Drives: Toyota86, MX5, Jeep, FJ45, 59 Caddy
Toyota sized Kenwood Navigation unit
Thought some of you guys might be interested in this...
I've always preferred the Kenwood navigation systems because they use the Garmin Navigation ECU's, which means the Garmin mapping works on them. Garmin is the only ones that are really keeping their Middle East mapping up to date - I'm in Dubai. Turns out Kenwood has a couple models that are specifically Toyota sized - the one I got was the DDX630WM - combined with the navigation module KNA-G630. Stock radio: ![]() After installing: ![]() With the Garmin navigation: ![]() Very nice - very factory appearance - so nice to not need the Metra / Scosche style adapters on each side! Also came with a plug and play harness for the Toyota audio connector. Only thing is the Toyota antenna is a different connector - need an adapter as I'm sure most of you have figured out already. Will try and get some better pictures for you in daylight ![]() Laurie
![]() 2013 Toyota 86 - 2008 Mazda MX5 2001 Jeep Wrangler - 1982 FJ-45 Land Cruiser Pick-Up 1959 Cadillac Sedan DeVille |
| The Following 13 Users Say Thank You to Laurie For This Useful Post: | baldolera (06-23-2012), Bonburner (08-20-2012), civicdrivr (06-21-2012), Dadhawk (06-22-2012), Efferalgan (12-26-2012), Fly Guy (06-22-2012), Jeff86 (01-19-2013), MaXimus (11-18-2012), Nardi330 (06-22-2012), normancw (06-27-2012), Scooby (07-14-2012), Slartibartfast (06-23-2012), sure74 (06-21-2012) |
Drives: Raven FR-S
The top is the stock head unit? I think that might be worse than the FR-S unit lol....I like the replacement you picked up though.
Drives: 2016 Toyota 4Runner Trail Premium
I was just looking at a pic with the metra kit installed saying, "Nope".
This is great, thanks! So what is the actual name of this DIN size? |
Drives: Many
which kenwood model is that?
#5 | |
Happy with the replacement
Don't know what the official name is but I've always called it "Toyota Double Din"
| The Following User Says Thank You to Laurie For This Useful Post: | sure74 (06-22-2012) |
As mentioned in the original post - Kenwood DDX630W with Kenwood KNA-G630 Navigation ECU.
Kenwood has an absolute mess of part numbers though with slight changes for different regions - at least I know that the Navigation ECU in the USA is the KNA-G610, not G630. There is also a radio called the DDX630 which is not the same - standard Double Din. I think the key is the "W" part for "wide" I'm guessing. Anyway - tracked down a suitable Antenna adapter today so I'll be putting that in soon. The Antenna adapter has one blue wire on it - any idea what I'm supposed to do with that?
Drives: 2013 Firestorm Scion FR-S
Apparently our cars have amplified antennas so hook that blue wire up to the antenna or remote wire off the aftermarket unit.
| The Following User Says Thank You to Nitro For This Useful Post: | Laurie (06-21-2012) |
#10 | |
#11 |
I just called my Kenwood rep and it's a no go on getting this in the states. I'd like to import one just to check it out though. Different am/fm tuner but I don't really care about that.
| The Following User Says Thank You to burnt_rice For This Useful Post: | sure74 (06-22-2012) |
#12 |
Drives: 2011 Civic Si
You sir are a sexy beast! This is exactly what I was looking for!
#13 |
Ask your rep what they have for nav units in a 1.5 DIN configuration. That's all this one is. Some people call it "Din and a half" or "one and a half din." I say "one point five din" personally.
#14 | |
Single is about 2x7 1.5 is about 3x7 Double is about 4x7 So, If ours is 1.5, how does that work? Again, I'm going on what the interwebs said, so it might now be accurate. |
| BRZ Navigation Audio Run Through | F1point4 | Electronics | Audio | NAV | Infotainment | 84 | 10-14-2012 12:20 PM |
| 2013 FR-S - 1st inventory unit for Scott Clark Toyota Scion | sctcmediaman | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 05-23-2012 08:57 PM |
| BRZ Navigation System | Guaruja | BRZ First-Gen (2012+) — General Topics | 15 | 04-13-2012 09:52 AM |
| replace the Ford Navigation system? | megancheung | Electronics | Audio | NAV | Infotainment | 1 | 03-22-2012 03:51 AM |
| New Here (Navigation Option Question?) | Jokester | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 02-19-2012 09:25 PM |
