Drives: 98'DC2R
HID Conversion DIY
So before I got a chance to shoot the FRS I posted in photo/video thread, I was able to capture a step by step instruction of how to install an HID kit into the FRS.
Brand: Alumina Xenon H11 6000k ![]() Unplug the factory bulbs, and remove them from the harness plug. ![]() Take the two prong connectors from the Alumina H11 bulbs and plug them into the factory harness plug. ![]() Connect the plugs from the Alumina H11 bulbs to the Alumina S2 ballasts. ![]() Take the remaining plugs from the Alumina H11 plugs and connect them with the remaining plugs from the Alumina S2 ballast. ![]() Turn on your headlights to check if all your plugs are connects properly. If the bulb does not ignite, reverse the two prong connected to the harness. Once you have checked all your connections, and everything is working, use electrical tape to secure the prongs to the harness plug. ![]() Plug the Alumina H11 bulbs back into the factory socket. ![]() Find the supplied zap straps ![]() Zap strap any loose wire and lines to de-clutter your engine bay. ![]() Mount your ballast to a secure location using either double sided tape or zap straps. The ballast was mounted to the frame using double sided tape. ![]() Before and After
| The Following 3 Users Say Thank You to loong For This Useful Post: |
Drives: 86 ZN6
Nice write up!
But Did you adjust the squirrel finders for the HIDs? |
Drives: 2013 Scion FR-S Raven
Mash those metal pieces (squirrel finders) hard
| The Following User Says Thank You to tonystewart For This Useful Post: | try2findmark (10-18-2012) |
#5 | |
Drives: 4 Wheels Auto
How is your light cut-off on the top?
Drives: Whiteout FR-S MT
#7 | |
Drives: FRS :D
They are used to reflect light a certain way if you bend them then it creates a much better cutoff for pnp HID in Halogen porjector housings.
#9 | |
Drives: FRS :D
google it http://www.3gwrx.com/forum/index.php?topic=13416.0
| The Following 3 Users Say Thank You to Mr.Jay For This Useful Post: |
#10 | |
Thanks man, now i know what it is. |
#12 |
DRIFT BITCH
Drives: Sideways
Can someone post a link to where to buy this or similar Xenons that won't F up
Five Axis Turbo FR-S
See my build thread with TURBO! Cobalt SS -> Nismo 370Z -> Camaro 2SS/RS -> FR-S Five Axis Turbo |
#13 | |
2 wheel member
Drives: 05 Tacoma 4x4 DC MKIV Supra 6spd TT
#14 |
DRIFT BITCH
Drives: Sideways
There probably aren't any kits that fit the stock connector. Does anyone know if the Scion tC and xB have the same harness connector as the FR-S? That would save a lot of trouble.
#15 |
I'm here for the beer
Drives: 2013 Scion FRS, 1971 Datsun 240z
It's just a H11 bulb, nothing different than the tC . Usually it's just with the really cheap or "universal" kits that only come with the standard prong types that require you to do this. Any slightly above average company should send out the proper H11 connectors.
| The Following User Says Thank You to raz0rbladez909 For This Useful Post: | RRnold (07-17-2012) |
#16 | |
DRIFT BITCH
Drives: Sideways
Like I'm trying to see if these would work. http://www.ebay.com/itm/Xenon-5000K-...ht_5740wt_1139
#17 |
Retrofit Source, 3B Specialties all offer "complete" connectors!
| The Following 2 Users Say Thank You to tonystewart For This Useful Post: | RRnold (07-17-2012), tripjammer (07-26-2012) |
#18 | |
#19 | |
DRIFT BITCH
Drives: Sideways
#20 |
2 wheel member
If you are going to with a PnP HID kit, might as well get the kit with the oem connectors. That's how you can tell the lower grade kits from the decent ones.
#21 |
DRIFT BITCH
Drives: Sideways
Right but how can you tell if the kit has the OEM connector or not. There are none out there designed for the FR-S under $100. And I'm sure theres thousands of generics that'll fit but nobody has yet to answer that question. I'm not about to buy one of our vendor's slim versions that basically the same setup as one on eBay but three times the price. As long as everything clicks and works for 4+ years I'm good.
#22 | |
2 wheel member
| leather seat conversion | stalon320 | Interior Parts (Incl. Lighting) | 6 | 07-20-2012 03:36 PM |
| LED Conversion | [M] | Cosmetic Modification (Interior/Exterior/Lighting) | 38 | 06-18-2012 07:44 PM |
| LED exterior and turn signal conversion | fenton | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-07-2012 10:33 PM |
| Anyone ever heard of a coupe to removeable hard-top conversion shop? | Saibot | CANADA | 26 | 02-09-2012 10:38 PM |
