Old 05-13-2012, 10:41 PM   #1
rawbz
Drives: 2013 Subaru BRZ
Best Manual transmission driving techniques?
I know there's one of these threads on every car forum but I spend all my time surfing ft86club so I figured I would create one here.
For myself (and many others) the BRZ/FR-S will be the first manual car we will own. I do have some experience driving stick but I wouldn't say I'm a pro.
A few questions for the more experienced that I could never find definitive answers to:
1) Is it bad to skip gears? i.e. shift from 4th gear straight to 6th gear or more importantly from 5th/6th gear straight down to 3rd gear?
- Some tell me its better to run through the gears or double clutch when down shifting but I don't know why?
2) Does double clutching really preserve any components a significant amount? I was able to figure out you're preserving synchromesh but is it really worth my time and the slower shifts? Does this part need to get replaced fairly frequently and it would extend its life?
I learned to do it and it feels a lot more smooth on my downshifts but started to wonder if its worth the effort.
rawbz is offline   Reply With Quote
Old 05-14-2012, 01:50 AM   #2
Pekingduck
Drives: 4 wheels
1. it is not bad to skip gears as long as you don't over mechanical over rev the motor.
2. I never really double clutch any of the gears, but sometimes I do for 1st when rapidly down shifting from multiple gears, or going to reverse I might double clutch for that.
Pekingduck is offline   Reply With Quote
The Following User Says Thank You to Pekingduck For This Useful Post:
bestwheelbase (05-16-2012)
Old 05-14-2012, 01:50 AM   #3
OrbitalEllipses
Drives: Attitude
Double clutching is antiquated; synchromesh transmissions essentially dispensed with the need to double clutch. Rev matching on the other hand is still a good idea, but you do not need to strictly double clutch.
EDIT: Reverse can be straight-cut and difficult to get into which is likely why the above poster prefers to double clutch reverse.
Old 05-14-2012, 02:23 AM   #4
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
On my s2k it was not advised to skip shift (from 1st to 3rd) etc. Because it would ruin the synchros.
You could go through the 1,2,3 motion but it was advised not to skip directly 1-3 2-4 etc.
86'd is offline   Reply With Quote
Old 05-14-2012, 02:41 AM   #5
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
1. Upshift at full throttle, slipping your foot sideways off the clutch pedal when re-engaging the driveline.
2. Savor the odor of your burning clutch plates.
Sport-Tech is offline   Reply With Quote
Old 05-14-2012, 02:45 AM   #6
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Never heard of that in my life, sounds totally whack and can't see how skip-shifting would hurt synchros. IIRC the tranny in the s2k is a variant of an Aisin model used in several other vehicles.
Old 05-14-2012, 09:50 AM   #7
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
1. No problem with skipping gears. Believe it or not, in the 4th generation f-body, GM put a solenoid in the manual transmission that made you shift from 1st to 4th if you were just puttering around town.
2. Double clutching and rev-matching are not neccesarily needed in today's transmissions. However, doing it right when downshifting will reduce wear and tear on the transmission's internals and clutch while making for smoother shifting and power delivery. It also can be done very quickly when you have the rhythm down, and pairs nicely with heel-toe. Double-clutching a downshift is second nature to me now, and using the synchros to spin up the input shaft just feels wrong now. I recommend learning to heel-toe, double clutch, and rev match.
Old 05-14-2012, 10:21 AM   #8
Draco-REX
Corner Junkie
Draco-REX's Avatar
Well, if you skip gears, the synchros need to slow the input shaft more in order to mesh properly. So that can put more wear on them if you shift quickly.
Old 05-14-2012, 11:44 AM   #9
86'd
86'd's Avatar
I didn't explain it right because I was a bit inebriated last night but there are tons of threads like this one:
http://www.s2ki.com/s2000/topic/9149...aking-it-easy/
Old 05-14-2012, 12:14 PM   #10
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Re: Reverse - Ive found that going into a forward gear before engaging reverse is best. Usually I slip it into third then into reverse. Never a crunch, grind, or pop out doing it that way.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 05-14-2012, 01:07 PM   #11
rawbz
Thanks for the responses guys!
So when I'm in 4th and I clutch in, shift into 5th (still with clutch down), then move into 6th and let the clutch out, did anything actually connect or carry a load when I was in the 5th gear?
If the clutch is down the whole time, I figured there's no difference?
Old 05-14-2012, 01:55 PM   #12
Draco-REX
Corner Junkie
Draco-REX's Avatar
You're still meshing the synchros and accelerating or decelerating the input shaft and clutch disk to match the output shaft.
Old 05-14-2012, 02:29 PM   #13
powertrip
Drives: Mercedes C320, S2000
Realistically with modern transmissions, if it feels wrong while you are doing it dont! You should be able to slide into gear if you are doing it right and there shouldnt be any sudden jerks or rev dropping. You wont hurt anything if it feels like butter going in.
powertrip is offline   Reply With Quote
Old 05-14-2012, 04:19 PM   #14
reni
Nobody beats the B[I|R]Z
reni's Avatar
Drives: shopping cart i stole from walmart
because someone had to...
"The [Subaru BRZ] feels as trim, nimble, and athletic as the great sports coupes of the pre-bloat era."
-- Car and Driver, June 2012
"And I thought to myself, I'm not going to die, because this is annoying"
-- Niki Lauda
reni is offline   Reply With Quote
The Following User Says Thank You to reni For This Useful Post:
SVTSHC (05-23-2012)
Hill Holder on Manual Transmission? devinclfalcons Engine, Exhaust, Transmission 74 04-28-2013 12:18 AM
FT-86, manual or automatic transmission??? luisjr Scion FR-S / Toyota 86 GT86 General Forum 22 07-25-2012 03:00 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) -- General Topics 51 05-04-2012 07:54 PM
Another reason to buy a manual transmission car... xantonin Off-Topic Lounge [WARNING: NO POLITICS] 4 08-10-2011 11:30 AM
Tips, tricks, techniques to improve driving? Buggy51 Off-Topic Lounge [WARNING: NO POLITICS] 15 08-01-2011 04:17 PM
