follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Showing results 1 to 21 of 21
Search took
0.30
seconds.
Search:
Posts Made By:
fableluke
Forum:
Engine, Exhaust, Transmission
07-05-2023, 02:51 PM
69
Oil Pressure
18,125
Posted By
blsfrs
Yes, I've swapped transducers and compared both...
Yes, I've swapped transducers and compared both to a manual gauge.
With the oil cooler removed, I have no way to read pressure at the sandwich.
My galley pressures run up to 60-65 psi when hot...
Forum:
07-04-2023, 05:47 PM
69
Oil Pressure
18,125
Posted By
blsfrs
I got my FRS put back together with a new timing...
I got my FRS put back together with a new timing cover. But I still have the same problem: High pressure at the sandwich and low at the galley.
I took the sandwich plate off again, (eliminating...
Forum:
06-18-2023, 05:54 PM
69
Oil Pressure
18,125
Posted By
KillerBMotorsport
To the best of our knowledge, every one of those...
To the best of our knowledge, every one of those was accounted for.
This is an odd conundrum. I'm not super familiar with the AVCS cam seals on the FA engines, but with the EJs they are hit miss...
Forum:
06-18-2023, 11:10 AM
69
Oil Pressure
18,125
Posted By
Breadman
I wouldn't drive on that at all. My IAG block...
I wouldn't drive on that at all. My IAG block made 0psi when i tried to crank it over. It is fixed now but with 10w40 like you said it is nearly 100psi cold start and takes quite a bit of time to...
Forum:
06-15-2023, 01:47 PM
69
Oil Pressure
18,125
Posted By
NoHaveMSG
What are you running for oil? I see 5-7psi at...
What are you running for oil? I see 5-7psi at idle when hot with 0-20. I am running a switch with the GJP box to force fans on full when I pull off track and usually kick them on during my cool down...
Forum:
Scion FR-S / Toyota 86 GT86 General Forum
04-17-2023, 05:54 PM
15
Oil pump question for the mechanics
4,984
Posted By
KillerBMotorsport
What is the mileage on that pump assembly? Looks...
What is the mileage on that pump assembly? Looks to be some decent scoring. How do the rotor faces (teeth) look?
The bypass should move smoothly. Not somewhat smoothly, it should be smooth. It...
Forum:
Issues | Warranty | Recalls / TSB
02-21-2023, 12:39 PM
11
P0455 - Large evap leak
2,472
Posted By
jrhudson
an attempt to feel smart it looks like here. lol
Forum:
01-19-2023, 10:04 PM
50
Gen 2 Transmission in a Gen 1 Car
11,352
Posted By
Irace86.2.0
So my gen 2 tranny had a few hundred miles I was...
So my gen 2 tranny had a few hundred miles I was told, and it looked brand new. It is paired with MTEC springs, Whiteline trans bushing, Kpower linkage, South Bend Endurance clutch, Verus forged fork...
Forum:
01-12-2023, 02:08 PM
50
11,352
Posted By
Irace86.2.0
The other factors that are worth mentioning could...
The other factors that are worth mentioning could be sintered/ceramic 4-6 puck-style clutches that grab abruptly/harshly and things like a supercharger versus a turbo. In the former case, I have a...
Forum:
01-12-2023, 01:27 PM
50
11,352
Posted By
RedReplicant
His (Jack's) 4th gear collar can still loosen up,...
His (Jack's) 4th gear collar can still loosen up, wear against the teeth, develop play, and allow movement.
https://i.imgur.com/DLyhpUL.jpg
Eventually you get the overtravel
Forum:
01-12-2023, 01:05 AM
50
11,352
Posted By
Irace86.2.0
I just did the gen 2 swap because it was the...
I just did the gen 2 swap because it was the cheapest and fastest swap for now to get me into something newer and slightly stronger. Everything bolts right up. I swapped the MTEC springs, Verus...
Forum:
11-09-2022, 01:35 AM
50
11,352
Posted By
bhmax
Yep. All the same.
Yep. All the same.
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
11-23-2021, 12:28 PM
11
2nd gen vs 1st gen Subaru OEM part numbers - comparison
3,452
Posted By
Racecomp Engineering
I've been digging through the suspension parts diagrams for the 2nd gen cars and thought I'd post some notes. Some things are the same, some things are different, some things need more research.
I...
Forum:
11-20-2021, 04:49 AM
12
My FA20 NA Dyno Results and Analysis - Stock, 98 RON, and E85
6,464
Posted By
pt1878
Hi all, sent my car for a tune on 98 RON (Aus) (which is apparently equal to 93 over in the US) back 9 months ago. Just got it retuned for E85 (and flex). All in all, very happy with the results from...
Forum:
11-14-2021, 12:33 PM
75
New motor starts then dies.
17,365
Posted By
jrhudson
Not really sure why i had the issues i had, but...
Not really sure why i had the issues i had, but they've been resolved, I think. Giving an update to give this thread to give it closure, so-to-speak.
Only thing i suspect is, i still had somewhat...
Forum:
09-16-2021, 09:17 PM
28
Oil Cooler with Fan - Experiences
3,659
Posted By
whataboutbob
Here's some shots of one I fabbed up. Added a...
Here's some shots of one I fabbed up. Added a small SPAL fan on a switch relay setup, but don't have the photos...
Forum:
Software Tuning
09-12-2021, 09:05 PM
13
ECUTek and Bluetooth Tunning
2,398
Posted By
DarkPira7e
Being able to datalog from a mobile device is...
Being able to datalog from a mobile device is worth the convenience alone.
Forum:
08-20-2021, 12:35 PM
11
Direct injectors installation issues.
4,113
Posted By
CSG Mike
Looks like you hulked the injector by quite a bit...
Looks like you hulked the injector by quite a bit to flare the seal that much.
1. clean out the injector hole thoroughly
2. use a VERY light amount of lube. Bare minimum to make it slightly...
Forum:
11-04-2020, 10:12 PM
149
Whiteline differential insert bushings review
67,667
Posted By
airrick
necro post. Dont yell at me. Just wanted to...
necro post. Dont yell at me. Just wanted to clarify some stuff and a small review.
TLDR;
with all diff bushings alot of added NVH more than i thought there would be. Started to feel like track...
Forum:
03-21-2015, 07:12 PM
69
oil pressure gauge
68,808
Posted By
Kirby64
You can toss the stock oil pressure sensor and...
You can toss the stock oil pressure sensor and just tuck away the stock sender line. No need to ground it at all. I tossed mine and tucked the wire, installed a real pressure gauge in the same spot...
Forum:
DIY (Do-It-Yourself) Guides
12-21-2012, 11:21 AM
15
where to tap into 12v accessory power under dash?
23,672
Posted By
BRZ-y
Forgot to take pics of the finished layout....
Forgot to take pics of the finished layout. Thanks for all your advice guys. I ended up using the fuse tap on the radio circuit. Wasn't sure which bolt Foobar was referring to for ground, so I ran...
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
01:37 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
