| Engine, Exhaust, Transmission, ECU Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
Drives: If god were a car he'd be an FR-S
K&N drop in air filters..............will you?
I see they are available on their site. $43.00 Will you?
Thoughts?
Drives: 07 STI, 03 WRX, 13 BRZ
I was about to when I figured out which one fit (33-2252 btw). But thinking about it, the MAF is so close to the filter media that I worried about oil getting on it.
| The Following User Says Thank You to Draco-REX For This Useful Post: | Username (09-05-2012) |
Didn't even think about that. Will you think about High-Flow Air Filter?
#4 | |
FT86Club Official Vendor
If you properly clean and oil the filter, you'll never have that issue. I've used oiled and oil-less filters on everything from vintage motorcycles to brand new cars and never had any issue. Also, K&N is very adamant that their products don't cause issues. Check the links for more info! K&N is my 1st choice in air filters on my personal cars and motorcycles. http://www.knfilters.com/warranty.htm http://www.knfilters.com/check_engine_light.htm http://www.knfilters.com/common_misdiagnosis.htm http://www.ftc.gov/bcp/edu/pubs/cons...ts/alt192.shtm http://www.knfilters.com/air_filter_testing.htm |
Drives: 2013 Scion FR-S Firestorm Red MT
I was thinking about it, funny how Amazon says 33-2252 will not fit when you put in the 2013 Scion FR-S (just outdated page I'm sure).
So should I buy the K&N drop ins or are they a waste of $$$
![]() Last edited by Liquidsnake; 06-08-2012 at 02:02 PM. |
Drives: FR-S|(2)AE86|TA22|E30M3|E36M3|BPLeg
Thats the question... Not sure if anyone knows yet.
Typically, drop in filters make power, but on cars like this- its often 5HP or less... Right now the only dyno figures I have seen are on prototype replacement intake 'systems' |
Drives: Clio TCE
I like ITG filters. The 3 layers foam has good filtering capacity (still inferior to the stock paper filters) and it doesn't need oil.
On 200-300 hp cars a panel filter can be good for up to 3-4 hp...I'm talking about max power. I change it only because I save up on the servicing. |
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
You can also use a TRD PTR43-00085 the FR-S uses the same 17801-0D020
filter as an 03-08 corolla and a 1st gen TC |
#10 |
Drives: Black
I just got the 33-2252 k&n. And it sounds different .... I like
| The Following User Says Thank You to RWD-boxer For This Useful Post: | Subaruwrxfan (06-11-2012) |
#11 |
Where did you buy it from? Online? Or local?
#12 |
Drives: Black
It's the same as the scion tc 1gen
Got it at autozone. 51$ |
#14 |
Drives: 2013 BRZ Premium 6MT
didnt someone remove the air filter and say the car made no extra power? if thats the case i doubt any filter will make a difference. the only benefit of a k&n is never having to replace it.
2013 Subaru BRZ Premium 6MT -STOCK!
#15 |
Drives: Mazda3
I had a k+n in a mustang for 70k miles and the engine light came on since the day I installed it.
#16 |
Where did you buy that from?
#17 | |
Drives: Scion FRS
This dyno was with a K&N drop in. http://www.141motors.com/fr-s/dyno.jpg See this thread: http://www.ft86club.com/forums/showthread.php?t=8146 Ishii
#18 |
Drives: Black
If you look at the waves of the stock filter and the waves of the k&n
The k&n is tighter ....means that there is more surface area = more flow For now that may not matter but with exhaust and other addon it will make .0000001 sec difference lol |
#19 |
Drives: Scion fr-s,Lexus is250,4-runner
#20 |
Drives: BRZ Ltd WRB
I have ordered a K&N drop in filter, but I would love to see a dyno if it gives you any extra at all.
Enkei RPF1/K&N/Perrin crank pulley/Visconti Stg1
#21 |
Inverse Animosity
Drives: Celica GT-S
I wouldn't get just a drop in-- i'd get a short ram or something. Just a drop in wouldn't get you much power, but would likely give a bit better response, MPG and sound. I would love to get a heat-wrapped full intake though.
![]() Inverse Animosity- These words codify my declaration of deference, and indemnify myself from the counter-progressive nuisance of biased judgment, ridicule and criticism based on discrimination such as driveline, engine size, pre-established dogmas, preconceptions or any such trivial nonsense. |
#22 |
Drives: 2000 Subaru Impreza 2.5RS Coupe
Are you guys seriously thinking that a drop in filter will add any noticeable power???
A drop in filter isn't increasing the amount of air sucked into the intake enough to actually help the performance of the engine. IMO K&Ns are just a waste of money I mean sure they last "forever" but you still have to clean and oil them. I'd much rather just pay the $50 for a brand new filter every 10k miles or so.. If you really want to add performance through an intake system just get a CAI or SRI even then I doubt those will add much a noticeable difference alone. Full bolt ons and a tune would be the only real way to get a nice performance increase that would be noticeable. |
| GT86 + Drop & 18X8 Advan RG-D | wtf.bbq | Wheels | Tires | Spacers | Hub | 44 | 08-24-2012 03:00 AM |
| K&N Drop In Filters! Available at Vivid Racing!! | vividracing | Engine, Exhaust, Bolt-Ons | 6 | 06-29-2012 04:53 PM |
| Service Parts! Motul Oil / Oil Filters | vividracing | Mechanical Maintenance and Tools | 8 | 06-19-2012 11:46 PM |
| TRD Drop in AF | feldy | Engine, Exhaust, Transmission, ECU | 2 | 06-05-2012 07:40 PM |
