follow ft86club on our blog, twitter or facebook
FT86CLUB.COM
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > Northwest
Northwest AK, ID, OR, WA
Old 06-05-2012, 01:01 PM   #1
DarrenDriven
Evil Asphalt
DarrenDriven's Avatar
Drives: 2013 FR-S Asphalt
Anyone here every pulled headlights apart?
I know that there are a bunch of DIYs on the net about separating your headlight housings, but has anyone here in Portland ever actually done it successfully? I'd like to paint the chrome in my lights black, but since this is my first attempt I don't want to screw it up. Help?
Old 06-05-2012, 01:05 PM   #2
colHolm
Default User Title
colHolm's Avatar
I've actually pulled apart the FR-S headlight already... It's not too bad, but the silicone they use is super-gooey once you heat it up.
Pre-heat the oven to about 225 F, and put the headlights in (after removing the screws around the edge, all the wiring, bulb sockets, rubber covers, etc) for about 12-14 mins.
Be careful - it's hot when you take it out! Guide the little clasps over the tabs, and then start prying (I started at the inside corner where the headlight narrows). Try to make sure the goopy silicone doesn't fall on the inside of the lens - this might be a good time to have some one helping you; they can cut the silicone and keep it away from the lens.
I'll be posting a full DIY in the coming weeks. I'm just waiting for a couple things...
Cheers!
Never argue with an idiot; onlookers will have trouble telling you apart.
colHolm is offline   Reply With Quote
Old 06-05-2012, 01:12 PM   #3
DarrenDriven
Evil Asphalt
Thanks colHolm! I think that the FR-S light will look SUPER mean with all the chrome blacked out. I have two HID kits on the way, low and high beam, so I'll do the blackout soon.
Old 06-05-2012, 02:24 PM   #4
indesign
indesign's Avatar
Drives: 2013 Whiteout FRS
darren, keep us posted on how this turns out. i certainly like that idea.
how much did you pay for your HID parts? That'll probably be the first modification I do after I get my car.
indesign is offline   Reply With Quote
Old 06-05-2012, 06:20 PM   #5
DarrenDriven
Evil Asphalt
I am negotiating a deal for my HIDs... not sure what I am paying yet. I will post an update as soon as I have it.
Old 06-05-2012, 06:31 PM   #6
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Since your taking the headlights apart, now is best time to replaced the projectors with better ones
Youre putting in hids too so yeah you really need a better projector To eliminate the glare
86_ZN6 is offline   Reply With Quote
The Following User Says Thank You to 86_ZN6 For This Useful Post:
RRnold (06-05-2012)
Old 06-05-2012, 09:58 PM   #7
colHolm
Default User Title
colHolm's Avatar
Doing some R&D work with the retrofit source. Hopefully they'll have one of their retro-quik system kits available soon!
Old 06-05-2012, 11:15 PM   #8
RWD_only
Lurks 'n stuff
Drives: 1994 Mazda Miata
I took apart the headlights on my SC300 way back when. It went...ok. Just be patient and precise. It helps to have someone there who's either a car person and knows what's at stake, or someone who'll listen to you without bitching, griping, or complaining.
RWD_only is offline   Reply With Quote
Old 06-06-2012, 12:46 AM   #9
DarrenDriven
Evil Asphalt
I've got someone who will help me out... I think I should be able to handle this. I am going to wait until my HID kits show up so I can play with the projector output while it's easier to get at the innards.
Old 06-14-2012, 08:40 PM   #10
DarrenDriven
Evil Asphalt
OK, we are working on this... my question at this point is do I need to heat anything up to reassemble the two halves or do I just stick them back together cold?
Old 06-14-2012, 09:01 PM   #11
Sanka86
Drives: 2013 Subaru BRZ Limited SWP
yeah you should heat them back up so you get a good seal. atleast that what i did when i would black out civic headlight housings.
Sanka86 is offline   Reply With Quote
Old 06-14-2012, 09:02 PM   #12
DarrenDriven
Evil Asphalt
OK, I just heated one light to 225 for 13 minutes and tried to pull the halves apart but they wouldn't really budge. I just stuck it back in the oven for five more minutes at 225... but if they don't come apart after that I am going to bump it up to 250 for another five minutes.
Old 06-14-2012, 09:10 PM   #13
colHolm
Default User Title
colHolm's Avatar
Make sure you took all the screws out from around the perimeter. There are also tabs you'll have to lift up.
Old 06-14-2012, 09:13 PM   #14
MmmHamSandwich
Vindictive S.O.B. Member
MmmHamSandwich's Avatar
Drives: '13 FR-S
If you have a heat gun handy, forget the oven. Keep that sucker moving along the seam and slowly pull apart. That's how the pros do it.
Also for those of you acting like you just slap a new projector in there willy nilly, I got news for you. It is difficult work, especially on a new platform. There's a reason retrofitters with established reputations charge good money. If you've never done a retrofit and just bought all your parts off TRS and think you're gonna bang if out in a couple days in your garage there's a high probability you will have frustrating failure and will ruin at least one set of lights. You're probably better off utilizing the stock projector. If you're dead set on putting a reknowned projector in your headlights you will probably save money in the long run looking into a retrofitter. Just my two cents.
I got a friend who might end up doing some work on an FR-S' headlights soon. If so I'll make sure it ends up posted.
MmmHamSandwich is offline   Reply With Quote
Old 06-14-2012, 09:41 PM   #15
DarrenDriven
Evil Asphalt
I got them apart... I think it was more technique than a heat issue. Laying down the paint right now... should be able to reseal them tonight hopefully.
Old 06-15-2012, 09:54 AM   #16
Neziah
Drives: 2013 HotLava FRS, 2005 Legacy
Can't wait to see a picture and hear how they turn out!
Neziah is offline   Reply With Quote
Old 06-15-2012, 04:58 PM   #17
DarrenDriven
Evil Asphalt
Complete writeup with photos here:
http://www.ft86club.com/forums/showthread.php?t=8788
Search this Thread:
Advanced Search
FR-S w/ BRZ headlights :) Carban Photos, Videos, Wallpapers, Gallery Forum 30 06-04-2012 10:19 PM
Pulled over on way home from dealership in our project BRZ...Wreckless Driving! JRitt Subaru BRZ General Forum 33 05-30-2012 06:22 PM
Headlights too dim Franisco Other Vehicles & General Automotive Discussions 10 05-15-2012 03:11 PM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks Subaru BRZ General Forum 21 01-10-2012 09:54 AM
Fugly Headlights Chokonen888 Scion FR-S / Toyota 86 GT86 General Forum 41 10-18-2011 12:51 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
