Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Search Forums
Showing results 1 to 30 of 79
Search took 0.00 seconds.
Search: Posts Made By: JD86
Forum: Forced Induction 06-13-2017, 02:42 AM
Posted By JD86
These guys have, and track tested. Seems to work....
These guys have, and track tested. Seems to work. I have mine sitting in a box with a bunch of other parts waiting for me to get my act together and install them.
Forum: Forced Induction 03-20-2017, 12:42 AM
Posted By JD86
I've seen a few different ones fitted. As above...
I've seen a few different ones fitted. As above it's a standard Greddy/Garret flange. However with a little bit of exhaust modification the sky is the limit. One in aus was running a blouche 3076...
Forum: Cosmetic Modification (Interior/Exterior/Lighting) 04-19-2016, 12:36 AM
Posted By JD86
Where are you getting your info from? Their page...
Where are you getting your info from? Their page still shows prototypes as of the start of this month.
I got bored of waiting for them so made my own.
Forum: Forced Induction 04-02-2016, 03:01 AM
Posted By JD86
My memory is a little vague on stage 1.5 but the...
My memory is a little vague on stage 1.5 but the rest went something like this.
Stage 1. Basic turbo kit 5psi actuator ends at over pipe.
Stage 2. As above, plus 8psi actuator, plus full 2.5 inch...
Forum: Cosmetic Modification (Interior/Exterior/Lighting) 10-07-2015, 01:04 AM
Posted By JD86
Can't help you on that one mate, sorry. Have you...
Can't help you on that one mate, sorry. Have you tried contacting them? I'm going to Sema this year so will keep an eye out for them.
But I wasn't waiting for them as I have my own solution to the...
Forum: Cosmetic Modification (Interior/Exterior/Lighting) 09-22-2015, 04:26 AM
Posted By JD86
I feel as though that needs a matching front...
I feel as though that needs a matching front spoiler. Like this.
120874
Forum: Cosmetic Modification (Interior/Exterior/Lighting) 08-29-2015, 04:28 AM
Posted By JD86
Got to the fb link I posted and look at their...
Got to the fb link I posted and look at their estimated price. They have said scion one will be about $1000us. The $9999 is their isnt us dollars, seeing as the website is in chinese I'd guess it's...
Forum: Cosmetic Modification (Interior/Exterior/Lighting) 08-27-2015, 02:14 AM
Posted By JD86
I'll see your gauge pods and raise you the DTM...
I'll see your gauge pods and raise you the DTM iMeter.
118884
118885
Actually a little mad that they've finished that as I am finishing off something very similar for my Motec C127. Their...
Forum: Forced Induction 06-30-2015, 07:47 AM
Posted By JD86
A few of you have asked about the "stage 4"...
A few of you have asked about the "stage 4" turbo... This is it. I believe they use the stage 3 turbo as a base. So billet wheel and then it looks to be a modified housing with a bigger wastegate...
Forum: Forced Induction 06-28-2015, 07:04 AM
Posted By JD86
As above, cut the BOV hose, doesn't need to take...
As above, cut the BOV hose, doesn't need to take much off, maybe an inch or so... Cable tie around the intake hose to turbo hose. No problems since.
Forum: Forced Induction 06-23-2015, 03:29 AM
Posted By JD86
I was having the inlet hose come off repeatedly...
I was having the inlet hose come off repeatedly to the point the fan belt ate a hole in it and I had to replace it. When I did the replacement we made a few changes. We trimmed the BOV pipe as this...
Forum: Forced Induction 06-08-2015, 01:17 PM
Posted By JD86
2 Inch coming from the turbo, 2.5 inch leading to...
2 Inch coming from the turbo, 2.5 inch leading to the inlet. Stage 4 is 2.5 on both sides.
Forum: Forced Induction 05-30-2015, 07:42 AM
Posted By JD86
There's been avo kits in aus fitted with GTX2867...
There's been avo kits in aus fitted with GTX2867 and GTX3076, don't have numbers on either sorry. The boys at high performance academy in nz switched out their turbo with a borg warner efr. In all...
Forum: Cosmetic Modification (Interior/Exterior/Lighting) 05-14-2015, 11:53 PM
Posted By JD86
So hang on, the kit is just the standard quick...
So hang on, the kit is just the standard quick latch minis with an angled washer to position them correctly?!? Also no instructions yet? Is there anything to align the holes correctly in the bumper...
Forum: Cosmetic Modification (Interior/Exterior/Lighting) 05-08-2015, 02:28 AM
Posted By JD86
You can get them from STI in Japan, however you'd...
You can get them from STI in Japan, however you'd normally source your sti parts in the states. They'll be grey leather and embossed with sti logo if you do that. Or you can get them direct from your...
Forum: Forced Induction 05-07-2015, 12:56 AM
Posted By JD86
Call them and ask nicely! I got my tracking...
Call them and ask nicely! I got my tracking number to say that stage 4 turbo/pipes/water bottle had been shipped to me yesterday. I already have a larger intercooler from a company called Hypertune...
Forum: Cosmetic Modification (Interior/Exterior/Lighting) 03-24-2015, 03:08 AM
Posted By JD86
Recaro Sportster CS
Probably should have posted these in November when I installed them. Recaro Sportster CS's in black leather and alcantara with airbags. These are the OEM equipment from the Japanese STI TS model...
Forum: Cosmetic Modification (Interior/Exterior/Lighting) 12-21-2014, 10:54 AM
Posted By JD86
And now for something a little different from the...
And now for something a little different from the land down under...
Styling isn't quite done, still waiting on the skirts to be wrapped and my car is a little bit of a mix and match. But I like...
Forum: Forced Induction 12-06-2014, 11:32 PM
Posted By JD86
What Protbipe said. They're a reasonably standard...
What Protbipe said. They're a reasonably standard gasket, I'm running Garrett ones... They're an unusual shape, you'll know it if you see them. I think what you need is the compressor outlet from a...
Forum: Forced Induction 11-13-2014, 04:26 AM
Posted By JD86
Yes, but not because of alignment or fitment of...
Yes, but not because of alignment or fitment of the pipe clashing with the pulley. I had a few issues with that pipe coming off the turbo. It was nothing a new pipe clamp and some cable ties couldn't...
Forum: Forced Induction 09-27-2014, 01:51 PM
Posted By JD86
As I said it's personal preference. I went to the...
As I said it's personal preference. I went to the Radium catch cans as I wanted to clean up the front of my engine bay and I didn't particularly like removing the AVO catch can when I had to empty it...
Forum: Forced Induction 09-25-2014, 01:55 AM
Posted By JD86
Third AVO turbo?!?
For those that haven't seen it yet, it appears AVO is testing a third turbo for our car on their Japanese vehicle. No word on power figures etc yet but it's larger than the stage 3 billet option and...
Forum: Forced Induction 09-25-2014, 01:35 AM
Posted By JD86
I'm running the dual radium catch cans... and the...
I'm running the dual radium catch cans... and the AVO air/oil separator off the oil reservoir.
As to what's needed... it's debateable and comes down to personal prefernce. I chose both as I get a...
Forum: Forced Induction 09-19-2014, 11:13 AM
Posted By JD86
Negative to the big TRD intake box working. If...
Negative to the big TRD intake box working. If you want a different intake you need to choose one that works with the stock airbox location. Mishimoto and Perrin are proven to work. I think Greddy...
Forum: Forced Induction 08-13-2014, 12:50 AM
Posted By JD86
Yes and No. I did a quick fit to get it on before...
Yes and No. I did a quick fit to get it on before a retune. So it's not a precision fit at the moment just squeezed in. I have the whole lot pushed up tight to the left of the engine bay and I'm not...
Forum: Forced Induction 08-12-2014, 04:00 AM
Posted By JD86
Haha cheers mate, but after two terrible...
Haha cheers mate, but after two terrible experiences with Venders on here (who are no longer here because I wasn't the only one receiving suspect service from them) I decided on a local tuner. At...
Forum: Forced Induction 08-12-2014, 02:07 AM
Posted By JD86
I wouldn't have bothered with remote tuning....
I wouldn't have bothered with remote tuning. Between remote tuners like Visconti and the ECUtek tuners that are available where I am not being all that great I blew close to $6 grand and was still...
Forum: Forced Induction 08-12-2014, 01:55 AM
Posted By JD86
I can confirm 100% that the mishimoto works with...
I can confirm 100% that the mishimoto works with the AVO kit. I'm running it at the moment on my car.
I chose it over the Perrin due to the larger pipe diameter pipe (although I believe perrin now...
Forum: Cosmetic Modification (Interior/Exterior/Lighting) 08-05-2014, 02:33 AM
Posted By JD86
West Australia... Been there done that!
We've got a WRB BRZ with Toyota front end in West Australia. There's more plans for that one, but the owner is keeping it as a Subaru.
There is another WRB in the works at the moment that is doing...
Forum: Cosmetic Modification (Interior/Exterior/Lighting) 08-04-2014, 03:40 AM
Posted By JD86
Powerhouse Amuse Carbon Bonnet
I don't think I've seen these up in here yet. Powerhouse Amuse Carbon Fibre vented bonnet. I don't have any details sorry, try Bulletproof. I'm really hoping the fact that they have this up means...
