follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 9
1
2
3
4
5
Last
Showing results 1 to 30 of 258
Search took
2.37
seconds.
Search:
Posts Made By:
Target70
Forum:
Forced Induction
01-09-2024, 12:57 PM
11,295
Full throttle Electric Supercharger Build Thread
3,439,581
Posted By
WNDSRFR
I think you're talking about the Procede...
I think you're talking about the Procede Controller. It was a separate item from the ESC from OFT. I believe it died off with the Phantom. You see one for sale every now and then. You might want to...
Forum:
Forced Induction
10-28-2023, 01:34 PM
11,295
3,439,581
Posted By
Qwimby1
Strange voltage readings
Car has been running beautifully since I installed new Big Crank deep-cycle batteries, but I'm getting strange voltmeter readings. I can only see the meter at night so that's when I do my testing. It...
Forum:
Forced Induction
10-05-2023, 02:39 PM
11,295
3,439,581
Posted By
WNDSRFR
This is what I think (guess). My meter reads...
This is what I think (guess). My meter reads about 28.5 volts when the system is not engaged. I think that the charger is supplying 28.5 volts constantly to the 2 batteries in series. So each battery...
Forum:
Forced Induction
10-01-2023, 02:10 PM
11,295
3,439,581
Posted By
WNDSRFR
I found this article about charging AGM...
I found this article about charging AGM batteries.
https://www.interstatebatteries.com/blog/how-to-charge-an-agm-battery
Forum:
Forced Induction
09-23-2023, 04:53 PM
11,295
3,439,581
Posted By
Qwimby1
Mine is working again, and as usual it was...
Mine is working again, and as usual it was batteries. But strange stuff is happening. It started when my OBD, which had reliably been predicting 100% throttle when I used it, started showing max...
Forum:
Forced Induction
09-15-2023, 10:13 AM
11,295
3,439,581
Posted By
WNDSRFR
It's getting to be about time for me to replace...
It's getting to be about time for me to replace my batteries again. I'm thinking about switching to lithium.
In my research I found this:...
Forum:
Forced Induction
08-05-2023, 07:40 PM
47
Torque amp ESC
5,995
Posted By
Texas2016Frs
https://datazap.me/u/texas2016frs/torque-amp-105-d...
https://datazap.me/u/texas2016frs/torque-amp-105-degrees-ambient?log=0&data=1-13
Here is the datalog I did for openflash. Ambient temps were 105. I don't want to take another one until I get the...
Forum:
Forced Induction
07-17-2023, 01:17 AM
47
Torque amp ESC
5,995
Posted By
Texas2016Frs
Thanks! I'm excited. The kit does not include any...
Thanks! I'm excited. The kit does not include any vehicle specific parts. I am going to mount it similarly to the phantom supercharger. I am pretty sure I have ordered the few items that I will need...
Forum:
Forced Induction
07-14-2023, 03:55 PM
47
Torque amp ESC
5,995
Posted By
Texas2016Frs
Torque amp ESC
I am going to be installing a torque amp electronic supercharger on my car.
From what I have seen it will make more power than the phantom as it spins at 70k rpm but has a smaller compressor.
Forum:
Forced Induction
07-01-2023, 05:15 PM
11,295
3,439,581
Posted By
Qwimby1
Grermlin occurred
I noticed that it hasn't felt its usual peppy self recently. I have my OBD set to show oil temp and absolute throttle position. I didn't notice until last night that when I floor it, my throttle...
Forum:
Forced Induction
10-17-2022, 10:29 AM
11,295
3,439,581
Posted By
WNDSRFR
Now that I have a basic understanding of this...
Now that I have a basic understanding of this thing I'm thinking about building my own.
I know the compressor is from a Cummins 11 liter diesel engine and I know the spec on the motor. I'm thinking...
Forum:
Forced Induction
10-14-2022, 12:03 PM
11,295
3,439,581
Posted By
WNDSRFR
Got it all back together and on the car. Butt...
Butt dyno says it works good as new. YAY.
The new modified wheel fit almost perfectly. It fit super tight. Tight enough that it rubbed the housing a bit. My...
Forum:
Forced Induction
10-11-2022, 02:45 PM
11,295
3,439,581
Posted By
Teseo
Because government.
Because government.
Forum:
Forced Induction
09-03-2022, 01:01 PM
11,295
3,439,581
Posted By
Qwimby1
I have version 2.5 and there is no vacuum tube...
I have version 2.5 and there is no vacuum tube from the compressor. Mine definitely has the two-position throttle switch, and while I at first noticed the sequential boost, I don't now. That could...
Forum:
Forced Induction
09-03-2022, 11:08 AM
11,295
3,439,581
Posted By
WNDSRFR
I've been reading though this post looking for...
I've been reading though this post looking for info on the drag reduction and discovered a few things. The drag reduction was discontinued when the two stage switch was introduced. Also I discovered...
Forum:
Forced Induction
08-24-2022, 11:59 AM
11,295
3,439,581
Posted By
WNDSRFR
I got the right bearings installed and the motor...
I got the right bearings installed and the motor runs like new! I ran it with the wheel attached and it seems to run fine. Next step is reinstall it in the housing, attach it to the intake and see...
Forum:
Forced Induction
08-20-2022, 10:31 AM
11,295
3,439,581
Posted By
WNDSRFR
I got the motor to work. Yay. But the rear...
I got the motor to work. Yay. But the rear bearing isn't quite right and I'm having trouble finding the right one. Turns out the motor shaft is 8mm in the front and 6mm in the rear. I got a good...
Forum:
Forced Induction
05-18-2022, 02:42 PM
11,295
3,439,581
Posted By
Start with confirming your level and charging...
Start with confirming your level and charging system. I would never assume anything when it comes to batteries. Check you draw amperage. That has more meaning than volts.
Forum:
Forced Induction
02-02-2022, 12:39 PM
11,295
3,439,581
Posted By
Qwimby1
I think I got it. The locking ring on the plug...
I think I got it. The locking ring on the plug was just loose enough. After I tightened it, the meter (so far) hasn't cut in and out. Disconnected everything first, then had to redo it al!. Sorry...
Forum:
Forced Induction
02-01-2022, 11:53 AM
11,295
3,439,581
Posted By
Qwimby1
Whaddayaknow. The damn thing works! I never...
Whaddayaknow. The damn thing works! I never thought I'd see it. I haven't even flashed the tune yet, but what a difference. I won't have to worry about hard-to-get E85 anymore. I guessed right...
Forum:
Forced Induction
06-24-2021, 07:48 AM
11,295
3,439,581
Posted By
WNDSRFR
Thanks for the thoughts. Everything you say makes...
Thanks for the thoughts. Everything you say makes sense. The green thing is connected to the resistors which are somehow related to the time-delay function of the two step switch concept. I think the...
Forum:
Forced Induction
02-11-2021, 04:31 AM
11,295
3,439,581
Posted By
geraldjust
hey guys! hopefully you guys don't think i have...
hey guys! hopefully you guys don't think i have forgotten about this. but ive made some progress in the electronics. As for improving the original electronics as it was mostly pieced together from...
Forum:
Forced Induction
12-07-2020, 07:12 PM
11,295
3,439,581
Posted By
Legend1515
Mine stopped working recently. It would do the...
Mine stopped working recently. It would do the same thing with the vacuum kick and voltage just rising back immediately. My pc680 starter battery was swelling up, corrosion on the negative terminal,...
Forum:
Forced Induction
11-13-2020, 03:28 PM
11,295
3,439,581
Posted By
zc06_kisstherain
if you were close to NJ, i could sell mine
Forum:
Forced Induction
11-10-2020, 07:36 AM
11,295
3,439,581
Posted By
WNDSRFR
The newer battery replacement uses a different...
The newer battery replacement uses a different tray. The advantage of the newer batteries is the terminal is alot more user friendly than the originals. But the PowerSonic's are alot cheaper. Just...
Forum:
Forced Induction
10-07-2020, 10:23 PM
11,295
3,439,581
Posted By
geraldjust
Hmm exactly that's what i would avoid. Im...
Hmm exactly that's what i would avoid. Im thinking of doing 3 nissan leaf batteries in series. This way i can get to 24v all full charge. and wiring a BMS to it with a charge it should not be too...
Forum:
Forced Induction
03-01-2020, 11:13 PM
11,295
3,439,581
Posted By
86TOYO2k17
Why not do it right with the proper wire/cable?...
Why not do it right with the proper wire/cable? Technically jumper cables would work but probably not ideal and may not be safe.
EWCS 1/0 Gauge Premium Extra Flexible Welding Cable 600 Volt Combo...
Forum:
Forced Induction
08-01-2019, 12:37 PM
11,295
3,439,581
Posted By
86TOYO2k17
Torqamp just emailed me, i have already purchased...
Torqamp just emailed me, i have already purchased a sprintex so i wont be getting one at this time, but they are doing a kickstarter in the next 2 weeks, and offering the system at 18% off. so 2700$...
Forum:
Forced Induction
10-12-2018, 10:44 AM
11,295
3,439,581
Posted By
vfrqqq
Thanks Target70. I'll report back after I power...
Thanks Target70. I'll report back after I power it up. Hopefully that will provide some additional helpful information.
I'm definitely not looking forward to taking apart the electronics. ...
Forum:
Forced Induction
10-08-2018, 05:44 PM
11,295
3,439,581
Posted By
vfrqqq
I'll take some pics and post them soon for anyone...
I'll take some pics and post them soon for anyone who is interested.
Page 1 of 9
1
2
3
4
5
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine, Exhaust, Transmission
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
04:09 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
