follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Showing results 1 to 22 of 22
Search took
1.13
seconds.
Search:
Posts Made By:
Hentai
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
12-11-2016, 01:37 PM
3
Coilovers Springs?
1,397
Posted By
MeisterR
In theory, the springs should not be loose ever. ...
If there is a gap, the gap should be taken by a "helper springs"
This is a small springs that is very light, and will fully compress as soon as any...
Forum:
12-08-2016, 06:06 PM
18
Dampening Concerns & Questions!
3,676
Posted By
totopo
For any given spring rate there is basically a...
For any given spring rate there is basically a small range of more or less ideal damper rates. The problem in most coilovers is that 1, bad ones aren't digressive enough to ever be correct, and 2,...
Forum:
Wheels | Tires | Spacers | Hub --
Sponsored by The Tire Rack
10-23-2016, 06:51 PM
10
Spacers Torque?
3,572
Posted By
guybo
That's only the first 100 miles. Not every 100...
That's only the first 100 miles. Not every 100 miles. Each time you mount the wheels and/or spacers they need to be retorqued
Forum:
Cosmetic Modification (Interior/Exterior/Lighting)
09-24-2016, 02:13 PM
9
Trd Exhaust exits for rear bumper?
2,704
Posted By
adjusts
That's my car haha
That's my car haha
Forum:
09-06-2016, 10:19 PM
9
2,704
Posted By
Spectre20
Here is another source....
Here is another source. http://hidpowerhouse.com/trd-japan-rear-muffler-garnish-cut-out-p-176.html
Forum:
09-06-2016, 12:00 PM
9
2,704
Posted By
NyC Zn6
So what you are looking for is the TRD Muffler...
So what you are looking for is the TRD Muffler garnish. You can purchase these separate instead of the whole TRD rear bumper. Here is an ebay link to one...
Forum:
12-08-2015, 05:53 PM
5
K1X Halo & Crystal Pearl White Paint Code?
9,080
Posted By
swarb
If you are buying something painted, make sure...
If you are buying something painted, make sure you confirm the paint code and NOT the paint name. For example world rally blue, there are multiple codes...
Forum:
12-08-2015, 05:48 PM
5
9,080
Posted By
8R6
same. just like the earlier models,...
same.
just like the earlier models, Whiteout and Satin White Pearl are the same.
Forum:
12-08-2015, 08:06 AM
5
9,080
Posted By
KR-S
Halo and Crystal White Pearl are one and the same.
Forum:
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
11-26-2015, 11:49 PM
4
Resetting ECU after cleaning MAF?
3,462
Posted By
steve99
Ecu is always learning no need to reset, only...
Ecu is always learning no need to reset, only need to reset to clear cel codes
see Flashing-Reset-Learning link below
Forum:
Engine, Exhaust, Transmission
11-02-2015, 10:40 PM
31
Concerns about Intakes?
8,029
Posted By
steve99
Just the filter will be fine, the intake tubes...
Just the filter will be fine, the intake tubes are rearly jist for looks and to nicely delete the sound tube, but you can just plug it up its near steering colimn.
Once you start messing with...
Forum:
11-02-2015, 02:28 PM
31
8,029
Posted By
churchx
Should or shouldn't without data behind imho it's...
Should or shouldn't without data behind imho it's wrong to guess. By rough real life gauging you've experienced it doing more harm then good, if nothing else is known, indeed, makes sense to revert...
Forum:
11-02-2015, 02:22 PM
31
8,029
Posted By
steve99
The ecu continuously learns fuel trims. It...
It does this by comparing the AFR it asks for to the AFR it gets. Then applies a series of corrections in different air flow bands . Unfortunately when you...
Forum:
11-01-2015, 11:49 AM
5
Check Engine Light came on after Intake install
2,840
Posted By
fika84
Just battery
Just battery
Forum:
11-01-2015, 11:14 AM
5
2,840
Posted By
Trust86
Just disconnect your battery should be fine
Forum:
10-30-2015, 06:47 AM
31
8,029
Posted By
Captain Snooze
Sent from my pc using my keyboard.
Forum:
10-30-2015, 04:59 AM
31
8,029
Posted By
Kiwi Greg
Get it, awesome, love it :) ...
http://i1004.photobucket.com/albums/af161/Kiwi-Greg/GT%2086%20Strut%20brace%20004%20640x479_zpsydaphsmi.jpg...
Forum:
10-30-2015, 04:31 AM
31
8,029
Posted By
ck-GT86
Marginal gains, no tune necessary. ...
Grimmspeed is a solid intake, get a different, exposed-filter type intake if you're looking for noise. Otherwise, stock airbox until FI.
.ck
Sent from...
Forum:
09-19-2015, 07:39 PM
5
Hub Centric Rings Fitment?
2,428
Posted By
mizzta21
I put 3mm hubs on mine. they were all loose with...
I put 3mm hubs on mine. they were all loose with about 4000 miles on them. no issues
Forum:
Issues | Warranty | Recalls / TSB
09-10-2015, 08:58 AM
32
Shitty MPG
7,403
Posted By
To have 23 is not uncommon for people that drive...
To have 23 is not uncommon for people that drive in stop and go a lot but does not explain the drop if you used to get much better in the same driving conditions.
Forum:
07-11-2015, 01:54 PM
5
Aftermarket Lugs on Stocks
1,621
Posted By
8R6
they usually are different, but our stock...
they usually are different, but our stock wheels/lugs use a tapered/conical seat so the stock lugs and aftermarket "tuner" lugs have the same 60deg taper.
Forum:
11-18-2013, 04:48 AM
297
Wheel specs for Rocket Bunny Fenders
282,702
Posted By
Maverick22
So I just wanted to remove my old post and give...
So I just wanted to remove my old post and give everyone a more accurate size chart for the rocket bunny and wheel specs.
I am not responsible if you mess something up, I am only providing...
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
03:31 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
