follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 6
1
2
3
4
5
Last
Showing results 1 to 30 of 152
Search took
0.30
seconds.
Search:
Posts Made By:
BR-ZED
Forum:
Electronics | Audio | NAV | Infotainment
03-22-2022, 11:44 AM
3
Climate control button part number?
895
Posted By
p1l0t
I think they call it a knob for some reason. $94...
I think they call it a knob for some reason. $94 OEM [emoji38] but maybe after market you can find it cheaper than buying a whole assembly for $100 used. #72363CAxxx where the xxxs may vary by model...
Forum:
Forced Induction
01-25-2021, 04:12 PM
4,981
Edelbrock E-force Owner's thread and FAQs (Frequently Asked Questions)
1,591,123
Posted By
toast
The kit has you leave off the driver side fuel...
The kit has you leave off the driver side fuel injector cover, I made a bracket for the passenger side to mount the ECU to that was aluminum to get rid of the passenger side. Those things are...
Forum:
Forced Induction
01-24-2021, 12:14 PM
4,981
1,591,123
Posted By
toast
I ran a Shorai on my car for two years without...
I ran a Shorai on my car for two years without issue, the last 18 months were with an Edelbrock. Only took it off during ski season when the car would sit outside all day in zero temps. Sold the car...
Forum:
Forced Induction
01-22-2021, 08:09 PM
4,981
1,591,123
Posted By
CSG Mike
The smaller the battery, the more often you'll be...
The smaller the battery, the more often you'll be replacing it.
Forum:
Forced Induction
01-14-2021, 01:10 AM
4,981
1,591,123
Posted By
CSG Mike
I put on enough miles where time hasn't ever been...
I put on enough miles where time hasn't ever been a concern for me.
Forum:
Forced Induction
01-12-2021, 07:52 PM
4,981
1,591,123
Posted By
Irace86.2.0
Just a tip: use Google instead of the search...
Just a tip: use Google instead of the search engine here. Type your key words followed by site:ft86club.com to limit search results to this site.
I run 5w30 because Subaru uses it in all forced...
Forum:
Forced Induction
01-12-2021, 05:10 PM
4,981
1,591,123
Posted By
CSG Mike
300V is readily available via CSG. Literally a...
300V is readily available via CSG. Literally a matter of submit an order, and get a box a few days later (or overnight if you choose to rush it).
The more important part, IMO, is making sure your...
Forum:
Forced Induction
01-12-2021, 09:12 AM
4,981
1,591,123
Posted By
aKaGorganZola
I've run Mobil 1 since I got the car and had no...
I've run Mobil 1 since I got the car and had no issues. My buddy also runs it in his wrx with no issues. As long as you buy a quality full synthetic and stay on top of your intervals i doubt you'll...
Forum:
Forced Induction
09-07-2020, 11:27 PM
4,981
1,591,123
Posted By
AKITA
I sent a pm.. but yeah if they're too big and you...
I sent a pm.. but yeah if they're too big and you might have to anyway.. remove air intake and maybe throttle body.. if so ugh.. changes my opinion maybe a little when you should do this.. because I...
Forum:
Forced Induction
09-07-2020, 12:38 PM
4,981
1,591,123
Posted By
AKITA
No... the passenger Radium used 3/8 hose like...
No... the passenger Radium used 3/8 hose like the one that comes in the Edel kit (driver side uses 1/2 inch which is the same in the Radium kit) .. Like I said it requires some planning and trimming...
Forum:
Forced Induction
09-05-2020, 12:21 AM
4,981
1,591,123
Posted By
AKITA
I had both prior to SC install.. which meant I...
I had both prior to SC install.. which meant I had to cut new hoses..So doing it after is better IMO. Not hard.. A 2 if that on a scale of 10. Just follow radium instructions which are available...
Forum:
Forced Induction
07-31-2020, 12:41 PM
4,981
1,591,123
Posted By
Mad1723
It wont fit without cutting into it. You can...
It wont fit without cutting into it. You can leave it off.
Sent from my Pixel 4 XL using Tapatalk
Forum:
Forced Induction
07-30-2020, 10:38 AM
4,981
1,591,123
Posted By
ArrrBussiere
Thank you, will do! And yeah, I was reading all...
Thank you, will do! And yeah, I was reading all about the issues with them before buying the car and determined it wasn't a big enough issue to turn me away. I fully intend on having to replace it...
Forum:
Forced Induction
07-22-2020, 12:06 PM
4,981
1,591,123
Posted By
AKITA
my bar per logs is .7 over 1 bar at 7300 rpm = 10...
my bar per logs is .7 over 1 bar at 7300 rpm = 10 psi
my bar at idle averages .30 to .25 .. I'm just gonna call it .7 below standard atmospheric press.. -10 psi at idle below so that's a vacuum...
Forum:
Forced Induction
07-22-2020, 11:45 AM
4,981
1,591,123
Posted By
toast
Stock pulley. There are variances in any...
Stock pulley. There are variances in any manufactured system and Zach said my SC had one of the highest outputs he had tuned for the stock pulley so YMMV.
Forum:
Forced Induction
07-22-2020, 09:28 AM
4,981
1,591,123
Posted By
toast
Where in the rpm range are you measuring 6 psi of...
Where in the rpm range are you measuring 6 psi of boost? At 7k I hit a little over 11psi.
Most people misunderstand how boost is created by a roots blower. It generates constant boost only in an...
Forum:
Forced Induction
07-19-2020, 11:55 AM
4,981
1,591,123
Posted By
rixon
I'm from Maryland and there was a lot more E85...
I'm from Maryland and there was a lot more E85 stations around before but E85 got a bad rep. and most stations dropped it.
People were putting E85 in non E85 cars because it was cheaper. The...
Forum:
Forced Induction
07-18-2020, 12:53 PM
4,981
1,591,123
Posted By
Z06ZN6
That makes me thankful to have a few E85 stations...
That makes me thankful to have a few E85 stations reasonably close. I do have to go a little out of my way to get to one but no more than 10-15 minutes. Since more e85 is required and the refuelling...
Forum:
Forced Induction
07-15-2020, 08:57 PM
4,981
1,591,123
Posted By
AKITA
Yeap that was it. I had to find one a little...
Yeap that was it. I had to find one a little bigger and a little thicker gauge. But to add, I looked at my pulley and wiped it after I was through working with DT yesterday while I was continuing to...
Forum:
Forced Induction
07-14-2020, 11:34 AM
4,981
1,591,123
Posted By
AKITA
Good to hear on the fuel pressure... Clearly an...
Good to hear on the fuel pressure... Clearly an idler shouldn't be weeping grease if that's where it came from.. if the grease gets on the belt.. you could slip the belt. I'd clean it and watch it.....
Forum:
Forced Induction
07-09-2020, 10:49 AM
4,981
1,591,123
Posted By
AKITA
In regards to your Ecutek question. I think once...
In regards to your Ecutek question. I think once the dongle ID is mated to the ECU, you can flash any bin that is appropriate for that ECU.
Forum:
Forced Induction
07-08-2020, 06:55 AM
4,981
1,591,123
Posted By
Kodename47
Are you off throttle? With no throttle, no fuel...
Are you off throttle? With no throttle, no fuel is injected so AFR reads max (usually 20.x depending on sensor scaling) and there is no STFT. There can be a max LTFT set in the tune, so may be...
Forum:
Forced Induction
07-07-2020, 11:15 PM
4,981
1,591,123
Posted By
AKITA
I don't know your tune but don't think it should...
I don't know your tune but don't think it should be doing this with any kind of reasonable tune. My initial DT tune did not do any of the things you are experiencing. (However I did run it without...
Forum:
Forced Induction
07-05-2020, 03:32 PM
4,981
1,591,123
Posted By
BA9092
I also had the same issue since I couldn't fill...
I also had the same issue since I couldn't fill the reservoir full enough before it pumped itself dry and stopped the pump. Eventually I got it full and the pump ran continuously.
However, I...
Forum:
Forced Induction
07-05-2020, 03:25 PM
4,981
1,591,123
Posted By
BA9092
BR-ZED... I also had a crowfoot wrench set which...
BR-ZED... I also had a crowfoot wrench set which was really helpful in those tight places where a normal socket wouldn't fit.
Forum:
Forced Induction
07-05-2020, 03:21 PM
4,981
1,591,123
Posted By
BA9092
I used a convoluted setup with various extensions...
I used a convoluted setup with various extensions and attachments since my torque wrench is 24" long and 3/8" drive. I know it's pretty tight down there, but I was able to get the specified 23...
Forum:
Forced Induction
07-05-2020, 02:11 PM
4,981
1,591,123
Posted By
BA9092
I had the same issue. Pull the fuel pump...
Pull the fuel pump fuse and try to start the engine. It usually doesn't start anyway, but it removes any pressure in the lines. Then you should be able to unbolt the fuel...
Forum:
Forced Induction
07-05-2020, 11:06 AM
4,981
1,591,123
Posted By
BirdTRD
For comparison sake, I some logs I took this...
For comparison sake, I some logs I took this morning. The first was with my TMAP relocation block installed in the BPV vacuum line, the second run was with nothing installed for a base line, then the...
Forum:
Forced Induction
07-05-2020, 09:54 AM
4,981
1,591,123
Posted By
BirdTRD
Nah, just fire it up and watch for any obvious...
Nah, just fire it up and watch for any obvious problems like spraying fuel or coolant, then hone in on the fuel system. For the cooling systems, you'll need to get all the air out of them first then...
Forum:
Forced Induction
07-04-2020, 06:15 PM
4,981
1,591,123
Posted By
Side
Installation was successful, for both the...
Installation was successful, for both the Edelbrock and the Jackson Racing DROC.
No real issues or setbacks during install, but my belt hopped a rib and started shredding on the 3rd or 4th drive....
Page 1 of 6
1
2
3
4
5
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine, Exhaust, Transmission
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
02:51 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
