| Engine, Exhaust, Transmission, ECU Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
#23 |
Drives: Red Herring
#24 |
Drives: 2000 MR2 Spyder
#25 |
Drives: 1994 Toyota Tercel
Correct me if I'm wrong but I always thought Catback exhausts replace whatever is behind the catalytic converter but you still would use your original cat...reason for the name catback. Unless your taking about the exhaust companies replacing the original cat with a high-flow cat? I feel like those exhaust would be really pricey...
#26 |
Drives: Clio TCE
As there are two cats emission won't be terribile with just the 1st one.
Obviously the best solution is to replace both of them with a 1st grade sport cats, but to just replace the 2nd with a straight pipe is cheap and won't turn on any CEL as it's not monitored. |
#27 |
Drives: Red Herring
#28 |
Drives: Clio TCE
That depends on the country...
Usually in Italy the pre-cat is enough to pass emission control, if the car is well warmed up. |
#29 | |
Drives: 2011 GR STi / 2013 BRZ
![]() We are working on the details with Prova Japan, however this will also include the new lower rear section as well for the bumper. ![]() ![]()
#30 |
Drives: Audi A5 Coupe
Wow, that is ehhhhh.... special
#32 |
^I agree! I don't like how you can see the exhaust pipe from a distance...
#33 |
Drives: Clio TCE
They could have fit just a mesh grill there, at least it would look like a race car.
#34 |
First 86
Drives: Scion FRS Argento Automatic
Do any of these exhaust mods require ECU mods as well? I'm concerned that if I make a change it will screw something up.
Life is short...NO BORING CARS |
#35 |
Drives: 07 STI, 03 WRX, 13 BRZ
As long as the changes are after the last O2 sensor, you won't need a tune. Generally, a "Cat-back" exhaust is after the cats and therefore won't need to be tuned for.
#36 |
Drives: Clio TCE
Agreed, also, if the reading of the post-cat O2 sensor is correct, regardless of what do you fit, you can leave the ECU alone. The auto-adaptive ability of the ECU will get the A/F ratio, spark advance etc right.
It's rare that a modern ECU of a NA engine is not able to compensate a full exhaust system. You can have problem if the pre-cat O2 sensor position is very different, for example it happens when you fit a long tube header on a car which had short primary pipes and the original sensor plug very close to the engine. The delay of the reading of the sensor or the different wire lenght confuse the ECU. A good programmer can modify the target of the sensor or the delay of the reading. This doesn't mean that a ECU remap can't improve the car, as there are also other characteristic of the management that are not subject to auto-adaptation, for example, throttle mapping, rev limiter, valve lift and timing if there is a variable system etc. |
#37 |
FT86Club Official Vendor
Drives: Matte Black STI
MAF based cars rarely have issues with any kind of bolt on exhaust pieces. The ECU sees more air flow and the car runs the proper air fuel ratio, so its perfectly. Proof of this is when someone dyno's an exhaust and shows the AFR curve before and after. Like this:
![]() No, that is not the catback dyno results, just an example.
#38 |
Drives: 2006 Scion tC RS 2.0
I'm not a fan of the muffler and how the pipe is routed, but I wouldn't mind having the rear diffuser and fabricating my own center exit.
Brake. Turn. Accelerate. Repeat as necessary.
#39 |
Drives: 2013 Subaru SWP BRZ Limited 6AT
Not a fan. Makes it look like the car has got it's junk all exposed.
Man Law #17: A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO inlet tubes + AVO drop-in filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts. |
#40 | |
#41 |
Drives: Future BRZ owner
I don't like the Prova Muffler set up. I was thinking a race pipe option as well. My brother in law had his BRZ at a performance shop last week where they fabricated intake and various exhaust options... After each part was installed the first initial dyno showed great HP increase levels...(Then the bad news) the ECU quickly remapped everything to only show a 6HP increase with exhaust and intake set up. It appears you can't obtain extra horsepower out of this car without a proper tune.
So hopefully Perrin can come out with something in less than 6 months? Perrin - Have you seen the same results so far? Any thoughts? |
#42 |
For sure less than 6 months! A sneak peak for you.
![]() Is there HP to be gained? Yes
| The Following 2 Users Say Thank You to PERRIN_Jeff For This Useful Post: | ESBjiujitsu (05-30-2012), Subaruwrxfan (05-30-2012) |
#43 | |
The good news is that this will keep people who mod improperly from destroying the car so badly. I'm eager to see what the tuners uncover when they rack the ECU open. One of the local tuners is going to try and download the ECU on my BRZ this weekend.
#44 |
FT86Club Vendor
wow, that prova setup is, um, interesting
Justin
| Stock Wheel Weight | Dionysus | Wheels | Tires | Spacers | Hub | 14 | 04-01-2012 12:46 AM |
| Official JDM BRZ weight and MPG | ayau | Subaru BRZ General Forum | 50 | 02-08-2012 01:04 AM |
| weight loss | cynic | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 10-24-2011 03:04 AM |
| Weight of FT-86? | Levi | Engine, Exhaust, Transmission, ECU | 38 | 06-14-2011 09:43 PM |
| FT-86 weight distribution? | tranzformer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 04-04-2011 09:58 AM |
