follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 4
1
2
3
4
Showing results 1 to 30 of 109
Search took
0.01
seconds.
Search:
Posts Made By:
stevo585
Forum:
Engine, Exhaust, Transmission
08-14-2018, 08:55 PM
34
Engine Cooling options
6,525
Posted By
stevo585
Absolutely a myth. At some point the VVT would be...
Absolutely a myth. At some point the VVT would be sluggish or get CEL maybe. That's if say an 0w-40 in cold temps. On the track it be thin enough to be fine. Remember the WRX is essential the same...
Forum:
Forced Induction
10-24-2017, 10:21 PM
29
Boost supporting mods for the street
11,708
Posted By
stevo585
I run zero supporting mods. I just watch oil and...
I run zero supporting mods. I just watch oil and coolant temps. I run a 30wt oil though. Stock clutch still holding ok. Tuned to near perfection.
Forum:
Forced Induction
05-20-2017, 10:41 PM
28
Water/methanol or flex fuel
9,711
Posted By
stevo585
WM injection is also a lot cheaper than FF up...
WM injection is also a lot cheaper than FF up front. Probably about 50% cheaper as you need FF kit + injectors + fuel pump to run e85.
Forum:
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
04-21-2017, 07:35 PM
29
Used Oil Analysis @ 51k miles
7,914
Posted By
stevo585
With the longer drain intervals its not the TBN...
With the longer drain intervals its not the TBN to worry about it the oil shearing too low or out of grade. The OP's shows 6.5 cst which is on the low side on a 20wt. That's way too thin IMO.
Forum:
Issues | Warranty | Recalls / TSB
04-09-2017, 11:23 PM
96
P0018 - what a disappointment this car has become
32,997
Posted By
stevo585
IAM = ignition advance multiplier. That means...
IAM = ignition advance multiplier. That means full timing. Which is around 20 degrees iirc in the stock map.
If my local fuel was that bad Id blend with toluene or some other octane booster like...
Forum:
Forced Induction
03-22-2017, 09:26 PM
30
Skunk 2 Forged Rods?
14,264
Posted By
stevo585
Isnt safe to say that *any* forged rod will be...
Isnt safe to say that *any* forged rod will be better than oem by far? Why all the worry?
Forum:
Forced Induction
02-25-2017, 10:28 PM
79
new JDL turbo kit price?
38,698
Posted By
stevo585
Support American manufacturing! ;)
Forum:
Engine Swaps
01-15-2017, 12:12 AM
139
3S-GE BEAMS swap
111,393
Posted By
stevo585
So you swapped an NA 200hp motor for a 200hp NA...
So you swapped an NA 200hp motor for a 200hp NA motor seems hmm
Forum:
Forced Induction
12-08-2016, 10:11 PM
11,295
Full throttle Electric Supercharger Build Thread
3,460,720
Posted By
stevo585
It is true it is essentially a non-existent...
It is true it is essentially a non-existent product. The "wait list" is kinda irrelevant too.
I was going to do a twin setup but I know Ill likely never get another kit.
So I may...
Forum:
Forced Induction
11-30-2016, 09:22 PM
11,295
3,460,720
Posted By
stevo585
Well I'm in the top quarter and I have been on...
Well I'm in the top quarter and I have been on the list since April 2015. So thats 18 or so months already.
I already have a used kit but I want a twin setup for shits and giggles.
Forum:
Forced Induction
10-14-2016, 12:43 PM
11,295
3,460,720
Posted By
stevo585
Looks like that extra psi up top will be good for...
Looks like that extra psi up top will be good for an extra 10-20whp.
Forum:
08-12-2016, 02:00 PM
31
$189 EBay Cat Back - Eh? Not too bad actually.
7,327
Posted By
stevo585
304 is 304. I use it pretty much daily at work....
304 is 304. I use it pretty much daily at work. The difference in quality is usually the lack of passivation or other secondary treatments. It will last just fine. Like any brand name you pay for the...
Forum:
08-12-2016, 10:05 AM
31
7,327
Posted By
stevo585
Yes I have noticed surface rust on the asian made...
Yes I have noticed surface rust on the asian made cheap exhausts. They usually use 201 SS that's not passivated as you tell by surface spot rust. However in my experience some blue magic can clean...
Forum:
Forced Induction
08-11-2016, 12:03 AM
1,206
Phantom FTS Electric Supercharger Owners Thread
362,117
Posted By
stevo585
Really? I activate mine all the time. A least a...
Really? I activate mine all the time. A least a few times a day. Just quick 3-5 second bursts.
Forum:
Forced Induction
08-01-2016, 04:10 PM
1,206
362,117
Posted By
stevo585
Wow how do you have so much boost? That's the V2...
Wow how do you have so much boost? That's the V2 TQ250 right?
Forum:
Forced Induction
07-19-2016, 09:59 PM
32
Best Supercharger for my Driving
15,663
Posted By
stevo585
I have the ESC kit its pretty good for the price...
I have the ESC kit its pretty good for the price - used. Not sure about full price of 2100 + tune. Also dont need any supporting mods other than a tune. Gives a modest 40hp and 70lb tq maybe a bit...
Forum:
Forced Induction
07-12-2016, 03:36 PM
11,295
3,460,720
Posted By
stevo585
I did say "not sure if they...". I could have...
I did say "not sure if they...". I could have said "Those guys never rode...". So you know I was unsure and trying to be passive but I get your point. Now I understand you have experience. But as you...
Forum:
Forced Induction
07-11-2016, 10:57 PM
11,295
3,460,720
Posted By
stevo585
I think in reality this is all irrelevant to the...
I think in reality this is all irrelevant to the OP because you can't buy the kit anyways. What is the wait list time? Close to 2 years now I assume. Its been 16 months for me and I'm still about...
Forum:
Forced Induction
07-11-2016, 04:27 PM
11,295
3,460,720
Posted By
stevo585
Wow that is a big difference between V1 and the...
Wow that is a big difference between V1 and the latest at least up top. Looking at the torque app boost is very dependent of atmospheric conditions.
I seem to not have your issues though. Hot and...
Forum:
Forced Induction
07-11-2016, 02:54 PM
11,295
3,460,720
Posted By
stevo585
I know you and I'm local. Next time at a CF86...
I know you and I'm local. Next time at a CF86 meet I'll take you out. I really don't think you'll be that impressed though in this summer heat it really kills performance. What he said about keeping...
Forum:
Forced Induction
06-29-2016, 09:24 PM
1,206
362,117
Posted By
stevo585
Yeah even 20-30 seconds is alot! I'm always 3-10...
Yeah even 20-30 seconds is alot! I'm always 3-10 seconds on the street. At just 13.8 seconds I'm already at 101 mph...
Forum:
Forced Induction
05-27-2016, 12:19 AM
8
Vortech V3 with 3.12 pulley, what supporting mods do I need?
3,144
Posted By
stevo585
ok well 235 isnt crazy if your on a 5w30wt oil....
ok well 235 isnt crazy if your on a 5w30wt oil. On a 0w20 thats going to be sub optimal oil pressure.
Forum:
05-26-2016, 09:55 PM
683
In for the long haul Ultimate NA build thread.
364,894
Posted By
stevo585
Right thats similar to investment casting (lost...
Right thats similar to investment casting (lost wax).
Forum:
05-24-2016, 09:02 PM
683
364,894
Posted By
stevo585
Graphite or sand cast them and make a side...
Graphite or sand cast them and make a side business. :D Laser the flanges and weld them.
Those flutes/runners machined are going to be expensive as hell though for a one off. I would guess...
Forum:
Forced Induction
05-09-2016, 10:50 PM
1,206
362,117
Posted By
stevo585
It was probably wheel hop as I did a dry burnout....
It was probably wheel hop as I did a dry burnout. Then bogged even after a 4k launch.
14.2 @ 99.5. Too warm kills performance I have done much better in cool weather. I also was only 2.3 on the 60...
Forum:
Forced Induction
05-08-2016, 11:08 PM
1,206
362,117
Posted By
stevo585
1/4 mile pass this friday May 6th. track run 1...
track run 1 - YouTube
Forum:
Tracking / Autocross / HPDE / Drifting
05-02-2016, 11:22 PM
420
Sticky:
Track Brake Pad Discussion Thread
231,756
Posted By
stevo585
Whats a good pad for a novice just into HDPE's? I...
Whats a good pad for a novice just into HDPE's? I plan on swapping to torque 700 brake fluid....overkill? Recommend a good fluid? Thanks.
Forum:
Forced Induction
04-20-2016, 08:22 PM
1,206
362,117
Posted By
stevo585
"If the ESC is turned off, technically it would...
"If the ESC is turned off, technically it would cause a slight air restriction, but likely nothing that would be of consequence".
Not exactly. My MAF was off 10% with it installed when I did my...
Forum:
Forced Induction
04-07-2016, 03:39 PM
1,206
362,117
Posted By
stevo585
No.. its not for sale :D ...sorry maybe in a...
No.. its not for sale :D ...sorry maybe in a year. Not sure I want to put 5k+ into this car that ill never get back.
Forum:
Forced Induction
04-06-2016, 08:17 PM
1,206
362,117
Posted By
stevo585
I actually have a first year kit. It's used....
I actually have a first year kit. It's used. Unlike most I run a custom Ecutek street tune with both 93 and 2x e85 maps saved in the ecu. Otherwise my setup is in my sig. I do have a stock catback...
Page 1 of 4
1
2
3
4
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
07:47 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
