Drives: Toyota Tacoma (Future FR-S)
Premium gas, or?
Hi folks,
Does the FR-S/BRZ HAVE to run on premium gas, or could it run on regular/mid and still function efficiently? Would it hurt the engine to run mid grade or regular? Would Scion advertise Premium as getting the most performance or would it run the risk of damaging something if anything else is used? Thanks! |
Drives: Supercharged Golf Cart
Says use premium.
In all those cases I do believe it is safe to use the lesser gas, but it results in less power and possibly less efficiency which both offset the savings. So you'd wind up spending the same amount overall, but with less power. |
Resident Nice Guy
Drives: Moped
Premium gas is required. In an emergency you can fill it up with less, and the car will pull timing, but the car will run like crap.
Premium gas is only 20 cents more per gallon than regular. Is it really worth potentially harming your engine in car that you just paid nearly 30G's for to save twenty cents a gallon? Plus this car has very high compression, you are risking knock and pinging by running less than premium, and that is bad, mmkay? |
Car Enthusiast
Drives: tC 05 & 07, Rav4
Many threads on this one
It still never seizes to amaze me how people are ready to pay $25k+ for a car and are willing to be cheap on gas. Not an expert on engines and fuels but I am guessing if it's optimized to run on premium, anything else would give you shitty results and might hurt your engine. They win nothing by advertising it as premium as they don't get $ from you whether you use premium or regular. If anything, they might lose some potential customers by saying you need premium. Point is, if they are saying you need it, you do. It will run on regular but do you want to put your car through that? This was a long way of saying, if you are gonna buy a brand new car for over $25k, don't be a cheap a** when it comes to filling it up.
Drives: 2013 Firestorm FR-S
I may be wrong but I think cars nowadays have technology to detect the use of lesser gas and the engine performs accordingly, so yes you get lesser performance but I do not believe you can damage or hurt you engine if you went with lesser gas for a few weeks or something. I would of course never do that and would always buy what the manufacturers suggests but its not the end of the world if you accidentally fill up on lesser gas once or twice.
Edit: I was wrong, so ignore everything I said. lol Last edited by Smitty_89; 05-13-2012 at 08:27 PM. |
Resident Genius
Drives: Subaru Legacy GT, 1990 Geo Prizm
Drives: 2013 firestorm FRS
You can indeed damage your engine if you run regular. Due to the high compression, it needs the 91 (minimum) octane to operate normally. If you put regular and then go into a heavy load situation, your engine will start to knock. It will pull timing but at the same time is also trying to meet the required torque demand (pedal position) and will start a nasty cycle of retard and advancing. Knock destroys engines if it happens far too often over a period of time or too much at once. You want to be cheap? Start by not paying 25k + on a car like this.
In short, dont buy this car if you want to run regular. Your wasting money. |
Drives: ex500r
if you calculate the cost of premium, it is an aprox an extra $5 dollars, that is a value meal
Just to clear things up, I have no objection to buying premium gas for the FR-S. A buddy asked me if I knew anything about it and if it was designed to utilize the lesser but perform the best with the high test, but I had no idea so I thought you guys might know more about it.
#11 |
Drives: 4 wheels
I think out would be okay at lower rpm, but at higher rpm you might cause detonation. With the frs why would you stay at low rpm?
#12 | |
Drives: 2006 Evo IX SE
Some people do tune their cars to utilize lower octane fuel in a safe manner, but again, it's useless to go through that hassle to save 20 cents per gallon at the cost of a certain amount of performance. But some cars nowadays will adjust as intended by the manufacturer. I know one of the Hyundais adjusts its hp and torque depending on the octane used, but in those cases, the "normal" octane to use is 87 while getting more out of a higher octane when used, not the other way around. |
#13 |
First 86
Drives: Scion FRS Argento Automatic
12.5 compression ratio. Enough said.
Life is short...NO BORING CARS |
#14 |
Drives: AW11 MR2 20v, E30 BMW 318is
| The Following 11 Users Say Thank You to Turbowned For This Useful Post: | adprokid (07-02-2012), civicdrivr (05-14-2012), dookie11 (05-14-2012), ESBjiujitsu (05-14-2012), Fly Guy (05-14-2012), Fortunate Few (05-13-2012), Guff (07-02-2012), jinrawke (05-14-2012), Mo707 (07-01-2012), russv (05-14-2012), YukiHachiRoku (05-13-2012) |
#15 |
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Just a note, higher elevations generally have lower octane levels, around where I live, 91 is the highest, some places only carry 89. This is not an issue as detonation becomes less of a concern the higher the altitude due to less dense air (so I'm told).
At sea level, I'd always use 93. Up here I'm stuck with 91, and unless I can't get it out of town somewhere, 89 will never be used. My Hemi asks for 91, and there is a noticeable difference in performance with 89 or 87 octane, though I do run 87 from time to time with no adverse effects. When I used to travel a lot, my '01 Celica was noticeably more peppy with a lower grade of gas at sea level, it's always good to know those cross country trips will usually end in a better performing car for a week or two.
#17 |
SUP BRYZ
Drives: Scooby BRZ
you want to put 91 on your FRS/BRZ....I know gas prices are tough at the moment...but don't harm the engine with lesser gas...91!! if you don't want a sports car get a hybrid or something that has 40 mpg...just my 2 cents..
![]() Follow Me on Instagram@ProjectBReeZy R-RYDES! "This is Family" Project Breezy Build http://www.ft86club.com/forums/showthread.php?t=31146 |
#18 | |
Drives: Girls crazy with his booty
#19 |
Drives: 2010 VW Golf TDI (DSG)
As of tonight I saw prices near me as
$4.49 for 87 $4.59 for 89 $4.69 for 91... and $4.29 for Diesel #2 (w00t for my tdi at least for now )
#20 |
Drives: Civic Si sedan
13.2 gal tank. Avg fill up, 11-12 gal. 12 x $0.20 = $2.40 or $7.20/month if you fill up three times a month. I suggest you skip a lunch each month if you can't afford that.
#21 |
Vortech Supercharged
Drives: WRB BRZ 6MT
Too much risk with unleaded and you are going to have to use more gas just to get your car to move.
#22 | |
Yes i have a stutter
Drives: 94 Acura Integra
91 in my area is about 3.79$ a gallon and reg is about 3.49 Last edited by StuttterButtter; 05-14-2012 at 09:17 AM. |
| BRZ Premium Photos Only | bimmerboy | Photos, Videos, Wallpapers, Gallery Forum | 47 | 05-15-2012 08:15 PM |
| FR-S vs BRZ premium seats? | karbon | Subaru BRZ General Forum | 26 | 03-29-2012 12:40 PM |
| HKS Premium Event | DIG1992 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 03-15-2012 12:49 PM |
| Premium Fuel | riceracer8888 | Scion FR-S / Toyota 86 GT86 General Forum | 65 | 12-16-2011 09:27 AM |
| GT5 Premium wish list | OldSkoolToys | Other Vehicles & General Automotive Discussions | 13 | 04-26-2011 12:17 AM |
