#199 | |
Site Moderator
Drives: '00 Subaru 2.5RS
| The Following User Says Thank You to ichitaka05 For This Useful Post: | yayforaddison (06-14-2012) |
#200 |
Interested in hearing the results. I haven't noticed any idle problems with my BRZ, but I did get a weird chirping at idle, which could be something different.
#201 |
I noticed that if I let the car idle for 15+sec then give it gas, the rpms will drop to 400-500 then go up. Result of this is the engine shaking for a brief second. Haven't noticed this before, but then again I started up the engine and ran it for roughly 10mins without going anywhere, so no load was ever on the engine.
#202 | |
Drives: Whiteout FR-S
#203 |
Drives: 2010 4Runner Trail
I went for lunch today in the FR-S and when I tried to accelerate onto the highway, the car lurched and felt dead for .5 seconds as I pressed moderately on the gas. I have an AT and the car was in sport mode. It must have only been in gear 2 and the rpm was about 3-4k. So it wasn't a hard acceleration by any means, but it was definitely a strange behaviour that should not happen. I'm having A LOT of rpm dips to 500 or just below, very easy to reproduce. There's also another big rpm dip about 1000rpm (dips to 800rpm then back up) with my AT. I'm on my second tank of gas, 91 octane which is all I can get here. 950kms on the odo.
Rob |
| The Following User Says Thank You to Rob_g For This Useful Post: | yayforaddison (06-14-2012) |
#204 |
Here's a vid I took of it at an idle. If you notice, when the RPMs are around 600 and are there for say longer then 10 seconds, as I give it gas, my iPod would shake a bit and the RPMs would drop to 500/400 then go up.
Is it me, or shouldn't the idle be a little higher? I always thought it should be around 750.
#205 |
Drives: Black Premium MT BRZ
No link.
#206 |
Haha, was talking to someone when I was typing that and totally forgot. Fixed!
#207 | |
Drives: 2013 Whiteout 6sp
And yes, bad gas will cause shuttering and stalling, but this is not bad gas. I have experienced the same thing. Going in tomorrow after my Scion phone call. |
| The Following 2 Users Say Thank You to TheChopShop For This Useful Post: | *KID* (06-15-2012), CountChoculitis (06-15-2012) |
#208 |
Drives: Scion FRS
sort of same issue here. low rpms when iddle. when stoped i can just feel the pistons when they fire as i feel a little shake in car. so wth is it?
just went out to check it i hit gas up to only like 1500 rpm dont want piss off neighbors but from what i saw now it would drop to like 800 than slowly move between 600-700 but i can stell feel the engine lol. ill try check in the morning when i can rev it higher and see Last edited by V1B; 06-15-2012 at 02:56 AM. |
#209 | |
Drives: 2008 STi
#210 |
Drives: 68MGBGT/93MiataLE/11Legacy
Mine has done this, though it was only once and it was really minor compared to a few of the comments here. It was in the first tank of gas, and it has not come back. Mine has 550 miles on it.
#211 |
86-er
Drives: Scion FRS
wonder how the maf sensor is doing with some of you all having the same issue.
2013 Scion FRS - Firestorm Red 6MT/ DDPR Tuned/ WORKS DIF/ PERRIN Intake Tube/ Motiv HFC Front Pipe/ Motiv Overpipe/ Whiteline Subframe bushings/ MOTUL fluids/ Beat Sonic Shark Fin/
My Journal |
#212 |
Don't know if any of you are getting a chirping sound at idle, but here's a video of what mine sounds like:
Also, are any of you having the idler pulley on the left side move back and forth a little bit?
#213 | |
#214 |
I haven't owned a Subaru before, let alone an opposed motor. But is it normal for the whole car to shake?
#215 | |
Double Dragon
Drives: 2013 6MT BRZ Limited
Sometimes in my WRX the idle would drop suddenly when coasting to a stop with clutch in or just sitting idling, and then it would run low and rough for a while. It did this from time to time over the five years I had it, but never seemed to become an issue. I would just give it some gas when it would happen and it would seem to clear up after a bit of rough idling. It never stalled though. Seems common from what I read among other WRX owners.
#216 |
Drives: 2008 STi
to me it sounds normal, but for your piece of mind take it back to the dealer and ask if this is normal. But my STi is load and stumbles and the car rocks back and forth
#217 | |
Now, if the car is shaking and your RPM's are fluctuating between 300 and 500, that's a stumble, usually caused by bad fuel or a vacuum leak. If this is what you are experiencing, a trip to dealer is in order. That should not happen on a brand new car. |
| The Following User Says Thank You to davisk6 For This Useful Post: | blu_ (06-18-2012) |
#218 |
Drives: MT GB BRZ Limited
Brought my BRZ in for the idle issue and an unpredictable check engine light, and the head mechanic at the dealer gave Subaru of America a ring; he said SOA was getting involved and that they were flying in engineers to their HQ today or something. This is a real issue.
He mentioned something about the camshaft not being in sync with the rest of the engine, and that it may be a problem with a third party supplier. (Mine's an MT BRZ Limited.) |
| The Following User Says Thank You to Stu L Tissimus For This Useful Post: | Marrk (06-24-2012) |
#219 | |
#220 | |
| A Small Easter Egg | avusblue | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 06-28-2012 10:38 PM |
| Subaru BRZ - The biggest small car ever | Laika | Photos, Videos, Wallpapers, Gallery Forum | 7 | 06-09-2012 12:21 AM |
| Received my FR-S with a small ding | Neurytic | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 06-03-2012 11:53 AM |
| Isn't 6-10 miles on a new car kinda high? | houseofsuffering | Subaru BRZ General Forum | 46 | 05-15-2012 11:32 AM |
| Kinda make me worry! (Radiation related thing) | EJ20 | Off-Topic Lounge | 32 | 05-08-2011 11:58 PM |
