follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Showing results 1 to 17 of 17
Search took
0.36
seconds.
Search:
Posts Made By:
localhost
Forum:
Forced Induction
12-30-2021, 02:11 PM
4,982
Edelbrock E-force Owner's thread and FAQs (Frequently Asked Questions)
1,591,713
Posted By
Aztec
That is the Radiator/Oil Cooler that I am running...
That is the Radiator/Oil Cooler that I am running with my Edelbrock. Honestly one of the cleanest installs since it takes the place of the OEM radiator, but adds more function with the added oil...
Forum:
Forced Induction
12-29-2021, 01:04 PM
4,982
1,591,713
Posted By
B T
I don't have any experience with this kit, but on...
I don't have any experience with this kit, but on one of my other projects I had a dual use radiator. There was a pinhole leak in the barrier between the two and it ended up contaminating both my...
Forum:
Forced Induction
12-28-2021, 08:33 PM
4,982
1,591,713
Posted By
CSG Mike
It's still the easiest option for additional...
It's still the easiest option for additional cooling.
Forum:
Forced Induction
09-13-2021, 02:59 PM
4,982
1,591,713
Posted By
CSG Mike
You'll want to consult with the shop that did...
You'll want to consult with the shop that did your installs, as they'll be more familiar with your engine bay.
It's difficult to make blind recommendations, as this is not a plug and play solution.
Forum:
Forced Induction
05-22-2021, 12:11 AM
4,982
1,591,713
Posted By
Pgh_Area
I recently purchased belts, smaller pulley and...
I recently purchased belts, smaller pulley and added tensioner from a forum member.
13/16" x 98-5/8" OC
20mm x 2505mm OC.
Gates
micro-v.
K060980RPM
6PK2491
Forum:
Issues | Warranty | Recalls / TSB
12-02-2019, 02:26 PM
66
FIXED: Installed Edelbrock SC. Now car is throwing CELs
14,446
Posted By
mrg666
I bought here ...
I bought here
https://www.subarupartsdeal.com/parts/subaru-meter-assembly-air-flow~22680aa400.html
Forum:
11-26-2019, 09:02 PM
66
14,446
Posted By
BirdTRD
The first pic is the bypass valve hose. If the...
The first pic is the bypass valve hose. If the valve does not move from the open position (pulled in due to vacuum) when you pinch the hose, then it is working correctly and not leaking.
As for...
Forum:
11-18-2019, 09:32 AM
66
14,446
Posted By
toast
An engine is basically an air pump. Your air...
An engine is basically an air pump. Your air pump can now flow about 20% more air because the outlet is less clogged. You can't run the tune designed for 20% less air.
It is difficult to drive...
Forum:
11-17-2019, 11:09 PM
66
14,446
Posted By
Certainly shows something out of balance. I'm...
Certainly shows something out of balance. I'm still an amateur at this but lots of experienced people will see it.
Forum:
11-17-2019, 05:31 PM
66
14,446
Posted By
Issues | Warranty | Recalls / TSB Well it is an...
Well it is an "issue".
Forum:
Software Tuning
08-28-2018, 08:36 PM
3
High negative LTFT OFT Stg1 tune
1,876
Posted By
guybo
The STFT were compensating and your total trims...
The STFT were compensating and your total trims were on point. I think it was just the heat. Increase your trigger point
You don't even have to monitor any of this, you're just panicking...
Forum:
Engine, Exhaust, Transmission
08-15-2018, 04:21 PM
29
Looking to buy header - question about exhaust fume smell
13,185
Posted By
FRSBRZGT86FAN
The 6 bolts on the header manifold should be 23...
The 6 bolts on the header manifold should be 23 ft lbs, and the overpipe to header should be 26 ft lbs. I used a torque wrench and re-did them after a week of hard driving, I still highly recommend...
Forum:
08-15-2018, 12:51 PM
29
13,185
Posted By
Trueweltall
The exhaust gaskets that come with the Gruppe-S...
The exhaust gaskets that come with the Gruppe-S header work fine, no need to spend extra money on different gaskets. I am going on over a year with no leaks, just make sure you torque everything...
Forum:
08-15-2018, 12:05 PM
29
13,185
Posted By
D-rek07
Not an issue. Leave the stock FP. You'll be fine
Forum:
Software Tuning
08-15-2018, 11:48 AM
25
Car seems to be pulling timing with OFT v4.03 Stg1
8,451
Posted By
tomm.brz
am at 0.7 doesnt mean 30% of the timings is...
am at 0.7 doesnt mean 30% of the timings is pulled
it s 30% of The ignition advance map (Knock correction A)
we are talking of maximum 3 degrees of timing so dont Know,something less than 10-12cv...
Forum:
08-15-2018, 01:52 AM
29
13,185
Posted By
FRSBRZGT86FAN
That's best, the gruppe-s is basically the tomei....
It won't get into the cabin unless you have an exhaust leak, I recommend buying grimmspeed gaskets and high temp RTV and it'll guarantee no leaks...
Forum:
08-15-2018, 01:48 AM
29
13,185
Posted By
FRSBRZGT86FAN
You're over thinking this, keep stock front pipe...
You're over thinking this, keep stock front pipe and you'll be fine.
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
10:07 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
