#309 |
Groovy
Drives: GMC Sierra
If it's chirping (and I'm going by experience from older cars/trucks)...
A bad throwout bearing in the manual transmission can cause chirping at idle, so can bad bearings in any of your pulleys. There can be a intermittent chirps if you have oil on your belts/serpentine belt. A constant chirping at idle can be a T/O bearing or any of the engine pulleys.
Share the road.
#310 |
Drives: 2013 Scion FR-S 6MT
This is what I experienced last night after coming back from Dodgers vs Angels game ( in which dodgers won ;D) it's pretty loud. What should I do? Call scion, take it to the dealer? http://i63.photobucket.com/albums/h1...s/fefb7143.mp4
I don't always drift every corner, but when I do, I drift FRS
. Stay drifty my friends ![]() 2013 Scion FRS Whiteout 6MT |
#311 | |
Drives: Whiteout FR-S
#312 |
Well the idle is very low n goes down to 400 at times. The high pitched chirp is what is loud. The video didn't capture how loud it really was but lemmie assure you it's pretty loud n high pitched.
#314 | |
#315 |
Yeah I guess I do see it bouncing a little bit. Mine isn't really bouncing that I know of. Just dipping well below 500rpm and bouncing one time up past 1k till it comes to a normal idle. Meh, guess its just a waiting game to find out if its normal, or needs fixed.
| The Following User Says Thank You to yayforaddison For This Useful Post: | Julio86 (06-24-2012) |
#316 | |
#317 |
Drives: scion tc
it would be good to see a pool to how many people have this issuee!
thanks |
| The Following User Says Thank You to csaba For This Useful Post: | Julio86 (06-24-2012) |
#318 | |
#319 |
Drives: 2013 FRS Asphalt
In the video you can hear the high pitched cricket noise. I didn't see anything wrong with the rpms. However the cricket noise is not normal. There is a thread about this in the engine sub forum. A lot of people are getting this.
2013 Scion FR-S AT Picked up 5/30/2012
#320 | |
#321 |
Troll Hunter
Drives: Moped
Someone needs to get a hold of a scope and trace the chirping sound.
It's too hard to tell from the video if it's a belt, a loose pulley, metal rattling from inside the motor, a tob, a leak, or something else. Scope it and you should have an answer to your problem. ***Is it me, or does the sound go away under load? Do people with automatics experience this chirp? If they don't, then it could be the TOB like others have said. |
#322 |
Yes I have the AT and have the cricket noise. It seems to be coming from the right side of the motor if you are facing it.
| The Following 2 Users Say Thank You to feldy For This Useful Post: | Lonewolf (06-24-2012), Lowellrenzo (06-24-2012) |
#323 |
Drives: Civic Si coupe
Mine doing the same thing
#324 |
Drives: 2013 asphalt fr-s
Idk, but only time I notice the idle drop is when my A/C is on.
#325 |
Drives: 2013 BRZ Premium 6MT
confirmed the idle drop today in my brz for the first time. i was at a taco bell drive thru and noticed the rpms drop to about 400 then bounce up to 900...it then did it again but dropped to about 500 and jumped up a few then leveled out. the a/c was running with the fan on the lowest setting.
ill mention it at my first oil change or take it in if it keeps happening
2013 Subaru BRZ Premium 6MT -STOCK!
#326 | |
Spaceman
Drives: 2013 Firestorm Scion FR-S
Your car wanted you to get away from Taco Bell... ![]() (it's sad when you're tired enough to crack up IRL at your own jokes....)
#327 |
Drives: M/T Argento FRS
I'm at ~250 miles on the FRS and I've seen the idle rpm drop from ~750 to 500. At 500 it shakes a bit (the shifter) and almost sounds like its about to stall
#328 | |
Drives: Honda Fit
#329 |
#330 |
N7 Spectre
Drives: 2013 Scion FR-S (Firestorm - 6MT)
I get both of these often, but assumed the chirping was coming from the DI system like someone mentioned in another thread maybe?
Subscribed; I want to see what the manufacturer says
GT5 PSN: Koji_Online
XBoxLive ID: KojiOnline4 |
| A Small Easter Egg | avusblue | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 06-28-2012 10:38 PM |
| Subaru BRZ - The biggest small car ever | Laika | Photos, Videos, Wallpapers, Gallery Forum | 7 | 06-09-2012 12:21 AM |
| Received my FR-S with a small ding | Neurytic | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 06-03-2012 11:53 AM |
| Isn't 6-10 miles on a new car kinda high? | houseofsuffering | Subaru BRZ General Forum | 46 | 05-15-2012 11:32 AM |
| Kinda make me worry! (Radiation related thing) | EJ20 | Off-Topic Lounge | 32 | 05-08-2011 11:58 PM |
