| Tracking / Autocross / HPDE Exactly what these cars were built for! |
#23 |
class with rear diffuser
So I have a pre-order in and when I changed my order I got bumped likely to the bottom of the list, so my car is still wait listed and probably won't show up for a little while.
There is a dealer with the model I want who will be getting one sooner, within the next few weeks, but it has the diffuser as an option, along with a couple other unnecessary things like the chrome trim and wheel locks. I like the diffuser but I wanted to race the car in stock class and I'm not sure if it's legal or not. I can't remember how things go as far as factory versus port installed options... I don't think it does anything to the car except add weight so I may end up just removing it and selling it if it bumps me out of stock. |
#24 |
Drives: 2013 FRS Asphalt
You can run any option in stock as long as its a factory option. Dealer or port installed items are not considered stock.
#25 |
Drives: 2013 Subaru BRZ
Well I took my BRZ to an autocross yesterday... and I feel foolish.
Some back story about myself. I've autocrossed for about 6 years now. I've got a lot of wins under my belt with my old 07 STi and my 99 2.5RS. I'd like to think that I know a bit about driving but know I've got a lot to learn. But it was my lack of gadget knowledge that owned me yesterday. I've never autocrossed a rear wheel drive car and one so advanced as the BRZ. My experience stems from FWD and AWD with little to no driving aid/assists on the vehicles. I didn't get a good feel and impression of the BRZ until my 8th run of the day and I only got 9 runs. Thoughts: Awesome car! light and nimble as advertised. I'm 6'3" tall and I had room to spare with my helmet on For you tall guys out there, this is a big plus.My mistake of the day and an epic one I might add. Traction control and how to properly use it. The manual lied. It states pressing TRAC OFF for 3 seconds and it will disable traction control and other driving aids until turned back on or the vehicle has been shut off. Well its more like 8 seconds that you have to hold that button. I didn't know this until my second to last run. With the SPORT button on you can get a little sideways with some spin but a hard accel out of a corner and the car falls short on its face. ABS applied the brakes and cut the throttle every time I exited a corner on the throttle. I had to run the course in first gear JUST to try and overcome this with power. With all the driver aids off I dropped my lap time by 3 seconds. Unfortunatly for me I only had 1 run after that and didn't get a good feel for the car. But there is an autocross next weekend I can attend and one after that. I'll have this dialed in soon. The BRZ is very unlike a subaru and doesn't handle like one either. This is a good thing. And the tires suck... I'm swapping those out before the next event. |
| The Following User Says Thank You to Mavrik For This Useful Post: | Fly Guy (06-04-2012) |
#26 |
Drives: 12' Evo X , prior 1st 86 FR-S
Thanks for info, my 1st event I just turned all off. Normally we get 6 runs and didn't want anything cutting power on me! Nice you get soo many runs!! Our course is near 50 sec - 1min avg.
Good luck Racing !!!
Autocross & Drift = my Anti Drug!!
I have Car A.D.D prior few: 12' Evo GSR, 13' FR-S, 11' STi, 08' 135i, 07' 335Xi, 08' STi, 04' 350Z, 04' STi, 02' WRX. 96' GSR, 04' SE-R/SpecV |
#27 |
Drives: '87 Corolla GTS, '13 FR-S 6MT
I took the car out yesterday with a friend who also picked up an FR-S. I ran mine completely stock while my buddy ran with 225 Star Specs, -2.4 camber up front and -1.6 out back.
The car is very neutral and rotates extremely easily with a little trail brake in and gas out. Steering is very accurate and communicative. The rear steps out willingly when you want it to and is very easy to keep there or bring it back, no snap nothing! I used to push (understeer) a lot with my previous car when trying to make up time but the FR-S is sooo transparent that I knew just how hard I could stuff it in a turn. This track layout had a fast off camber sweeper that was a blast! Plant the front at turn in, start feeding in throttle so the rear steps out and start using the throttle to steer, wooooHOO! I got six runs and by the end the tires started to feel greasy. I ended up being about 2.7 seconds slower than my buddy who is an excellent driver. I'm not sure how much time his tires and alignment were worth, hopefully 2.8 secs lol! Can't wait for the next event! Edit: Forgot to mention the super annoying fuel cut. When you hit redline the engine slowly goes down to about 7k, it doesn't just bang off the rev limiter like normal. Last edited by RiskyTrousers; 06-04-2012 at 05:55 PM. |
#28 | |
Drives: Asphalt FRS
#29 | |
I was completely stopped, e-brake up, waiting in grid when I was pressing the TRAC OFF button. I had read earlier that it could not be switched off when in motion. TRAC OFF indicator appeared the moment I pressed the button but the second light didn't appear until roughly 8 seconds later. I tried today to see if you can have VSC and TRAC OFF at the same time. But when TRAC OFF with all driver assists turned off is active, it seems VSC is no longer on. It turned off on its own. |
#30 |
Senior Citizen
Drives: Scion FR-S
Can I ask how your friend achieved his camber settings? Was that with the stock alignment bolts?
#31 |
#32 | |
Drives: Ford F-150 (not for long)
-2.4 up front is AWESOME, but for stock purposes it won't work. I highly doubt the subie/scion bolts get you anywhere close to that. |
#33 |
I noticed the fuel cut off as well. So weird. You have to hold both buttons down till they both say off. I still put it in sport mode. When in sport mode the trans holds gears longer! However I still leave it on sport when doing Manuel mode with the paddles. That fuel cut off is wicked though. Wonder if Mts can bounce or if they cut fuel as well.
#34 |
I think they're called SPC camber bolts. I think they maxed out at -2.9 but he backed it off to -2.4
#35 |
#36 |
Manual.
#37 | |
I never got right to the redline on my autocross runs so I couldn't tell you how it felt for fuel cut at that point. |
#38 |
First 86
The fuel cut at redline is terrible no matter what nannies you have turned off or on. Was hoping it would be more like my MR2.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered 5/17.
Mods: Motegi 17x7 TrakLites, Hankook RS3s, K&N 33-2300 Filter, Nameless Perf. Track Pipe |
#39 |
I bet the fuel cut can be tuned out. The big question is if it will cause serious damage...
#40 |
Site Moderator
Drives: 97 ITR, 00 GS-R, 96 GS-R Race Car
Car felt good for sure. I sucked driving it.. and yeah, that soft fuel cut sucks ass.
Link to videos/me talking about how much I suck. http://www.ft86club.com/forums/showp...&postcount=120
-Dave
97 Integra Type-R, 00 Integra GS-R, 96 Integra race car and a 2013 BRZ-L! |
#41 |
Conedancer
Drives: 2013 Subaru BRZ SWP
Well...had my first event this past weekend. Car drove well but I have noticed some things:
- it seems that when on the power in a straight line...it feels different than on the power in the corners...Situation: going thru the slalom, with all Traction Control off...the car didn't want to accelerate...like it was boggy.... now in a straight line...it feels fine.. I am not thoroughly convinced that there still is some kind of electronic/ECU device *Yaw Sensor maybe, holding the car back.. The car transitions really well..and the BRAKES are fantastic...for stock... its easy to stab brake and kinda steer with the throttle if you have to... it just rotates soo well.. -Traction control is the DEBEL...nuff said -the lack of Camber is going to be this cars downfall, I feel... I understand the engineering of what they did...but damn, give us a little something to play with -the Torsion Rear Diff seems adequate for now.. but I am already looking at putting a OS GIKEN 1.5 way diff in it as soon as I know for sure what ST class its going to. -It really needs a tune...that dead/Flat spot in the lower RPM band really kills the momentum of the car...I am sure an aftermarket tuner will be to fix this.. but as she rides stock...it sucks. -The car is Quick, Nimble and super fun... my codriver and I Paxed in the top 21...and Raw time in the top 24...out of 104... theres things that I feel will need ALOT of development...and some none at all. -its a point and Shoot type car...it will pretty much go where you steer it..the gearbox seems adequate for now..but don't leave the traction control on..as you will BOG the launch...no matter what RPM you think your going to leave at... -car is easy on the eyes on course.. ![]() -Quick note on Fuel....Fuel started at 1/4 tank...after 13 runs...6 ea normal...and 1 rerun for timing...never had a fuel issue. the fuel light never came on... we did some testing in parking lot the night before the event...Fuel light was on...and basically drove in sweeping circle for about 5 mins. at speed...like a G'force circle....Never hiccuped once... so as long as you don't run out...I would say 1/4 tank or less is a good starting point for the Fuel..more than that...is just extra weight....We did have a 5 gallon jug on site in case we needed any from the runs..which looks like that will be become std practice....but never needed it...ended up putting it in for the drive home.. more as I think of it.. Bill
#42 |
form follows function
Drives: '95 M3, '07 Si, '13 BRZ
Thanks for the fuel tip especially. I'll target a quarter tank for autocrossing until lower is proven.
2013 Subaru BRZ <STX> :: 2007 Civic Si <for sale> :: 1995 BMW M3 - STU <for sale>
#43 |
I autocrossed with a full tank this past weekend. tire pressure at 38psi in the front and 35psi in the rear. dry pavement with all trac off this time haha.
Managed 5th place PAX and 13th place Raw. Not to bad considering I was only 2 seconds off the fastest time of the day and 7 of those ahead of me were about .005 between them.
2013 SWP Subaru BRZ. First in Alaska
#44 |
Drives: Hydra EMS Powered FRS Raven Black
I'm pretty sure the rev limiter is a throttle cut which is what most of the DBW cars do and not a fuel cut. When we finish the Hydra EMS computer we'll use a tradition ignition cut cycling through the cylinders so you can stay on the rev limiter. This was also killing me when road racing.
Even on slick tires I never experienced fuel starvation even when the fuel line came on so I'm very happy about that. The grip level is so high I'm really worried about oil pickup starvation but it seems without a boosted motor the oil is just not collecting in the heads as badly as the STis do. I noticed no oil loss from all of the racing sessions where even a stock STi would have drank a quart of oil. |
| The Following User Says Thank You to Element Tuning For This Useful Post: | Scooby South (06-13-2012) |
| Bored to death, give me some movie names! | 82mm 4g63 | Off-Topic Lounge | 36 | 03-07-2013 02:02 PM |
| Autocrossed FR-S at Scion FR-S First Drive Event in Baltimore! | jackoskate | Scion FR-S / Toyota 86 GT86 General Forum | 69 | 05-08-2012 06:45 AM |
| Which would you give up? | ant08 | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 03-31-2012 03:32 AM |
| Let's give $1 to the first total'd FRS owner | miata | Scion FR-S / Toyota 86 GT86 General Forum | 55 | 01-06-2012 10:00 AM |
| Give Sabine Schmitz the FT86 for some Nürburgring action | Andy | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 10-21-2011 01:51 PM |
