follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 2
1
2
Showing results 1 to 30 of 39
Search took
0.82
seconds.
Search:
Posts Made By:
Gloonge
Forum:
Forced Induction
05-21-2021, 07:30 PM
1
Edelbrock Larger Pulley
818
Posted By
Gloonge
In case anyone needs this the 100" belt fit.
Forum:
Wheels and Tires
03-16-2021, 02:37 PM
13
► APEX | 17” ARC-8 Lightweight Track Wheel Group Buy
3,237
Posted By
Gloonge
Great set of wheels here, got mine in satin...
Great set of wheels here, got mine in satin bronze at full retail. Would buy them again if I blew one out today.
Forum:
Engine, Exhaust, Transmission
01-13-2021, 09:19 AM
46
To exhaust wrap or not
6,954
Posted By
Gloonge
Crows foot wrenches and a nice extensions was how...
Crows foot wrenches and a nice extensions was how I got mine on with the wrap.
Forum:
Want-To-Buy Requests
12-09-2020, 06:59 PM
8
WTB Hood Vents
819
Posted By
Gloonge
Thanks for the heads up. I'm not quite ready to...
Thanks for the heads up. I'm not quite ready to settle for the verus, but I will keep my eye on those while I weigh my options.
Forum:
8
WTB Hood Vents
819
Posted By
Gloonge
Thanks for looking out, its nothing new though. I...
Thanks for looking out, its nothing new though. I get between 6 and 10 of those private messages on every WTB post I put on here. Every now and then I get lucky and find a real person with what I am...
Forum:
Issues | Warranty | Recalls / TSB
11-23-2020, 01:53 PM
10
Possible oil leak?
1,596
Posted By
Gloonge
Kinda looks like it's seeping from the dipstick...
Kinda looks like it's seeping from the dipstick tube oring and being blown around by the fans.
Forum:
11-21-2020, 04:44 PM
5
Question Regarding 2017+ Battery
1,600
Posted By
Gloonge
Just pry that off with a screw driver. It's just...
Just pry that off with a screw driver. It's just to hold those wires in place.
Also that cable tie can not hurt a cable what you are seeing squished is called conduit. It is of no concern.
Forum:
11-01-2020, 09:37 AM
9
Smoke from engine bay due to oil leak?
1,807
Posted By
Gloonge
They all do this. Lookup a cam plate replacement...
They all do this. Lookup a cam plate replacement for it. Aftermarket ones come with a nice o ring isnted of the bullshit rtv that subaru installed.
Here ya go....
Forum:
10-29-2020, 08:23 PM
15
Rubber Cover Fell Into Transmission Bell Housing
3,056
Posted By
Gloonge
I thought it was a dumb product too when I first...
I thought it was a dumb product too when I first seen it. Thought it was just one of those products to rice up your engine bay. Until the morning I started my car and the God awful racket from that...
Forum:
10-22-2020, 08:10 AM
4
Squeaking on starting up
2,009
Posted By
Gloonge
Wet belt most likely, no worries.
Forum:
Forced Induction
09-29-2020, 12:24 PM
4,964
Edelbrock E-force Owner's thread and FAQs (Frequently Asked Questions)
1,478,921
Posted By
Gloonge
Buy it with the tune. So you will have the ecutek...
Buy it with the tune. So you will have the ecutek and a base tune to get it to your tuner of choice.
Forum:
09-28-2020, 09:06 PM
4
Fuse #4, TAILS
846
Posted By
Gloonge
If you have tapped into any wire anywhere. I...
If you have tapped into any wire anywhere. I would start there, probably touching metal somewhere. Had the same issue with my reverse lights a few months ago.
Forum:
09-24-2020, 12:16 PM
49
Engine Stalled, Rough Idle And Knocking Noise On Startup
7,375
Posted By
Gloonge
The guy below has good advice, you can likely get...
The guy below has good advice, you can likely get a few thousand if the rest of the car is in good shape from a private sale.
But you can also find a low mileage engine for 3k and have it...
Forum:
09-18-2020, 06:49 PM
5
Questions about bolts on undercarriage and front bumper
3,167
Posted By
Gloonge
Idk about just the vent, but you can get the...
Idk about just the vent, but you can get the whole panel for $22.
Forum:
09-18-2020, 03:44 PM
18
Part ID and potential problems?
1,183
Posted By
Gloonge
Try to catch a video of it. My two most prevalent...
Try to catch a video of it. My two most prevalent are input shaft bearing whine. Fixed that one by installing a supercharger, can't hear it anymore. The other is clutch chatter, not sure what's up...
Forum:
09-18-2020, 03:26 PM
18
1,183
Posted By
Gloonge
Did you recover the plastic? If not it fell down...
Did you recover the plastic? If not it fell down inside there with the flywheel.
The part is just an inspection plate. Varus makes an aluminum on for $30corbthe original is $15 from the dealer.
Forum:
09-13-2020, 03:40 PM
49
7,375
Posted By
Gloonge
Definitely sound like a trash motor. Pull the dip...
Definitely sound like a trash motor. Pull the dip stick and check for glitter or water.
You hit a puddle recently? Or forget to change your oil for 20k miles?
Also, with the rpms fluctuating...
Forum:
Forced Induction
09-13-2020, 12:22 AM
4,964
1,478,921
Posted By
Gloonge
PSA: if you're getting weird negative LTFTs...
PSA:
if you're getting weird negative LTFTs check the screws on the air filter housing.. All of mine were loose and one was missing.
Replaced the one and tightened the rest and the issue went...
Forum:
Software Tuning
09-13-2020, 12:19 AM
7
LTFT creeping negative, AFR's staying normal?
1,207
Posted By
Gloonge
It sounded like clutch chatter for a few days...
It sounded like clutch chatter for a few days cause it only happened when trying to start in first gear. Then it was constant so I could hear it at idle.
I'm telling you, forced induction has been...
Forum:
09-10-2020, 06:05 AM
6
No power to windows
1,535
Posted By
Gloonge
Try this. ...
Try this.
https://m.youtube.com/watch?v=MRMrwnCfR0c
Forum:
Software Tuning
09-09-2020, 06:16 PM
7
1,207
Posted By
Gloonge
Today my a/c compressor started knocking loud...
Today my a/c compressor started knocking loud enough for me to hear it. The bottom bolt backed out. After snuggling that back up the fuel trims seem to have gone back to normal.
So I am assuming...
Forum:
Software Tuning
08-21-2020, 07:58 AM
5
Oft Stage 2 e85 switch over question
1,493
Posted By
Gloonge
You don't have to re learn. The e85 tune is...
You don't have to re learn. The e85 tune is expecting certain results and when it doesn't get those results it adds a little more fuel to compensate. Once your tank gets more and more pure e85 it...
Forum:
Forced Induction
08-18-2020, 06:02 AM
4,964
1,478,921
Posted By
Gloonge
$30 on Amazon next day with prime if you don't...
$30 on Amazon next day with prime if you don't want to wait.
Forum:
08-17-2020, 07:46 PM
19
Overreving engine with automatic transmition
2,637
Posted By
Gloonge
Most autos with a "manual" function have a bunch...
Most autos with a "manual" function have a bunch of nannies that won't let your shift up or down if your outside of the rev range.
Forum:
07-28-2020, 10:09 PM
4
stock exhaust manifold (header)
998
Posted By
Gloonge
Just put some tape over the holes. Problem solved.
Forum:
Engine, Exhaust, Bolt-Ons
07-23-2020, 12:13 PM
16
Header, Overpipe, Front Pipe
2,733
Posted By
Gloonge
I picked it up.
I picked it up.
Forum:
07-13-2020, 07:40 AM
8
Exhaust bolt torque specs?
8,624
Posted By
Gloonge
22 header 32 overpipe 13 on the spring bolts ...
22 header
32 overpipe
37 on the hanger bolt.
It would appear that in the shop manual "FR" is the over pipe and "CTR" is what we would call the front pipe.
Forum:
07-13-2020, 06:23 AM
8
8,624
Posted By
Gloonge
From the shop manual. Tightening torque...
Tightening torque (Exhaust manifold sub-assembly):
30 N·m (3.1 kgf-m, 22.1 ft-lb)
Tightening torque (Exhaust pipe sub-assembly FR):
35 N·m (3.6 kgf-m, 25.8 ft-lb)
Forum:
07-09-2020, 01:56 PM
22
FS: Edelbrock Supercharger Kit
3,175
Posted By
Gloonge
Haha never would have assumed intercooler with...
Haha never would have assumed intercooler with those little ports. Let me look into some stuff and get back to you with a number I can pull off.
Thank you!
Forum:
07-09-2020, 12:44 PM
22
3,175
Posted By
Gloonge
$500 is not bad, for some reason I always assumed...
$500 is not bad, for some reason I always assumed it would be $1000 or more.
Thanks!
Page 1 of 2
1
2
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
05:20 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
