU on my daily driver. Talking with the guys at Holinger, when they were developing the gearbox with the same ECU they couldn't get the throttle blip...
Forum:
Forced Induction
07-19-2018, 07:07 AM
30
Hesitation/Misfire under boost
10,684
Posted By
Hags86
The engine had about 7,000km running after the...
The engine had about 7,000km running after the turbo install with no issues.
Then one day the AFR would be fine for a while and then drift after a hard drive. Back on the dyno for a re-tune,...
Forum:
Forced Induction
07-09-2018, 05:47 PM
24
Turbo ram air intake?
5,691
Posted By
Hags86
For what it's worth here is mine. Custom built...
For what it's worth here is mine. Custom built crash bar and shroud around the radiator and heat exchanger on the Water-to-Air intercooler. Fresh air is ducted from the enlarged front grill up into...
Forum:
Forced Induction
07-09-2018, 06:07 AM
24
5,691
Posted By
Hags86
I agree with FRS Justin. You won't get any Ram...
I agree with FRS Justin. You won't get any Ram air but a good supply of cold air is beneficial. I'm not familiar with the kit but if it's getting fresh air (e.g no warm air after the radiator etc)...
Forum:
Forced Induction
06-23-2018, 05:14 PM
25
Engine oil recommendations for turbo cars
12,164
Posted By
Hags86
Shimming the relief valve makes the spring...
Shimming the relief valve makes the spring stiffer, keeps the relief valve closed longer. Holds more pressure. You can see how the pressure raises nicely with RPM and then flattens out. Stiffening...
Forum:
Forced Induction
06-21-2018, 07:33 PM
25
12,164
Posted By
Hags86
I really like this logic. OEM's are forced to...
I really like this logic. OEM's are forced to make so many compromises with their recommendations and design it is impossible to get one recommendation for everyone.
A 0W-20 is great for a car...
Forum:
Forced Induction
06-21-2018, 05:17 PM
25
12,164
Posted By
Hags86
The place to learn about this stuff is the Bob...
The place to learn about this stuff is the Bob the Oil Guy "motor oil university" page
https://www.bobistheoilguy.com/motor-oil-101/
Forum:
Forced Induction
06-21-2018, 04:56 PM
25
12,164
Posted By
Hags86
It is Penrite 10 Tenths Racing 10W-40 (I know I...
It is Penrite 10 Tenths Racing 10W-40 (I know I said 0W-40 in the post but when I went to check it was actually a 10W-40. I have edited my post to reflect that.
Maybe there is differences...
Forum:
Forced Induction
06-21-2018, 03:38 PM
25
12,164
Posted By
Hags86
The answer is the thinnest possible oil that...
The answer is the thinnest possible oil that gives sufficient oil pressure. Get an oil pressure gauge.
This is a scatter plot of my car of oil pressures (Y axis) vs revs (X axis) where the colour...
Forum:
Forced Induction
06-18-2018, 03:38 PM
23
INSTALLED TURBO, CAR WONT START
4,546
Posted By
Hags86
The car idles pretty much 100% on the OEM direct...
The car idles pretty much 100% on the OEM direct injectors so port injector scaling is unlikely to be the issue.
I'd be looking for a vacuum leak or bad electrical connection.
Forum:
Forced Induction
06-17-2018, 07:39 PM
52
Engine internals for 500-600 HP turbo
20,583
Posted By
Hags86
Same data but with different scales to make it...
Same data but with different scales to make it easier to read.
Forum:
Forced Induction
06-17-2018, 04:12 PM
52
20,583
Posted By
Hags86
I spoke to FRS Justin and it turns out my build...
I spoke to FRS Justin and it turns out my build has more similarities than differences to his. Pistons, rods, closed deck, 1/2" ARP studs, JE MLS head gasket are all the same. I'm using lighter...
Forum:
Forced Induction
06-10-2018, 04:56 PM
52
20,583
Posted By
Hags86
Have a Moroso baffle The plan was to...
The plan was to keep OEM valves with GSC springs and not port as I'm not chasing stupid power. But the engine builder just checked the valves and a few are bent up to...
Forum:
Forced Induction
06-10-2018, 11:41 AM
52
20,583
Posted By
Hags86
My engine builder (Top Torque in Melbourne)...
My engine builder (Top Torque in Melbourne) thinks that shimming the pump and installing some flow restrictors to the heads will get me the oil pressures I want. They do all the engine warranty work...
Forum:
Forced Induction
06-09-2018, 12:50 PM
11
Opinion on Kit
2,242
Posted By
Hags86
I have a smaller turbo which had peak efficiency...
I have a smaller turbo which had peak efficiency at about 12psi but we could run to 14psi and get more power at the expense of higher intake temps.
- on e85 made 241 rwkW @ 14psi
- on 98...
Forum:
Forced Induction
06-09-2018, 12:39 PM
53
How often do engines fail because of FI?
12,320
Posted By
Hags86
So the symptom of the bent rods is the air/fuel...
So the symptom of the bent rods is the air/fuel ratio changing. I had some problems with the A/F drifting over a few weeks and the ECU needed to perform a lot of fuel trims to try and compensate. ...
Forum:
Forced Induction
06-02-2018, 09:43 PM
52
20,583
Posted By
Hags86
After talking with a bunch of engine builders and...
After talking with a bunch of engine builders and tuners the build list has changed a little since I started this thread.
My approach is to spend as much is as sensible on the short block...
Page 1 of 3
1
2
3
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
09:19 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
