Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
04-10-2014, 03:00 AM | #15 | |
The 1521 isn't abrasive enough to do that unless you cook em badly. |
04-10-2014, 09:06 AM | #16 |
Site Moderator
Drives: Stuff
Work fine. Make noise.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
04-10-2014, 09:39 AM | #17 |
Drives: 2012 BRZ Premium WRB 6MT
I'm still here! But yes, I am trying to sell M3 kits too! You guys can't hoard all the good sh*t!
Jeff Ritter|Mgr.- High Performance Division
Exclusive Importer AP Racing and Ferodo Racing www.essexparts.com |
04-10-2014, 12:32 PM | #18 |
Site Moderator
Drives: Stuff
Stay away from my M3!
:moneyburn:
-Dave
04-10-2014, 01:53 PM | #19 |
Drives: Used to Drive:Grand-Am GS #54 E36M3
In my case, depth/shape-wise, I had a single radial dimple, with the low spot on the rotor and the high spot on the pad. I experienced no reduction in performance from this anomaly, as described here:
http://www.essexpartsblog.com/news/c...acing-comp-bbk I was not, however, swapping pads nor pad compounds on the same rotor. I wouldn't have had a problem putting on a fresh pad, but would not have put the used pad on a fresh rotor. Last edited by dradernh; 04-10-2014 at 02:05 PM. |
04-10-2014, 01:59 PM | #20 |
Thanks
In the case of this thread, what is a street pad/track pad you can run without ruining the rotors. Meaning, without changing rotors what pad can I run on the street and when I get to the track swap to a different pad, and before going home from track put the street pad in. All that on same rotor. Basically 1 set of rotors, different set of street and track pads. This on AP racing sprint kit.
Thanks
04-10-2014, 02:24 PM | #21 |
Guys...sorry I didn't have time to write a full response earlier. Here's the scoop:
The issue is the J Hook discs, and what you’re seeing is normal. If you look at that pic above, every concentric ring being worn on the disc is at the end of a J Hook. The spent pad debris collects in the J Hook, and then exits the J Hook at its termination and causes the grooves. Other than a cosmetic issue, there shouldn’t be any performance issues. This happens more when the brakes are cold, since they’re working in an abrasive mode…they’re scraping the discs rather than sticking to them. When you heat pads up on the track, they’re scraping AND sticking to the discs (and you get a pad transfer layer). You will find that some pads do this more than others because some pads have more material break loose from the pads, or the material that breaks away from the pad is more abrasive than materials from other pads. To anyone who does not know what is happening, I can definitely see how this would be a concern, and I probably need to get something up on our website about it. Again, this is normal and nothing to be alarmed about though. If you don’t like the grooves or are worried about them, we sell a plain-face version of the exact same disc, and they are $155 per disc. Right hand side= part# 19 01 720 Left hand side= part# 19 01 721 Finally, J Hook slots can cause a little more whirring and scraping noises, similar to drilled discs because there are more leading edges for the pad to catch on.
04-10-2014, 02:25 PM | #22 |
Forgot to say...at $155 each, the plain face discs are $10 cheaper per disc than the J Hooks.
The Following User Says Thank You to JRitt For This Useful Post: | SuperDave (04-19-2014) |
04-10-2014, 04:01 PM | #23 |
04-10-2014, 05:00 PM | #24 | |
Site Moderator
Drives: Stuff
I swear I asked if you had those before!! Damn.. I might buy a set.. I still have spare rotors (burnished too) sitting around.. hmph.
-Dave
The Following User Says Thank You to Dave-ROR For This Useful Post: | CSG Mike (04-14-2014) |
04-10-2014, 05:02 PM | #25 |
Site Moderator
Drives: Stuff
So anyone want to buy some brand new burnished J Hook rotors?
I might need to test me some plain face discs
-Dave
04-10-2014, 05:12 PM | #26 |
Nice. I prefer plain rotors. They probably make less noise as well.
04-10-2014, 06:11 PM | #27 |
Drives: GT-86
Can the sprint kit be bought with the plain rotor instead of the j-hook rotor
04-10-2014, 06:20 PM | #28 |
Similar Threads | ||||
Will STi 08+ Brembos fit stock rotor? | omgwtfbbqsauce | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 04-02-2014 07:24 PM |
Rotor Weight | ender2664 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 05-14-2013 05:14 AM |
Has anyone cracked the OEM rotor yet? | ayau | Tracking / Autocross / HPDE / Drifting | 10 | 04-22-2013 04:41 PM |
Turbo 4 rotor GS300 | jschendel | Other Vehicles & General Automotive Discussions | 1 | 01-16-2013 07:15 PM |
Sprint Rotor Temperatures | Captain Snooze | Tracking / Autocross / HPDE / Drifting | 2 | 12-19-2012 12:59 PM |
