Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Search Forums
Showing results 1 to 30 of 37
Search took 0.01 seconds.
Search: Posts Made By: AussieBRZ
Forum: Software Tuning 04-20-2025, 12:23 AM
Posted By AussieBRZ
You can modify the old tune but not any of the...
You can modify the old tune but not any of the restricted settings they are locked out in new ecutek software
Forum: Software Tuning 03-08-2024, 06:02 AM
Posted By AussieBRZ
OFT will work fine with the greedy kit up to...
OFT will work fine with the greedy kit up to about 10 psi or so if you still have OFT and it's a 2012-021 cc ar
Forum: Software Tuning 12-04-2023, 06:25 AM
Posted By AussieBRZ
Can be done but bit of a process and you will...
Can be done but bit of a process and you will need a tactrix and you need copy of current boost tune and an ecutek cable kit.
Forum: Software Tuning 11-15-2023, 05:58 PM
Posted By AussieBRZ
I've used this scaling here on all cars 2012-2021...
Works well
https://www.ft86club.com/forums/showthread.php?t=82875
Forum: Software Tuning 11-15-2023, 05:53 PM
Posted By AussieBRZ
It's possible to tune turbos with opensource like...
It's possible to tune turbos with opensource like tactrix or oft but it's a lot easier with ecutek.
It is possible to transition to a non USA rom in USA car but you would need a tactrix cable to...
Forum: Software Tuning 10-21-2023, 07:30 PM
Posted By AussieBRZ
Yes if you ant to use ecutek for catless header...
Yes if you ant to use ecutek for catless header then you will need to convert to euro rom beforehand or you won't be able to disable emmissions codes like P0420.
Also if you not planning on flex...
Forum: Software Tuning 10-13-2023, 11:16 PM
Posted By AussieBRZ
Try doing pedal dance ...
https://m.youtube.com/watch?v=CWXv7UNA7hg
Or search pedal dance on this forum
Forum: Engine, Exhaust, Transmission 10-05-2023, 02:25 AM
Posted By AussieBRZ
We If car is ecutek tuned I'd say tuner...
We
If car is ecutek tuned I'd say tuner has activated flat foot shift feature, whan you clutch kick it won't let the rpm increase of current rpm.
Fix will be to disable flat foot shift...
Forum: Software Tuning 10-05-2023, 02:13 AM
Posted By AussieBRZ
If your just swapping out the engine ECU for a...
If your just swapping out the engine ECU for a motec or similar they don't usually need to be synced into the other modules in car.
The standard ECU need to sync with the key receivers keys...
Forum: Forced Induction 09-21-2023, 08:42 AM
Posted By AussieBRZ
If your tuner didn't rescale for the Harrop...
If your tuner didn't rescale for the Harrop intake air temp sensor it won't read correctly this can also cause some issues with tune especially if it's using speed density
Forum: Software Tuning 08-20-2023, 04:56 AM
Posted By AussieBRZ
No your good as gold at present. Ecutek...
Ecutek updates just stop you creating new tunes on USA ROMs that disable emmissions systems like rear O2 or evap flex kits or evap purge boost control or...
Forum: Software Tuning 08-08-2023, 07:30 AM
Posted By AussieBRZ
Definition with the extra tables here ...
https://www.ft86club.com/forums/showthread.php?p=3060187
Steve99
Some say his ghost is still haunts these forums
Forum: Software Tuning 06-29-2023, 07:20 AM
Posted By AussieBRZ
Thanks I have a bench flash setup and can test...
Thanks
I have a bench flash setup and can test flash this to my bench ECU
Would you have the K00G definition for romraider with the added tables for the SD ?
I can probably work out the...
Forum: Forced Induction 06-27-2023, 06:22 PM
Posted By AussieBRZ
Check the bracket bolts on di computer as well...
Check the bracket bolts on di computer as well see photo
Forum: Forced Induction 06-26-2023, 09:01 PM
Posted By AussieBRZ
Yes seems strange usually di fuel pressure failry...
Yes seems strange usually di fuel pressure failry steady 3 to 4 MPa at idle
Check the grounds on the DI computer under Bonnett all three bolts in and tight
Also it might be the di fuel...
Forum: Software Tuning 06-19-2023, 06:50 AM
Posted By AussieBRZ
Car manufacturers will very rarely include...
Car manufacturers will very rarely include sensors that are not necessary for correct operation, the oil temp sensor is there for a reason, there are many unknown tables or functions in he ECU...
Forum: Software Tuning 06-17-2023, 07:52 AM
Posted By AussieBRZ
ECU is pretty easy to replace if you get one from...
ECU is pretty easy to replace if you get one from same year car same transmission
Otherwise you can reflash the replacement ECU with tactrix
Oft is not good at recovery tactrix is a bit...
Forum: Software Tuning 06-07-2023, 08:53 PM
Posted By AussieBRZ
Yes unlikely anything with fueling will change...
Yes unlikely anything with fueling will change tune will still target same afr and timeing dependant on load and boost
The catless header will generally increase spool and in some cases could...
Forum: Software Tuning 06-07-2023, 12:12 AM
Posted By AussieBRZ
If header was already catless then it's likely ok...
If header was already catless then it's likely ok it may make turbo spool a little different and possibly hit boost limiter but unlikely just log data and check but should be fine
Forum: Software Tuning 06-04-2023, 05:02 AM
Posted By AussieBRZ
CVN is the checksum verification number ...
It's used during emmissions checks or by dealers to determine if the contents of the ECU or engine computer are stock and un touched.
Each...
Forum: Software Tuning 05-02-2023, 05:54 AM
Posted By AussieBRZ
ID 1050 injectors are good quality they should...
ID 1050 injectors are good quality they should start and run ok, might not be as smooth as the stock injectors but should not be terrible. I'd say the injector setting need some more work. Car cranks...
Forum: Software Tuning 04-03-2023, 07:14 AM
Posted By AussieBRZ
Ok Compare the log when you blip the...
Ok
Compare the log when you blip the throttle and it doesn't stall to when you blip the throttle and it stalls
Most things seem the same port zero direct injection about 0.9, fuel rail...
Forum: Engine, Exhaust, Transmission 03-20-2023, 04:14 AM
Posted By AussieBRZ
Ok in the log at idle with no throttle the target...
Ok in the log at idle with no throttle the target afr is round 14.7 which it should be, but the actual afr or measured afr varies rich to lean. This seems bogus as in a few places the actual afr is...
Forum: Software Tuning 03-12-2023, 05:43 PM
Posted By AussieBRZ
As long as you change the new ecu vin number to...
As long as you change the new ecu vin number to same as your original vin number that the oft was married to oft will work
Forum: Software Tuning 02-12-2023, 08:14 AM
Posted By AussieBRZ
Oft V4 tunes are based on European ROMs a A00D...
Oft V4 tunes are based on European ROMs a A00D oft tune will actually be a euro A01I based tune which has the important updates same as a B01D
Oft doesn't let you update the stock rom only...
Forum: Software Tuning 02-12-2023, 08:05 AM
Posted By AussieBRZ
Go to Openflash manager and see if you can update...
Go to Openflash manager and see if you can update oft again, somtimes they come good after second update.
If not try erasing oft, then remarry to car, but your current tune will become what oft...
Forum: Software Tuning 01-26-2023, 08:04 AM
Posted By AussieBRZ
If you want a smooth rev limiter then you need to...
If you want a smooth rev limiter then you need to have the ignition retard limiter limit the refs rarther than the fuel cut limiter that is rev limiter A and B.
So have the ignition retard...
Forum: Software Tuning 11-21-2022, 07:29 AM
Posted By AussieBRZ
You got it already emtron or motec, both good but...
You got it already emtron or motec, both good but expensive
I know motec comes with a get you going map, and I suspect emtron does as well. They won't be stock maps though, as they run...
Forum: Software Tuning 10-04-2022, 06:16 PM
Posted By AussieBRZ
Physically connecting to the stock AFR sensor to...
Physically connecting to the stock AFR sensor to run a physical afr giage is likely to cause issues as the second connection is likely to cause voltage or current changes and effect the readings from...
Forum: Software Tuning 09-22-2022, 04:03 AM
Posted By AussieBRZ
Try ...
Try
https://www.facebook.com/profile.php?id=100009796213855
