Old 01-29-2014, 12:03 PM   #1
olorin
olorin's Avatar
Drives: GBS Premium
DIY - Hella Horns
16 gauge wire (Red and Black)
3 1/4in female disconnects (crimp connectors) -- home depot ~$2 for set of 15
1 1/4in male disconnect
1 1/4in ring terminal
4 1/4in bolt 1/2 inch long
4 1/4in nuts (use 7/16 socket or wrench)
2 1/4in lock washer (optional)
Angled Aluminum or 90 degree brackets
Black tube for chasing wires
Soldering Iron
Hella Horns (Supertone and Panther horns work for this)
Remove bumper, grillcraft.com has a great how too:
http://www.grillcraft.com/installs/i...install_id=309
Make the bracket (optional)
You can either make your own angle bracket or buy some. I made mine since I had some angled aluminum laying around. You don't need to paint these since they are hidden:
Cut 2 3/4 - 1 inch sections:
Make a brace to hold the brackets out of a 2x4:
Make one solid cut half way through the 2x4 then shave the inner edge until the angled aluminum is snug.
Drill hole with 1/4in bit don't press too hard, let the bit do the work. Sand off the rough edges:
Make wiring
There are 2 horns marked L and H and each one has a different connector. For the L horn you need to make one long red (~2.5ft) wire with a male disconnect at one end and a female disconnect at the other and a short (~6imn) black wire with a ring terminal at one end and female disconnect at the other.
For the H horn you make 2 medium (~1ft) length wires both with female disconnects at one end and posts at the other.
To make the posts use a soldering iron to coat the tip of the wire with solder:
And trim to size:
You don't want the posts to be too wide or thick as they need to fit in the H horns connector. The solder is really just there to stiffen the wire.
You should have wires that look like this:
Install the wires in the wiring harness. The medium wires posts go in the H harness (order doesn't matter):
And the male connector on the long red wire goes in the L connector (sorry no pic).
Intall tubing and wrap with black electrical tape. Make sure the wires reach to the mounting points as annotated in the below image:
Underneath there are elongated holes that will be used to mount the brackets. Pick whether you want to use the inner or outer holes. I initially used the inner ones but my license plate covered them up, so I remounted then on the outer holes.
Use a ridged pole or a telescoping magnetic thingy to place the bolts head up thread down through the hole. The outer ones are easier to work with:
A locking washer can make tightening easier.
Next add bracket and use nut to tighten-- leave loose enough to adjust the angle. For the drivers side (or wherever you will place the L horn) use additionally add the ring terminal:
Attach the horn (it may be easier to remove the horn from its straight bracket):
Tighten the nuts (use some thread locker). If you use the inner mounts it harder to tighten or remove since you have no access to the top of the bolt.
Attach the female connectors to horns, order doesn't matter as long as you connect the L wires to the L horn and H wires to the H horn.
Check to makes sure the horns are working before you reinstall the bumper!
Reinstall bumper.
Done:
olorin is offline   Reply With Quote
The Following 5 Users Say Thank You to olorin For This Useful Post:
br_z1Lch (05-26-2014), Choco (01-21-2015), chris's fr-s (01-29-2014), MJones_RB (06-14-2016), RobertPaulson (01-23-2015)
Old 01-29-2014, 10:52 PM   #2
chris's fr-s
@theexquisite86
chris's fr-s's Avatar
Drives: 2013 Firestorm FR-S
Thanks for the DIY, I never got around to finishing mine, but here is an optional mounting location for them. They are hidden behind the bumper but the sound is the exact same, I just didn't want to block air flow to my intercooler.
ML24 widebody, FA20 turbocharged, Avant Garde wheels sponsored 2013 Scion FR-S
Instagram:Theexquisite86
chris's fr-s is offline   Reply With Quote
The Following 2 Users Say Thank You to chris's fr-s For This Useful Post:
Choco (01-21-2015), olorin (01-29-2014)
Old 01-29-2014, 11:17 PM   #3
olorin
olorin's Avatar
Drives: GBS Premium
Your IC is beefier than mine. But you may be able to make a bracket such that it's off to the side. The 2 elongated holes on either side of your pic are right above the holes I used to mount the brackets. Is the low horn one pointing towards the driver?
And nice build thread!
Old 01-30-2014, 12:01 AM   #4
chris's fr-s
@theexquisite86
Thanks, yes the low fq horn is pointing inwards, I am actually probably going to remount them I'll be removing the crashbar soon to tuck wires, I might mod up a bracket and move them off to the side(of the intercooler) like yours. With my oil cooler there in the way here anyways .
Your thread looks good to man.
Old 01-30-2014, 01:10 AM   #5
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
My set up
FRSfan111 is offline   Reply With Quote
The Following User Says Thank You to FRSfan111 For This Useful Post:
Choco (01-21-2015)
Old 01-30-2014, 01:17 AM   #6
husker741
Is there an easier way to do this for noobs who don't work with much electrical stuff?
husker741 is offline   Reply With Quote
Old 01-30-2014, 02:31 AM   #7
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
This is as easy as it's going to get man. It's basically plugging in wires.
A relay is suggested though per the hella instructions.
Old 01-30-2014, 10:35 AM   #8
olorin
olorin's Avatar
Drives: GBS Premium
Truly. The way I wired it there was no cutting the stock wires.
Old 01-20-2015, 08:23 AM   #9
Pkush
Thanks for they DIY. Made similar brackets but bigger with 2 screws for a sure fit. They're a bit off center since I messed up when measuring but that doesn't bother me. Pics attached. Olorin you're the man.
Pkush is offline   Reply With Quote
Old 01-20-2015, 09:47 AM   #10
Timmy_Jones
Spun
Drives: 17' Focus RS
Why these horns? Are they louder? Deeper? Higher pitched?
Timmy_Jones is offline   Reply With Quote
Old 01-20-2015, 09:50 AM   #11
Pkush
look them up on youtube. Louder for sure.
I also kept the stock horns (we have 2) so I have 4 horns in total right now. Not train horn loud, but loud enough to make people get out of the way (in the City of Chicago people like to cross the street in very unexpected places and very unexpected times).
Old 01-20-2015, 10:00 AM   #12
adamg
Drives: brz
I am the only one that thinks these are one of the worst/ uglyiest trends in the subi world. next to rally armor mudflaps, bright plasti dip, and racecar stickers
adamg is offline   Reply With Quote
The Following 5 Users Say Thank You to adamg For This Useful Post:
GT86_PRAGUE (01-20-2015), Hyper4mance2k (05-07-2015), Joon525 (09-12-2016), Timmy_Jones (01-23-2015), twag4 (01-23-2015)
Old 01-20-2015, 10:26 AM   #13
Pkush
I beg to differ. Love the looks of Hellas. Love the look of rally armor flaps on stis and wrxs, not so much on brz. And I love well executed plastidip. No comment on stickers tho haha
Old 01-20-2015, 10:28 AM   #14
adamg
Drives: brz
The Following User Says Thank You to adamg For This Useful Post:
Choco (03-01-2015)
DIY - Hella Supertone horns installation on FR-S driver01 DIY (Do-It-Yourself) Guides 93 07-22-2019 05:08 PM
Hella Optilux Extreme Yellow Robert95g Cosmetic Modification (Interior/Exterior/Lighting) 14 01-18-2014 04:09 AM
hella-dumb charged86 Other Vehicles & General Automotive Discussions 49 09-25-2013 02:37 PM
Hella Fail SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 117 01-14-2013 12:59 PM
Hella Supertones. 636 Cosmetic Modification (Interior/Exterior/Lighting) 10 08-09-2012 01:16 AM
