follow ft86club on our blog, twitter or facebook. Interested in the FT-1? Check out FT1Club
RR Racing
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Old 06-20-2012, 09:24 PM   #1
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
TRD Wheels
Hi All,
Relatively new to modding cars and since the FRS is the first car I've owned, I want to upgrade the wheels and tires eventually but keep it classy and not effect performance.
I've been looking at the current TRD wheels available for Scions, Toyota's etc. and stumbled upon this pair.
http://www.trademotion.com/partlocat...catalogid=3482
What have people's experience been with TRD products, reliability, quality, etc. I assume it doesn't get any easier for bolt-on (no modification) upgrades.
I would be open to other wheel suggestions as wheel, looking for something simple. For example, what is on the new porsche Boxter S or Cayman R. Looks wise, not the exact rim.
Any help would be appreciated. I've read the wheels 101 and its slowly sinking in...
Re~Mix is offline   Reply With Quote
Old 06-20-2012, 09:30 PM   #2
MKIV
MKIV's Avatar
Drives: 4 tires mounted to 4 wheels
Originally Posted by Re~Mix View Post
Hi All,
TRD wheels are OEM quality.
MKIV is offline   Reply With Quote
Old 06-20-2012, 09:56 PM   #3
AlmostMDD
AlmostMDD's Avatar
Drives: 99 2.5RS
That's a Camry wheel. So it wasn't designed for the FRS. I couldn't find anything about the specs of that wheel, so you'd have to do a little digging to figure whether or not it'll fit, and what size tire you'd want to keep your speedo right. That's all assuming that Camrys use the same 5x100 bolt pattern. So unless you've done a bunch of reading already, I'd start there.
So the point is, just because this wheel is a TRD wheel, doesn't mean that it'll fit this toyota application like a glove. I think maybe that's what you're looking for.
Edit: quick google informed me that the the wheel you're interested is a 5x114.3 bolt pattern. So, no dice.
AlmostMDD is offline   Reply With Quote
Old 06-20-2012, 10:39 PM   #4
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
I had to have my scion wheels that came on a tc bored out. It was a 54.1 mm bore and the Frs has a 56.1 bore just as a heads up.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 06-21-2012, 01:58 AM   #5
Re~Mix
Re~Mix's Avatar
Thanks guys, any clue if TRD will be coming out with wheels etc. specific to the FR-S. I assume yes, just a matter of when.
Old 06-21-2012, 02:23 AM   #6
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Dodge Caravan
cyde01 is offline   Reply With Quote
The Following 2 Users Say Thank You to cyde01 For This Useful Post:
Packofcrows (08-22-2015), Re~Mix (06-21-2012)
Old 06-21-2012, 02:29 AM   #7
Re~Mix
Re~Mix's Avatar
Did a little research on my own and it looks like a few options are coming.
Any idea on pricing, availability etc. in the US?
Just beginning to dive into the upgrades, maybe i should keep it all stock for a while longer.
Old 06-21-2012, 03:46 AM   #8
Calidrifter
@Executive_chicken
Drives: Firestorm FR-S
I think it was mentioned somewhere that those black trds were somewhere in the 11,000 range. Without tires.
Keep it stock for as long as you can to get a feel for the car. There is no sense in putting something that looks good but make the car worse.
Club 4AG | Apex'i | HKS | GrimmSpeed | TRD | Beat Sonic | ENKEI | Cusco
Originally Posted by Jyn View Post
That guy, like me after BBQ Thursdays, is full of shit.
Calidrifter is offline   Reply With Quote
Old 06-21-2012, 05:03 AM   #9
nix
nix's Avatar
Drives: AVO BRZ
Take some time to do some reading and get up to speed. People could offer you all kinds of suggestions but you're best off understanding what it is you want and making your own decisions.
nix is offline   Reply With Quote
Old 06-21-2012, 12:59 PM   #10
cyde01
cyde01's Avatar
the wheels are actually 1500 each without tires not 11000. still a sky high price, they make volks look affordable. the brakes are like 11000 front and rear if i recall correctly. almost half the price of the car
Old 06-21-2012, 08:23 PM   #11
sickmint79
Drives: bmw
enkei rpf1's are cheap and light at tirerack. 17x7.5. direzzas. done.
sickmint79 is offline   Reply With Quote
Old 06-21-2012, 08:29 PM   #12
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
TRD wheels are heavy.
go with volk or work
86_ZN6 is offline   Reply With Quote
Old 06-27-2012, 01:15 PM   #13
Re~Mix
Re~Mix's Avatar
So I'm still left drooling over some of the TRD Wheels I've seen as well as a few products from Rays.
I'd like to upgrade the look of the car without sacrificing performance or the suspsension (likely leaving it at 17" rims). What exactly are my options to do so with limited modification, or perhaps without even affecting the warranty?
I realize TRD parts won't hurt the warranty, but what about 5 axis, Rays, etc.?
Sorry for being a newb here, I've always had the desire to have aftermarket rims and I finally have a car and the cash to do so.
Old 06-27-2012, 03:08 PM   #14
TuxedoCartman
Drives: '13 86
The only way an aftermarket wheel will affect your warranty is if something related to the wheel fitment breaks, or the wheel itself breaks while you're driving; in that case, the dealership will neither fix the wheel nor parts of your car damaged when in happens. Not that it matters, because your insurance will probably fix it in that case anyway.
No one thing you can do to part of a car can void the warranty on other parts. So if you pick up some Rota wheels, and your engine decides to throw a piston through your fender... Toyota will still fix your engine.
TuxedoCartman is offline   Reply With Quote
The Following User Says Thank You to TuxedoCartman For This Useful Post:
Re~Mix (06-27-2012)
Search this Thread:
Advanced Search
Which 18" wheels will weigh the same or less than the stock wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-16-2013 03:07 PM
Forgestar wheels, great wheels at great prices!!!! IslandImportPerformance Wheels and Tires 0 06-15-2012 05:03 PM
O.Z. Wheels Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 02-28-2012 04:21 AM
has anyone else seen this wheels supramaster12 Scion FR-S / Toyota 86 GT86 General Forum 12 02-09-2012 09:40 PM
OEM wheels I haven't seen elsewhere bambbrose Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 12-14-2011 07:08 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
