ACE Headers
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Suspension | Chassis | Brakes
Suspension | Chassis | Brakes Relating to suspension, chassis, and brakes.
Old 05-22-2012, 01:57 PM   #1
sparks
sparks's Avatar
BRZ front camber adjustment confirmed
Here ya'll go. Camber adjustment on the BRZ
"Replace the upper mounting bolt of the shock absorber ASSY FR and knuckle with a replacement bolt. (Part No.: Flange bolt 1460 (901000394))"
"The range adjustable by replacing the bolts is 0 45'"
I'm trying to get a screen shot of the online manual
sparks is offline   Reply With Quote
The Following 2 Users Say Thank You to sparks For This Useful Post:
ESBjiujitsu (05-24-2012), Scooby South (05-22-2012)
Old 05-22-2012, 01:59 PM   #2
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Is that the normal standard one??? thanks OBTW..can you tell how much the Alternator puts out..
Bill
Scooby South is offline   Reply With Quote
Old 05-22-2012, 02:00 PM   #3
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Yes, we already knew this a while back when I posted the information from the Scion manual.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 05-22-2012, 02:01 PM   #4
sparks
sparks's Avatar
Bill
Different part number for the top bolt
And YES the title says BRZ
Old 05-22-2012, 02:02 PM   #5
Scooby South
Conedancer
Jeff
Jeff...it has to be in 'both' manuals to be considered for stock class racing in Autocross... so its good comfirmation that its in both..
Bill
The Following User Says Thank You to Scooby South For This Useful Post:
ESBjiujitsu (05-30-2012)
Old 05-22-2012, 02:07 PM   #6
Jeff Lange
Jeff Lange's Avatar
True, good point.
Jeff
Old 05-22-2012, 02:15 PM   #7
sparks
sparks's Avatar
Bill
This is all that's listed under specs
SERVICE DATA
Charging circuit without load
Standard amperage: 10 A or less
Standard voltage: 11.3 to 15.6 V
Charging circuit with load
Standard amperage: 30 A or higher
Brush length
Standard length: 22.5 mm (0.885 in.)
Minimum exposed length: 5.0 mm (0.196 in.)
Battery type
55D23R
Old 05-22-2012, 02:31 PM   #8
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
Why wouldn't this have been included stock? Is this simply a bolt with an eccentric?
Matt Andrews is offline   Reply With Quote
Old 05-22-2012, 02:36 PM   #9
Racecomp Engineering
It's the same eccentric bolt IIRC that's used OEM on every other Subaru. We knew it fits but it's awesome to see that it's in the manual if that means it's usable for stock autocrossers (i'm not clear on that myself). EDIT: see below.
No idea why it's not just included from the factory but I'd highly recommend it for everyone, even if you get camber plates. It's cheap too.
- Andrew
Old 05-22-2012, 02:54 PM   #10
sparks
sparks's Avatar
- Andrew
Andrew - I ran the number and it's original on the 2012 Impreza/Forester, and for alignment (crash bolt) on BRZ
Old 05-22-2012, 03:05 PM   #11
Ah yes, Myles in the office is more on top of that stuff than me. Good call.
- Andrew
Old 05-22-2012, 03:32 PM   #12
sparks
sparks's Avatar
Here's the screen shot
The Following 3 Users Say Thank You to sparks For This Useful Post:
ESBjiujitsu (05-24-2012), jdrxb9 (05-24-2012), Scooby South (05-22-2012)
Old 05-22-2012, 06:19 PM   #13
Calum
That Guy
Drives: 2013 asphalt FRS MT
plus or mines .45 degrees....? Am I reading that right? Doesn't really seem like it'd be enough.
Old 05-22-2012, 06:50 PM   #14
sparks
sparks's Avatar
0.0" +/- 4.5' = .075 degrees - Recommended
0" 45' = .75 degrees - With the adjustment bolts
Its the minutes to degrees covnersion
Search this Thread:
Advanced Search
BRZ front grille mod bloomy116 Cosmetic Modification (Interior/Exterior/Lighting) 208 05-18-2018 11:57 AM
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 04:41 PM
My frs confirmed. Now what? Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 51 05-09-2012 06:05 PM
Comparing front end of the FR-S/FT-86 to BRZ DIG1992 Photos, Videos, Wallpapers, Gallery Forum 66 11-21-2011 06:26 PM
Handling: Camber Attainable with Struts. Your Experiences? skeeler Suspension | Chassis | Brakes 31 11-09-2011 05:07 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
