follow ft86club on our blog, twitter or facebook
FT86CLUB.COM
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Suspension | Chassis | Brakes
Suspension | Chassis | Brakes Relating to suspension, chassis, and brakes.
Old 06-01-2012, 12:45 AM   #1
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Sway Bar Upgrades
Does anyone know the part number for the stock rear sway bar for a 2010 Forester XT? It's 17mm and apparently is a direct swap. Not a crazy upgrade but cheap! I want to give it a shot before I go crazy for aftermarket bars (which I know I will)
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 RTR~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 06-01-2012, 09:38 AM   #2
Draco-REX
Draco-REX's Avatar
Drives: 07 STI, 03 WRX, 13 BRZ
The rear bar in the BRZ/FR-S is 14mm. Going to 17mm is a big bump in roll stiffness. The Cusco aftermarket bar is only 16mm. You'll end up pretty tail happy.
Old 06-01-2012, 09:52 AM   #3
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
that stuff can be tuned out. for low speed autocross, I'd want a looser rear and then tune it out with toe settings...
but someone needs to try to see if it works.
Matt Andrews is offline   Reply With Quote
Old 06-01-2012, 09:59 AM   #4
Racecomp Engineering
and GTWORX
Drives: 2013 BRZ, 2012 Paris Di2 & 2011 WRX
We're planning on testing 16, 17, 18, and 19mm rears. And then again when we have a front to test as well. Also need to do some math when I have more time.
- drew
Be a fan on facebook for news, rants, ravings, videos, etc.
https://www.facebook.com/RacecompGTworx
410-846-5407
www.racecompengineering.com
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
Fly Guy (06-01-2012), Jedi1 (06-16-2012), Scooby South (06-01-2012)
Old 06-01-2012, 12:28 PM   #5
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Is there any stock bar that will fit that is 16mm?
Old 06-01-2012, 12:48 PM   #6
and GTWORX
Yes, the current WRX rear I think is 16mm.
- andrew
410-846-5407
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
blu_ (06-04-2012), NYC BRZ (06-01-2012)
Old 06-01-2012, 02:25 PM   #7
Dimman
Kuruma Otaku
Dimman's Avatar
Drives: BD Legacy and Mk3 Supra Turbo
Am I doing this right? If lever arm length, attachment point, bar total length and hollow/solid remain the same, and only the diameter increases, will the stiffness increase be (NewDiameter^4)/(OldDiameter^4), so ~ 70% more roll stiffness for a 16mm bar?
Because titanium.
Old 06-01-2012, 02:36 PM   #8
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Am I doing this right?... so ~ 70% more roll stiffness for a 16mm bar?
For a solid bar, yes. For hollow it would be (od2^4-id2^4)/(od1^4-id1^4). But it's not 70% more roll stiffness, just 70% more bar stiffness.
Actually it will probably end up being a tiny bit more than that, due to reduced deflection in the lever arms.
old greg is offline   Reply With Quote
Old 06-01-2012, 06:43 PM   #9
Dimman
Kuruma Otaku
Dimman's Avatar
Ok. Then would roll stiffness gain be (springs + new bar) / (springs + old bar) ?
This weekend I'm going to try to see if I can understand David Gould's roll/weight transfer stuff.
Because titanium.
Old 06-01-2012, 08:22 PM   #10
old greg
Rocket Surgeon
Drives: PSM GGA OMG
More or less. Don't forget the motion ratios.
Old 06-01-2012, 08:32 PM   #11
Dimman
Kuruma Otaku
Dimman's Avatar
I'm going to try and figure out the front first. 1:1 for both... I was using .8 in the back before, but RCE says ~ .75. So my eyeball wasn't too far off. Will have to see about the rear bar's motion ratio next.
Because titanium.
Old 06-04-2012, 11:38 AM   #12
Archer1.8
Drives: 2005 Subaru Legacy GT Stage 1
Those looking for A VERY CHEAP 16mm rear swaybar upgrade. Check out the 10+ Legacy GT rear sway bars. They are the same as the STi which shares the BRZ platform. Guy on my forum selling them for $25
http://legacygt.com/forums/showthrea...la-179658.html
Archer1.8 is offline   Reply With Quote
Old 06-04-2012, 11:46 AM   #13
Asterisked Accolade
Inverse Animosity
Asterisked Accolade's Avatar
Drives: Celica GT-S
Does anyone think that maybe the stock rear sway bar should be left as is, and only the front should be stiffened up? I ask because i would think a stiffer rear sway bar would increase an already present oversteer.
Asterisked Accolade is offline   Reply With Quote
Old 06-04-2012, 11:53 AM   #14
Archer1.8
You would think so, but its drivers preference. I have always driven nothing but subarus. EVERY subaru understeers like a pig. So the rule of thumb was always bigger rear bar, but thats my preference. I think a bigger bar upfront as well as a 17mm adjustable rear bar to dial in preferance would be good.
Old 06-04-2012, 11:58 AM   #15
Asterisked Accolade
Inverse Animosity
Drives: Celica GT-S
Ooh, i forgot about adjustable sway bars. Good call. And i suppose i would rather oversteer than understeer.
Old 06-04-2012, 12:14 PM   #16
and GTWORX
I would be wary of just jumping into a big rear bar for the FRS with no other changes but with the BRZ, I think you can safely go a little bigger in the rear. We're doing some testing to find a sweet spot both with the OEM front bar and later with an upgraded front.
- Andrew
410-846-5407
blu_ (06-04-2012), Fly Guy (06-04-2012), GodSays (07-15-2012)
Old 06-04-2012, 12:25 PM   #17
Draco-REX
Draco-REX's Avatar
If this were a usual Subaru, I'd say do the sways first. But in this case, I'm going to do RCE's springs first and then decide if I want to change the bars.
Old 06-04-2012, 01:09 PM   #18
Archer1.8
Agreed. As I do no have a BRZ/FRS...it looks like a drop is in order first, then maybe some bracing, strut bars, bushings, then some sways. If this car is even half as good stock as my Autox 2.5rs with full suspension mods was. I can not wait to own one.
Old 06-04-2012, 01:10 PM   #19
Archer1.8
Did anyone find out if the front bar is similar to any other subaru setups?
Old 06-04-2012, 01:11 PM   #20
mines13
FT86Club Official Vendor
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
- Andrew
I am on the same page, after a spirited test drive I think I would not mind some more front roll stiffness. Especially with my desire to run a wider stickier tire all around. I will not be touching the rear bar for a while if at all on my FR-S.
"Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere." -Colin Chapman
My build thread
mines13 is offline   Reply With Quote
Old 06-04-2012, 01:32 PM   #21
and GTWORX
It is unique for the BRZ/FRS.
I'm not convinced bracing and strut bars are all that necessary for most applications, but we'll see. Bushings in a few key areas will be good to have.
Changing the swaybars will for sure be helpful for auto-x, and an adjustable rear can be very nice. I do tend to stay away from very large swaybars though.
A good alignment is first.
- Andrew
410-846-5407
Old 06-04-2012, 02:01 PM   #22
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Here are my list of desired suspension changes in order (it's a short list)
1. More negative camber up front
2. Slightly stiffer spring rates all-around with good dampers.
Ummm that's it for now!
uspspro is offline   Reply With Quote
Search this Thread:
Advanced Search
adjustable sway bars!!! carbonBLUE Suspension | Chassis | Brakes 9 05-04-2012 07:42 AM
STI rear sway bar carbonBLUE Suspension | Chassis | Brakes 0 03-25-2012 11:58 AM
Cosworth Internal Upgrades Confirmed DanPO Engine, Exhaust, Transmission, ECU 27 03-08-2012 10:18 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
