follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Go to Page...
Sign Up
Page 1 of 4
1
2
3
4
Showing results 1 to 30 of 111
Search took
0.01
seconds.
Search:
Posts Made By:
15limited
Forum:
Tracking / Autocross / HPDE / Drifting
06-05-2019, 05:17 PM
18
Has anyone been able to A/B a PP versus tS?
8,195
Posted By
15limited
Its oem aero, man. You're just comparing trim...
Its oem aero, man. You're just comparing trim packages at this point, same chassis. Honestly I dont think either package is worth any more than a stock 86 or brz [emoji2369]
Sent from my SM-G950U...
Forum:
05-29-2019, 06:07 PM
17
When to use a higher pressure rad cap?
4,089
Posted By
15limited
A cap ain't gunna make ya or break ya. Sent...
Sent from my SM-G950U using Tapatalk
Forum:
05-09-2019, 08:55 PM
42
To help people who wanna to change a seat
10,221
Posted By
15limited
Reading the first couple steps makes my head hurt...
Forum:
04-02-2019, 09:47 AM
25
Has anyone tracked on 'plasti-dip' coated wheels?
7,662
Posted By
15limited
You cant even compare professional...
You cant even compare professional sandblasting/powder coating compared to driveway plastidip, no matter how much easier it is. Gotta pay to play or look just like the others.
Sent from my...
Forum:
DIY (Do-It-Yourself) Guides
03-11-2019, 05:49 PM
242
How To: Free Clutch Spring Removal in 15 Minutes - A must do for manual trans!
143,464
Posted By
15limited
This has been done for years, probably by the...
This has been done for years, probably by the hundreds. Let's not be neurotic about a 10 minute removal/install DIY.
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
02-14-2019, 07:28 PM
57
Subframe mount inserts choice
18,368
Posted By
15limited
Daily driver? It all comes down to you, man. How...
Daily driver? It all comes down to you, man. How hardcore are you? I drove solid subframe and diff mount along with all kinds of other "track" parts a hundred or so miles everyday for months. Some of...
Forum:
Northwest
02-07-2019, 10:22 AM
15
Clutch during valve spring recall $1100?
4,077
Posted By
15limited
You forgot "uphill, in the snow, both ways" ...
Forum:
12-27-2018, 02:22 AM
57
18,368
Posted By
15limited
I used Voodoo 13 solid inserts, and theres small...
I used Voodoo 13 solid inserts, and theres small amounts of adjustment in suspension geometry, in my subjective opinion the car seemed to sit a little lower in the rear after install.
Yes solid is...
Forum:
Engine, Exhaust, Transmission
07-20-2018, 11:36 AM
40
Does this exists?
6,132
Posted By
15limited
Yeah but its 61mm Sent from my SM-G950U...
Yeah but its 61mm
Forum:
07-19-2018, 08:49 AM
40
Does this exists?
6,132
Posted By
15limited
I hope the only exhaust you can find for any car...
I hope the only exhaust you can find for any car forever only comes in 63mm.
Forum:
07-18-2018, 09:02 AM
40
Does this exists?
6,132
Posted By
15limited
So to answer your question, No. An axleback or...
So to answer your question, No. An axleback or catback doesnt exist that's going to be "quiet" when you exclude the sections that make it quiet. And 3mm increase diameter in piping isnt going to make...
Forum:
Wheels | Tires | Spacers | Hub --
Sponsored by The Tire Rack
06-12-2018, 09:06 AM
4,468
Sticky:
Will this fit? (width, offset and tire size Qs)
1,569,448
Posted By
15limited
I ran 245/45, 245/40 stock dampers and was really...
I ran 245/45, 245/40 stock dampers and was really close to the spring perch, with maxed out camber bolts, super down drop springs. Then ran 255/40 with coilovers on the same wheels,but now I'm on...
Forum:
06-11-2018, 08:51 AM
4,468
Sticky:
1,569,448
Posted By
15limited
All of those will fit with gobs of extra room. ...
Forum:
06-07-2018, 10:59 PM
4,468
Sticky:
1,569,448
Posted By
15limited
It's just butts to nuts in 245 flavor, Compared...
It's just butts to nuts in 245 flavor, Compared to 35 or 45 ratio
Forum:
06-04-2018, 09:41 AM
4,468
Sticky:
1,569,448
Posted By
15limited
So they're "too tall" for you, not the car. And...
So they're "too tall" for you, not the car. And 235/45 aren't 2-3 inches taller than stock mpss
Forum:
06-01-2018, 08:34 PM
2,550
Meaty Tire Thread
1,859,232
Posted By
15limited
He meant Performance package "PP", relating to...
He meant Performance package "PP", relating to fitment that package comes with brembos and Sachs dampers, which might have a smaller spring perch? Common rub point in the front is on the oem spring...
Forum:
05-28-2018, 04:06 AM
4,468
Sticky:
1,569,448
Posted By
15limited
Compound compound compound. Traction issue solved...
Forum:
05-28-2018, 04:03 AM
2,550
Meaty Tire Thread
1,859,232
Posted By
15limited
Meaty 265/35/18 falkens Sent from my...
Meaty
265/35/18 falkens
https://uploads.tapatalk-cdn.com/20180528/b50696a60e1b03454844d2b79e544399.jpg
Forum:
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
05-23-2018, 08:10 PM
13
Fr-s with Titan 7 / Brembo / Greddy
10,604
Posted By
15limited
They do rub a little bit at full lock on the...
They do rub a little bit at full lock on the inner fenderwell with 265/35's and lowered about 1.5" on coilovers, I'm fairly confident with some camber and a 3 or 5 mm spacer it would clear lock to...
Forum:
05-23-2018, 01:33 AM
13
10,604
Posted By
15limited
BBK and titan 7s are legit ...
https://uploads.tapatalk-cdn.com/20180523/45194795e1552c3b668ad9f6875850cb.jpg
Forum:
05-23-2018, 01:27 AM
397
Wheel Directory: WedsSport TC105N 17x9.0 +35
338,737
Posted By
15limited
17×9...
17×9 DGMhttps://uploads.tapatalk-cdn.com/20180523/9fc6b96fdd9ff0ccab5de17a0b05f534.jpghttps://uploads.tapatalk-cdn.com/20180523/05c79e460199b6bc518902e09c6e3356.jpg
Sent from my SM-G950U using...
Forum:
05-16-2018, 07:41 PM
56
EvoX rear caliper swap
39,244
Posted By
15limited
Calipers I got used online, same as OP about $250...
Calipers I got used online, same as OP about $250 a pair, and rotors I think $300 for the set? DBA 4000 series drilled and slotted
Forum:
04-10-2018, 04:23 AM
35
Autopower roll bar 60783 install/review
24,605
Posted By
15limited
After nearly two months from order date... Im...
After nearly two months from order date... Im blaming the shipping company for this...
Forum:
Issues | Warranty | Recalls / TSB
03-15-2018, 09:38 PM
34
CEL P0500 Vehicle Speed Sensor Malfunction
26,355
Posted By
15limited
The rings are exceptionally cheap, $10-15 iirc. I...
The rings are exceptionally cheap, $10-15 iirc. I decided to replaced them myself however couldn't find any information online as to how set them, so I guessed. Dealer ended up replaced the whole...
Forum:
02-27-2018, 08:06 PM
56
39,244
Posted By
15limited
Anybody have luck finding rotors to eat up the...
Anybody have luck finding rotors to eat up the extra pad hangoff? I'm having a hell of a time even finding 08+ sti hat offset to put on a slightly larger disk.
Forum:
02-16-2018, 07:18 PM
96
CAE Ultra Shifter install...
68,262
Posted By
15limited
I don't think there's adjustment for the spring,...
I don't think there's adjustment for the spring, just small Allen head set screws to control left to right movement. Do you have mtec shift springs installed too? I do and it's not for the limp...
Forum:
BRZ Photos, Videos, Wallpapers, Gallery Forum
02-10-2018, 11:46 AM
91
Show Off Your Best Photos & @Instagram Name
44,777
Posted By
15limited
Those CR's look great [emoji108][emoji108] ...
Forum:
02-10-2018, 09:14 AM
20
Most reliable catback exhaust?
6,059
Posted By
15limited
I'm not sure how an exhaust will "burn out",...
I'm not sure how an exhaust will "burn out", unless you're referring to like... muffler packing? You can't really go wrong with any reputable catback, essentially the most basic exhaust component...
Forum:
12-25-2017, 03:23 AM
96
68,262
Posted By
15limited
None Sent from my 2PQ93 using Tapatalk
None
Forum:
10-12-2017, 09:25 AM
31
Built engine. How hard is it?
18,821
Posted By
15limited
I think despite manufactures claims there was...
I think despite manufactures claims there was much more than 5 whp gained in 17' MY, and I believe the increased output was almost entirely from the intake mani and tuning.
Well, the FI section...
Page 1 of 4
1
2
3
4
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) — General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) — General Topics
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Transmission and Driveline
Wheels and Tires
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Coating and Customization Services
Exterior Parts - Lighting
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
05:18 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2025 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
