follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 6
1
2
3
4
5
Last
Showing results 1 to 30 of 172
Search took
1.20
seconds.
Search:
Posts Made By:
Lav
Forum:
Engine, Exhaust, Transmission
08-06-2023, 07:46 PM
32
How bad is it that I've had a 2 inch hole in my air filter resonator for 2 weeks?
2,704
Posted By
Hells bells, back in the day, I've driven...
Hells bells, back in the day, I've driven hundreds of miles with the engine not even having an air cleaner - :confused0068:
Why? Because you never knew when you would be challenged to a drag race...
Forum:
08-05-2023, 03:32 PM
32
2,704
Posted By
soundman98
there's really 2 variants of scrap yard. ...
pick-your-part yards= you can confirm they have 'a' vehicle(usually with a picture of the vehicle as it was coming into the yard), but they won't confirm...
Forum:
09-12-2022, 08:06 PM
204
Sticky:
Basic Bolt on mods intake, exhaust tuning guide
360,414
Posted By
FRSBRZGT86FAN
It's just best practice to drive about for a...
It's just best practice to drive about for a week, maybe mix in some spirited driving, then go back and double check.
I did that back when I still had my car and the cnt uel and didn't notice...
Forum:
07-14-2022, 08:43 PM
36
Installing Resonator?
19,225
Posted By
DominicRouleau
Thank you for posting all that informations ! I...
Thank you for posting all that informations ! I decided to replace my TRD resonator with a Vibrant Ultra Quiet resonator because I have a uel header and was a little too boomy for me. The shop who...
Forum:
Cosmetic Modification (Interior/Exterior/Lighting)
04-16-2022, 09:50 PM
13
seat belt shoulder strap thingy..
3,527
Posted By
soundman98
once the fabrics stretched, it's coming out...
once the fabrics stretched, it's coming out again. they're riveted in place and create the hole as the rivet is compressed. stretching out the fabric to fit makes the hole larger, and more likely...
Forum:
04-16-2022, 09:13 PM
13
3,527
Posted By
EndlessAzure
Slip the plastic flange back into that hole where...
Slip the plastic flange back into that hole where the yellow seat foam is showing through. You might need to do a little stretching and careful work, but once it's in it will probably stay as long as...
Forum:
04-13-2022, 09:55 PM
13
3,527
Posted By
soundman98
they're generally called 'snap fasteners', ...
they're generally called 'snap fasteners', though everything i'm finding at local micheals/joann/home depot/amazon are all smaller than needed.
https://www.joann.com/search?q=Snap%20Fasteners
Forum:
12-08-2021, 09:39 PM
21
Recommendations on sound proofing?
5,206
Posted By
soundman98
yes. the idea to sound deadening is to...
yes.
the idea to sound deadening is to reduce external noise. in audio, the idea is to reduce unwanted noise from intruding on the wanted noise. in your case, you're just skipping the 'audio'...
Forum:
12-04-2021, 02:04 PM
21
5,206
Posted By
Cephas
I've done it exclusively to make the car quieter,...
I've done it exclusively to make the car quieter, actually. Any improvement in audio quality is just icing on the cake.
Forum:
DIY (Do-It-Yourself) Guides
09-29-2021, 11:00 AM
110
Full BRZ interior disassembly for sound deadening - lots of pics, every panel off
137,482
Posted By
alphasaur
This thread was immensely helpful! Thank...
Thank you!
For anyone that is sort of interested in this undertaking, I ended up doing it and it took me about two full days between installing front...
Forum:
Software Tuning
08-28-2020, 02:08 AM
6
Need Help OFT ERROR CODE
2,394
Posted By
BayArea_FRS
Hey so I already had a tune installed for a while but was trying to change tunes. During installing the new tune it erased my ecu file like normal but then failed , So now I I have no ecu tune at all...
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
06-30-2020, 12:16 AM
491
CSG Spec Tein Flex A Owners Thread
156,091
Posted By
CounterSpace Garage
It probably just need a nice impulse smack. A...
It probably just need a nice impulse smack. A few that we have adjusted were like that regardless of the type of system. We've seen other manufacturers have collars that started slipping so the car...
Forum:
08-05-2019, 01:13 PM
11
DIY Cheap Armrest Simple and Easy. Updated as of Aug. 5 2019
3,327
Posted By
Drft204
Hey guys, I redid it in suede and 3M super 77....
Hey guys, I redid it in suede and 3M super 77. The suede material is much stretchier and easier to work with. Looks nicer as well.
Please see the original post for the updated version.
Forum:
07-23-2019, 02:30 AM
11
3,327
Posted By
Drft204
Hey guys,
I made this armrest for around $30 with material you can get at a craft store.
Materials:
-Simple Cushion foam 2" thick
-1/2" Thick Styrofoam Board( Can be replaced with MDF board...
Forum:
07-12-2019, 01:26 AM
215
TRD Exhaust owners?
80,970
Posted By
Mr_Eyo
If it's at the axleback joint, how bad could it...
If it's at the axleback joint, how bad could it be?
Forum:
07-12-2019, 12:04 AM
215
TRD Exhaust owners?
80,970
Posted By
Mr_Eyo
Which bolts and how loose?
Forum:
06-08-2019, 02:03 PM
10
Did donuts, turned off car, turn on car, rough idle, died, no code
2,272
Posted By
Yoshoobaroo
There’s a fuel cut when the car thinks it...
There’s a fuel cut when the car thinks it crashed. I spun backwards once and it wouldn’t start for ~30secs
Forum:
05-31-2019, 12:37 PM
215
TRD Exhaust owners?
80,970
Posted By
weederr33
I must confess, when Prius drivers are going 10...
I must confess, when Prius drivers are going 10 or more under the limit, I relish the opportunity to book it passed them. They aren't saving the environment any better going 10 or more under. Alas my...
Forum:
05-31-2019, 11:55 AM
215
TRD Exhaust owners?
80,970
Posted By
nikitopo
Are you sure you're not a ricer? LOL
Forum:
16
How can you be sure there are no leaks after install?
2,253
Posted By
Spuds
That only works on the BRZ.
Forum:
05-31-2019, 09:34 AM
16
2,253
Posted By
Pretty sure that is what others and myself have...
Pretty sure that is what others and myself have already said. You ware overthinking this unless you believe there is a leak you can't find. If there is a leak large enough to fill the car with...
Forum:
05-31-2019, 09:28 AM
16
2,253
Posted By
Spuds
Am I the only one here who is wondering what was...
Am I the only one here who is wondering what was installed before giving advice?
Forum:
05-31-2019, 08:54 AM
16
2,253
Posted By
cjd
Vacuum to the tailpipe (be sure to seal it so its...
Vacuum to the tailpipe (be sure to seal it so its not just pulling air through the muffler) and a tube to the ear with the other end in hand, checking all the joints. Better than soap because you can...
Forum:
05-31-2019, 07:24 AM
16
2,253
Posted By
Fred E
You could buy a smoke test machine on amazon and...
You could buy a smoke test machine on amazon and plug it into one of the exhaust tips while blocking the other (if you still have a dual exit). You'll have to turn the crank pulley yourself to close...
Forum:
05-30-2019, 06:47 PM
16
2,253
Posted By
natekwondo
This may not be a popular suggestion but, if you...
This may not be a popular suggestion but, if you wanna be sure just take it to an exhaust shop and indicate you think you have an exhaust leak. Save you the hassle in the long run.
Forum:
05-30-2019, 05:13 PM
16
2,253
Posted By
Lantanafrs2
Dont worry about it
Dont worry about it
Forum:
05-30-2019, 03:53 PM
16
2,253
Posted By
Can you see anything? Can you hear anything? ...
Can you smell anything?
The same things apply to small leaks as you mentioned for big ones.
If you can't find a leak there probably isn't any.
Forum:
Off-Topic Lounge [WARNING: NO POLITICS]
05-23-2019, 01:18 AM
1,441
Sticky:
how old? what do you do?
337,283
Posted By
wbradley
Update from 2013- I am 55 and assist clients...
Update from 2013- I am 55 and assist clients designing, supplying and to some extent building custom metal building systems.
Forum:
Southern California
05-14-2019, 05:45 PM
0
Japanese Car Cruise In at Petersen Museum FREE
695
Posted By
ohmikegoodness
I was thinking about checking out this event!
https://petersentickets.org/products/japanese-cruise-in
Maybe see you there?
Forum:
Southern California
03-27-2019, 03:38 PM
2
Boomers 86 meet newebie
928
Posted By
Gymnast562
If he's talking about the Boomers that I'm...
If he's talking about the Boomers that I'm familiar with [not the bar], then it's a family oriented place with miniature golf, arcade games, and entertainment things and the like ^_^.
Page 1 of 6
1
2
3
4
5
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Site Announcements / Questions / Issues
08:57 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
