Go Back   Toyota 86 / Scion FR-S / Subaru BRZ Forum - FT86CLUB > Technical Topics > Cosmetic Modification (Interior/Exterior/Lighting)
Old 04-15-2015, 06:03 AM   #1
funwheeldrive
funwheeldrive's Avatar
Drives: Firestorm Monogram
Instructions for Installing TRD Rear Stabilizing Cover?
Hey guys, I just recently bought this part.
The only issue is that the install instructions are in Japanese. Does anyone have a guide in English, or know where I could get one? Would anyone on here be able to translate the Japanese instructions if I uploaded them? Thanks in advance.
Old 04-15-2015, 03:08 PM   #2
ryoma
ryoma's Avatar
I thought it sticks on with double-sided tape... lol. did it come with any hardware?
Old 04-15-2015, 03:26 PM   #3
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
edit: fail, read the thread title wrong
from some photos i see online.. looks like just double sided tape???
Old 04-15-2015, 10:28 PM   #4
stevesnj
stevesnj's Avatar
Where you get it and how much....thanks!
My 2016 Build thread
Old 04-15-2015, 11:41 PM   #5
cfordart
cfordart's Avatar
Drives: 2014 FR-S
Mine was very easy to install....clean the glass, center the piece, stick it down and pull the covers off the double-sided tape. Done. Looks great and fills that funky gap with something besides leaves.
The only thing you need to watch out for...don't mount it too close to the trunk lid. When you open the trunk the lid moves forward slightly, if the piece is mounted too close it WILL rub. Worse in the winter when everything's cold. They include some small rubber pieces for setting the spacing. You need at least an eighth inch spacing, maybe a quarter inch to be sure....but closer looks better. Stick it down loosely and see if the trunk lid clears it...if so then you win.
cfordart is offline   Reply With Quote
The Following 2 Users Say Thank You to cfordart For This Useful Post:
juliog (04-24-2015), MJones_RB (09-24-2018)
Old 04-24-2015, 01:18 AM   #6
funwheeldrive
Sorry it took me so long to get back to this thread. There is hardware and the instructions are confusing me. I uploaded what came with the cover and the instructions.
I get the basic concept, but can someone tell me what to do with the spacers? They look like they have an adhesive strip on them.
What do you guys think?
Old 04-24-2015, 08:14 AM   #7
drifter-s
drifter-s's Avatar
Drives: 2013 Whiteout FR-S
The spacers are used to adjust the gap between the stabilizer and trunk lid. They have adhesive to stick the spacers together if you need a larger gap or to better center it all the way across. You do not stick the spacers to the stabilizer or trunk lid.
Place them in between the stabilizer and trunk lid and leave them there until you remove the strips to the adhesive on the stabilizer. Once the stabilizer is secure, remove the spacers.
You don't need a large gap between the trunk lid, but give yourself enough to keep clear of the trunk lid and stabilizer rubbing.
drifter-s is offline   Reply With Quote
Old 04-24-2015, 11:56 AM   #8
funwheeldrive
Thanks, that makes sense. I get using the spacers on the bottom between the trunk and cover, but am I supposed to use the spacers on the sides as well?
Also, am I supposed to let the prep dry fully before my final placement?
Old 04-24-2015, 06:57 PM   #9
drifter-s
drifter-s's Avatar
I prepped it first with the alcohol wipe and then the primer wipe. Lined it up and measured each end to make sure it was centered. I used one large spacer for the middle for the gap and then I believe I combined one large and one small spacer for each end area. I used three spacer locations to line it up total, then I removed the adhesive backing from the stabilizer. Made sure it was still lined up properly and then pressed down evenly to secure it.
The Following User Says Thank You to drifter-s For This Useful Post:
funwheeldrive (04-24-2015)
Old 04-24-2015, 10:27 PM   #10
Jake_86
Jake_86's Avatar
How much were they
Gold Accented GT86 Build Thread
Live Fast, Die Young.
Jake_86 is offline   Reply With Quote
Old 04-24-2015, 10:38 PM   #11
drifter-s
drifter-s's Avatar
Originally Posted by Jake_86 View Post
How much were they
Bought mine through Nigel-jdmparts. His prices aren't bad. I've bought a few parts through him. Be prepared to wait for some items though. Took me about 3 months to get the stabilizer.
Old 05-05-2015, 02:34 AM   #12
shodan
shodan's Avatar
Drives: MY15 Toyota 86 GTS
Someone posted about this before and he showed a table that showed how big the rubber pieces added up need to be for whatever size gap you want/have between the boot and the rear window:
http://www.ft86club.com/forums/showp...97&postcount=7
It's the table next to image 3 (on the page; not the 3rd attached image)
Last edited by shodan; 05-05-2015 at 02:39 AM. Reason: just re-read the instructions and it's the gap between the boot and the rear window, not the boot and the aero cover
shodan is offline   Reply With Quote
Old 05-05-2015, 12:12 PM   #13
Jake_86
Jake_86's Avatar
Post a finished shot too btw
Old 05-17-2015, 10:10 AM   #14
tiz22
tiz22's Avatar
Drives: 2013 Scion FR-S (Raven) MT
A bit late on this reply but applies to any future installs where the instructions are in japanese... If you download the Google Translate app for your iphone it has the option to use the camera to scan text and will show you english translation...I use it at work all the time to translate spanish signs...It's not perfect but usually gets the job done
My Car Journal: Raven FR-S w/ TRD Flavour
Click for my AVIC Z150BH Head Unit DIY Install
tiz22 is offline   Reply With Quote
Search this Thread:
Advanced Search
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 21 04-18-2019 11:14 AM
Pictures of TRD Aero Stabilizing Cover??? funwheeldrive Cosmetic Modification (Interior/Exterior/Lighting) 71 06-06-2018 05:03 PM
Need help installing rear springs! flashburn Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 03-29-2014 04:51 PM
Free-Rear bumper cover (entire rear facia) replaced after slight rear-end collision n7011n Exterior Parts (Aero, Lighting, Etc.) 7 03-26-2014 04:46 AM
Installing the AVO Rear Reinforcement Bracket AVOturboworld DIY (Do-It-Yourself) Guides 9 10-29-2012 11:44 AM
Copyright ©2000 - 2020, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
