#1 | |||||||
FT86Club Official Vendor
^^^Interior / Exterior Super White LEDs offered at HID_Powerhouse^^^
TitanRR High Intensity Super White LEDs for 2013+ Scion FR-S, Subaru BRZ and Toyota 86. 100% confirmed fitment for license plate lights, trunk lights, front marker lights (if installed Japan Clear Marker Lens) and BRZ equipped front door courtesy lights ![]() TitanRR Super Bright High Intensity White LEDs installed for license plate lights ![]() ![]() ![]()
TitanRR Super Bright High Intensity White LEDs installed for front clear marker lights (if equipped with JDM clear lens/housings) ![]() TitanRR Super Bright High Intensity White LEDs installed for trunk lights ![]() Installation: ![]() ![]() HID Powerhouse LEDs vs. Other LEDs on the market Not all LEDs on the market are made equal. Our LED chips use the largest die (largest chip size) for maximum brightness, which results in effective light transmittance and achieve a high luminous intensity. Our high quality LED chips produce a unique, super white colour output that enhances your car’s aesthetics and sets it apart from others. Life span is also extended by high quality LED chips with high quality silicone to seal the LED chip for resistance to heat, UV and moisture. Therefore, this results in resistance to colour fade and discolouration with repeated use. Other LED chips on the market may use a smaller chip size which does not produce sufficient and effective lighting for its intended use. Lower quality LED chips may also use epoxy as a sealant which may lead to colour fade, short life span and ineffective light transmittance. In our view, it would be a worthwhile investment to upgrade to quality LED products .You may spend more in total if you had to upgrade to better quality LEDs before you are satisifed. Pricing: List price: $22.99 a pair + shipping Please visit our online store for your FT86Club member special pricing and to place an order!!! http://hidpowerhouse.com/?product=ti...-sbrztoyota-86 Purchase any FR-S or BRZ LED packages and receive additional discounts. Please see below for more details. For international shipping outside of US and Canada, please contact us for more information. Customer Feedback: Quote:
Other LED products we offer for your FR-S/BRZ: ![]() ![]() ![]() ![]() ![]() MaxRS Reverse LEDs for FR-S/BRZ (click on photo below): Turn Signal LEDs for FR-S/BRZ (click on photo below): LED Daytime Running Lights FR-S (click on photo below): Do we offer LED packages and additional discounts? Absolutely!!! Please see below for specific LED packages we offer for your FR-S/BRZ: ![]() FR-S LED packages Package 1: FR-S MR LED package 1) MaxRS Super Intense White Reverse LEDs (a pair) 2) TitanRR Super Intense White License Plate LEDs (a pair) 3) K-Spec 6 LED festoon Super Intense White for Dome Light (20% brighter than factory) 4) TitanRR Super Intense White Trunk LED Package 2: FR-S CR LED package 1) MaxRS Super Intense White Reverse LEDs (a pair) 2) TitanRR Super Intense White License Plate LEDs (a pair) 3) K-Spec 9 LED panel Super Intense White for Dome Light (1 panel) (30% brighter than factory) 4) TitanRR Super Intense White Trunk LED Package 3: FR-S BR LED package 1) MaxRS Super Intense White Reverse LEDs (a pair) 2) TitanRR Super Intense White License Plate LEDs (a pair) 3) K-Spec 12 LED panel Super Intense White for Dome Light (1 panel) (40% brighter than factory) 4) TitanRR Super Intense White Trunk LED Package 4: FR-S Ultimate LED package 1) MaxRS Super Intense White Reverse LEDs (a pair) 2) TitanRR Super Intense White License Plate LEDs (a pair) 3) K-Spec 15 LED panel Super Intense White for Dome Light (1 panel) (60% brighter than factory) 4) TitanRR Super Intense White Trunk LED BRZ LED packages Package 5: BRZ MR LED package 1) MaxRS Super Intense White Reverse LEDs (a pair) 2) TitanRR Super Intense White License Plate LEDs (a pair) 3) K-Spec 6 LED festoon Super Intense White for Dome Light (20% brighter than factory) 4) TitanRR Super Intense White Trunk LED 5) TitanRR Super Intense White Front Door Courtesy Lights (1 pair) (15% brighter than factory) Package 6: BRZ CR LED package 1) MaxRS Super Intense White Reverse LEDs (a pair) 2) TitanRR Super Intense White License Plate LEDs (a pair) 3) K-Spec 9 LED panel Super Intense White for Dome Light (1 panel) (30% brighter than factory) 4) TitanRR Super Intense White Trunk LED 5) TitanRR Super Intense White Front Door Courtesy Lights (1 pair) (15% brighter than factory) Package 7: BRZ BR LED package 1) MaxRS Super Intense White Reverse LEDs (a pair) 2) TitanRR Super Intense White License Plate LEDs (a pair) 3) K-Spec 12 LED panel Super Intense White for Dome Light (1 panel) (40% brighter than factory) 4) TitanRR Super Intense White Trunk LED 5) K-Spec 6 LED panel Super Intense White for Front Door Courtesy Lights (2 panels) (30% brighter than factory) Package 8: BRZ Ultimate LED package 1) MaxRS Super Intense White Reverse LEDs (a pair) 2) TitanRR Super Intense White License Plate LEDs (a pair) 3) K-Spec 15 LED panel Super Intense White for Dome Light (1 panel) (60% brighter than factory) 4) TitanRR Super Intense White Trunk LED 5) K-Spec 9 LED panel Super Intense White for Front Door Courtesy Lights (2 panels) (60% brighter than factory) Our customer feedback: http://www.ft86club.com/forums/itrader.php?u=11756 Unlike the competition, HID_Powerhouse uses high quality components in all our LEDs. These components ensure longer life and better stability in color in all our LEDs. Many companies choose to go with the less expensive generic LEDs. These generic LED chips wear out very quickly, discolour and may possibly short-circuit your car's electrical system (blow your fuse(s) in many cases). Why our LEDs are better than others on the market? ![]()
| The Following User Says Thank You to KI_ZN6 For This Useful Post: | peazs (07-01-2012) |
Drives: 2013 genesis rspec
way too bright, it looks like a freaking flashlight, no thanks less light is better to be unnoticed by the cops
Hi just86,
Indeed, the pictures of the product may be on the brighter side because the product pictures were taken in a controlled environment with photography gear and in some dark areas. We just had a customer in the Vancouver, BC, Canada area that installed our LED white license plate lights, LED white reverse lights and LED dome light. I snapped a daytime picture a customer's FR-S with the LED white license plate lights turned on and it is only somewhat visible during the day. At night, it is a very pure white, slightly whiter than the factory BMW and Lexus LED license plate lights.
| The Following User Says Thank You to KI_ZN6 For This Useful Post: | MattR (06-13-2012) |
Drives: FRS :D
Waited till it was dark and got some pics for you guys. Excuse the camera as my sister has stolen my Rebel and thus cellphone pics we got
The new reverse lights actually give off a nice amount of light when backing up and the look really good in person I think. So fair everything is good for light output however the dome light took some time to get use to but now my eyes have adjusted (you just dont expect it to be that bright) ![]() ![]() ![]() ![]() ![]()
| The Following User Says Thank You to Mr.Jay For This Useful Post: | KI_ZN6 (06-16-2012) |
Mr. Jay,
Thank you kindly for sharing your impressions and thoughts on our LED products. Thanks for sharing the pictures!!! =) For those who are interested, feel free to PM us with any questions. We are planning on a group buy very soon for these LEDs (dome light, license plate lights and reverse lights). For those looking for something less bright for the interior dome light, we carry those LED dome lights with less LED count, thus, less bright. It's really personal preference for how bright you would want to go. Given that there is just one interior light in the FR-S/BR-Z, I would like most people would like to go slightly brighter to light up the interior at night. Cheers!
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
I'd be interested in the whole set! Count me in!
| The Following User Says Thank You to DaJo For This Useful Post: | KI_ZN6 (06-18-2012) |
We carry super white LEDs from Japan for interior and exterior.
Super white LEDs from Japan for interior and exterior. PM me for more LED selection and pricing. =)
Here are photos of our customer's 2005 TSX Tech Package. Products used: 7440 White LED for reverse lights 15 White LED Panel Dome Light 9 White LED Panel Map Lights 9 White LED Panel Door Courtesy Lights T10 White LED License Plate Lights D2S 6000k HID headlight bulbs ![]() ![]()
Interior and Exterior LEDs on 2010 Lexus RX350
LED list: Custom 18 LED panel front map lights 2 LED panels for front footwell lighting 6 LED panels for door courtesy lights 24 LED panel for rear dome light 6 LED panels for trunk lights Here are photos of our 2010 Lexus RX350: ![]() ![]() ![]() ![]()
LEDs on a 2006 Lexus IS350
LED list: 3 LED panels front map lights 2 LED panels for front door courtesy lights 24 LED panel for rear dome light 6 LED panels for trunk lights 921 Super White LEDs reverse lights 5050 Super White LEDs for front marker lights Here are photos of our 2006 Lexus IS350: ![]() ![]() ![]()
#10 |
#11 |
SUP BRYZ
Drives: Scooby BRZ
pm me for license plate super white LED shipped to 92614 please
![]() Follow Me on Instagram@ProjectBReeZy R-RYDES! "This is Family" ProjectBreezy Build http://www.ft86club.com/forums/showthread.php?t=31146 |
#12 |
PMs replied. Thanks!
#13 |
Here are pictures of our customer's 2013 BRZ Sport-Tech (his screen name is jmah88). He installed the following:
- 9 Blue LED panel for front dome light - 1 pair of blue LED for the front door courtesy lights - 1 pair of super white LED license plate lights - 1 blue LED for trunk light We will be installing an HID kit for his foglights very soon. Stay tuned!!! ![]() ![]() ![]() ![]() ![]()
#14 |
#15 |
Items shipped. Thanks!
#16 |
PMs replied, thanks!
#17 |
Orders shipped and PMs replied. Thanks everyone
#18 |
HID_Powerhouse LEDs (BEWARE OF CHEAP LEDS)
We work closely with our supplier in Japan to bring you the best automotive LEDs that are made with high quality LED chips. Our LEDs are made with thanks to state-of-the-art LED manufacturing robotics, and all of our LED and HID products are subject to strict quality assurance measures and high QC standards.
We take it one step further by utilizing stress tests to determine how we can improve our product quality and durability with hours and hours of LED colour shift tests, LED chip endurance and heat generated by LEDs. We compare our LED products with other manufacturers, creating benchmarks and raising our quality standards whenever possible. Our LED panels are made with high quality printed circuit boards with precise soldering points. The LED chips are designed, engineering and made in Japan. The LED chips have one of the highest life expectancy and maintains its original colour the longest. Many LED chips on the market colour fade very quickly and the colour/light output diminishes significantly. The male and female connectors are also from Japan, ensuring that the connection is proper and safe. Lastly, our LED panels use genuine 3M double-sided adhesive for customer who wish to mount their LED panel to their personal liking. We are continuously improving our LED products and bringing to the market the newest LED technology available, creating value for customers and offering high quality LED products at reasonable prices. Buyer beware: Majority of the LEDs on the market are manufacturered by hand and there may be signs of poor soldering work on LED circuit boards. This translates to premature LED failure, overheating, short-circuit of your vehicle's electronics (will blow fuses first) and hit-and-miss quality. Spending a little more for quality automotive LEDs will save you money in the long-run, instead of spending unnecessary money for repairs and replacements. CLICK HERE for a quick comparison of HID_Powerhouse's LED panel to other competitor's LED panel.
#19 |
T10 5-5050 Super White LEDs installed on a Lexus CT200h
T10 5-5050 Super White LEDs installed on a Lexus CT200h:
OEM incandescent light bulb: ![]() Our T10 5-5050 Super White LED installed on the right side, in comparison to the factory OEM Lexus incandescent light bulb: ![]() Our T10 5-5050 Super White LEDs installed, rated at 6000k colour output: ![]() The FR-S and BRZ use the T10 (194/168/2825) incandescent light bulb from factory. This is the same bulb that is used on the Lexus CT200h. PM us for any interior and exterior LEDs. We sell LEDs for license plate lights, dome lights, map lights, door courtesy lights, trunk lights and reverse lights. We have various sizes of LEDs in stock, different LED panel sizes in different colours. Thanks for looking!
#20 |
2013 BRZ Limited LED license plate lights
HID_Powerhouse Super White LED License Plate Lights (detailed photos):
| The Following User Says Thank You to KI_ZN6 For This Useful Post: | jmah88 (06-28-2012) |
#21 |
PMs replied and orders shipping out later today.
Many thanks!
#22 |
PMs replied.
Thanks!
| Front License Plate Solution? | Dillano609 | Scion FR-S / Toyota 86 GT86 General Forum | 72 | 03-16-2013 01:00 AM |
| License plate ideas | Laika | Off-Topic Lounge | 138 | 03-01-2013 08:03 PM |
| Another license plate idea.... | michaelahess | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 06-07-2012 07:24 PM |
| Front License Plate Replacements | Bonburner | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 05-14-2012 05:25 PM |
| Odd question: License plate light? | Double4Free | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 02-20-2012 08:29 PM |
