Old 05-31-2012, 10:39 AM   #1
RaceR
Drives: 2010 Cooper S, 74 Beetle
Winter tires and wheels, what is your plan?
I have been thinking about using the OEM 17x7 wheels and putting on some 205/50-17 winter tires.
But not completely sure. I would much rather have 16" wheels for the winter due to the larger sidewall. 195/60-16 would be nice for winter.
But that would mean I would get a new set of 16" wheels for winter use.
I would also like to have a new set of nice 17" wheels for daily summer driving.
If im going to Autocross and be competetive I would need a set for that as well. Either 16" or 17" inch. Im most likely going to autocross it and would need a set of wheels with semislick tires to be competetive due to regulations here.
That is 3 new sets of wheels and tires! Expensive! Not gonna happen after buying a new car of the dealer.
Selling the OEM 17" wheels will probably not give me much money, so that is most likely not an option.
I could use them as track wheels tough. But they are a little narrow and could be lighter. Or would the narrow 7" tires not be a problem with say Toyo R888 in 235/40. Maybe 215/45tires would be just as good since they heat up quicker and might make the car more agile??
Decicions decicions.... In my case. Would you use the 17" OEM wheels for winter or for autocross competitions?
What are your plans for winter wheels and tires?
RaceR is offline   Reply With Quote
Old 05-31-2012, 11:37 AM   #2
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
I'll be reusing the aftermarket wheels I had on my CR-Z. I found a set of Blizzaks on Craigslist for cheap which I will be mounting on them. The only question I have at this point is will I spend the extra money to have TPMS sensors installed in them.
Old 05-31-2012, 12:14 PM   #3
Klinn
Klinn's Avatar
Drives: '20 Pure Red BRZ, '20 Torch Red C8
I intend to use the OEM wheels with winter tires and get an aftermarket set for combined summer street and Solo2 use.
Not going to get a set of dedicated Solo2 tires/wheels. I know that will leave me behind folks with Hoosiers but I prefer to just arrive and drive.
Klinn is offline   Reply With Quote
Old 05-31-2012, 12:23 PM   #4
RaceR
Yes, TPMS. :/ Im pretty sure i will put the sensors in both my summer and winter wheels. Not helping the budget!
My toughs:
1. Some warning light is not fun when owning a car for several years. Especially not on a new car. I would sleep and feel better having everything working 100%
2. I might need them for EU-inspection
3. I will get some of the cost back the day I sell the car. Having sensors in all wheels.
What size tires are you guys thinking to use in the winter?
Old 05-31-2012, 12:32 PM   #5
neutron256
neutron256's Avatar
I've already got the tires they're used, but with plenty of tread left on them. They are the stock size 215/45/17. I would have gone with 16" but I've already got the 17" wheels.
Old 05-31-2012, 04:04 PM   #6
madfast
Drives: 2010 Evo X MR-T
steelies FTW?
http://www.discounttiredirect.com/di...=Car%2FMinivan
madfast is offline   Reply With Quote
The Following User Says Thank You to madfast For This Useful Post:
JMon85 (11-03-2017)
Old 05-31-2012, 04:06 PM   #7
Calum
That Guy
Drives: 2013 asphalt FRS MT
My plan is to run the factory rims that came with my winter beater, on the winter beater.
Old 05-31-2012, 06:34 PM   #8
YankBoffin
YankBoffin's Avatar
Drives: BRZ, WR Blue, Premium Trim
I'm hoping my old OEM 2002 WRX wheels (16") will fit, since I have a newish set of snow tires on them. As far as bolt pattern and offset, I think they should fit, bit I haven't studied the situation enough to know for sure.
YankBoffin is offline   Reply With Quote
Old 06-01-2012, 12:36 AM   #9
xcelir8brz
Drives: 2013 BRZ Limited
I have some 16" Dunlop Snow tires. Would like to know if I can put on some 5x100 16" Rims and if it would clear the rotors/brake calipers.
If so, I'm set (i.e. needing to buy four rims for $500) vs. $1200 for 17's.
xcelir8brz is offline   Reply With Quote
Old 06-01-2012, 12:59 AM   #10
neutron256
neutron256's Avatar
Here is a great site for calculating size compatibility of tires.
http://www.1010tires.com/tiresizecalculator.asp
Old 06-01-2012, 11:46 AM   #11
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
going to wrap the stockers with winters. I'll go either a tall 205 or the stock 215 size. Haven't decided on a tire yet.
Old 06-01-2012, 12:50 PM   #12
Future
Future's Avatar
Drives: BRZ!
Going to plastidip the OEM wheels for winter (black looks good) stock size, set of 18"s in the summer, set of 16"/17" don't know yet for track use...
Many will likely say the FR-S/BRZ needs more power and while more wouldn’t hurt, those folks (the same ones who have probably never driven on a track) are missing the point.
Future is offline   Reply With Quote
Old 06-01-2012, 12:55 PM   #13
#87
I usually post drunk
#87's Avatar
planning to put a 225 width winter tire on oem wheel and get a new set for next summer
#87 is offline   Reply With Quote
Old 06-01-2012, 01:18 PM   #14
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
you do not want a wider winter tire
you want a narrower winter tire, 205 max, pref 195 with 55-65 sidewall.
remember contact patch shape is determined by weight. In the winter time you want a square patch for braking and accelerating, not to mention a large, soft sidewall to help with finding traction.
Widest Track tires for stock wheels?? track_warrior Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 56 10-11-2015 12:01 PM
A set of clown-shoes: 205/60R16 tires on 16 x 7 wheels.... rogerdalien Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-31-2012 01:09 AM
Delete driver01 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-21-2012 01:50 AM
Stock tires winter feldy Scion FR-S / Toyota 86 GT86 General Forum 33 05-29-2012 11:38 AM
What size wheels do you plan on running? poormans_LFA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 51 04-28-2012 06:30 PM
