follow ft86club on our blog, twitter or facebook. Interested in the FT-1? Check out FT1Club
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > Northwest
Northwest AK, ID, OR, WA
Old 12-24-2013, 02:44 PM   #1
mwy23
Drives: BRZ, X5
OEM Front License Plate bracket installation
I received an $86 (ironic) no front plate ticket by parking enforcement, which is enough for me to put the plate on. I dislike the offset Perrin/Grimmspeed mounts and taking off the front bumper to glue magnets on is too much hassle.
Curious if anyone knows the proper procedure (more importantly, proper screws) to screw that OEM bracket on. Any advice would be greatly appreciated.
mwy23 is offline   Reply With Quote
Old 12-24-2013, 02:50 PM   #2
ramiram1984
Drives: 2016 STi DGM
^$144 for me. Never put it on tho.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 12-24-2013, 02:52 PM   #3
JRTritsch
Drives: 13' FRS
I had been ticketed in the past, so I just mounted mine with the stock plate mount. I just used two self tapping screws ~1/4" thread ~1/2 long in the lower half of the plate where it screws into the black plastic grill and some double stick tape on the top so it won't scratch (and can be peeled off by the next owner).
JRTritsch is offline   Reply With Quote
Old 12-24-2013, 02:52 PM   #4
Touge_ninja
Evo Killer
Touge_ninja's Avatar
Drives: stage 2 2015 STI
Zip ties works wonders
Oversteer scares passengers. Understeer scares drivers.
Touge_ninja is offline   Reply With Quote
Old 12-24-2013, 03:22 PM   #5
252actual
252actual's Avatar
Drives: 2014 BRZ Limited
^this. just mount the oem plate a little lower than if you drilled the bumper and zip tie it on. if i get a chance later ill grab a pic of how mine is mounted.
252actual is offline   Reply With Quote
Old 12-24-2013, 04:33 PM   #6
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
If you need the stock kit let me know
Jmonty is offline   Reply With Quote
Old 12-24-2013, 04:50 PM   #7
humfrz
DANG Fife PD will do anything to make money .....
I just put mine on the grill (centered), with the OEM bracket.
As I recall, I placed the bracket upside down (by design) .... I think I used the screws/bolts that came with it......then again, maybe I didn't ...... hey, that was a LONG time ago .... 9 months ago ..... I think ..... now WHERE did I put my meds .... I think it's time.....
humfrz
Old 12-24-2013, 04:54 PM   #8
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
All of the hardware and bracket should be in the rear cargo area or under floor.
1. Install the bracket loose.
2. Mark the center of the holes. I use a spring loaded awl.
3. Drill the holes - 1/2" drill bit
4. Install drop in expansion anchors - The longer ones.
5. Push the bracket up against the bumper and screw in the 10mm screws
6. Put the plate on with the supplied screws.
There will be two small screws that have 10.9 JH on the heads and two small drop in anchors that you will not use and throw away.
You should be able to go to your local dealer for assistance or where you purchased.
Beyer Subaru is offline   Reply With Quote
The Following 2 Users Say Thank You to Beyer Subaru For This Useful Post:
mwy23 (12-27-2013), WRB-DZA-BRZ (12-24-2013)
Old 12-24-2013, 06:52 PM   #9
tbertran
tbertran's Avatar
Drives: Subaru BRZ (6027xx) Premium Manual
Yes, please. Been driving around for a year without it, all good so far (even got a speeding ticket, cop didn't notice) but I want to be ready.
By the way, I thought this was a "fix-it" ticket so I always assumed it would be cheaper on the first offense.
FT86SpeedFactory catted UEL Header / GReddy EVO3 Catback / Cosworth Drop-in air filter / Shifteck short throw shifter / Kartboy pulley / Rear bumper diffuser / Perrin shorty antenna / Raceseng Slammer knob / Carsmo armrest / Clear side markers / 10" CustomSubEnclosure|Rockford R500X1D|Rockford P3D4-10 / Perrin Inlet Hose / GrimmSpeed front strut bar / Valentine V1 with BlendMount / All LED Inside
tbertran is offline   Reply With Quote
Old 12-25-2013, 01:16 PM   #10
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Old 12-25-2013, 01:55 PM   #11
tobin
tobin's Avatar
Drives: 2013 BRZ Limited
I picked up my BRZ in July, and got pulled over in November for no front plate (CT). To me it wasn't worth the hassle of getting pulled over again for that, so I put the stock bracket on. I also added a Weathertech clear cover, so the plate doesn't get dented up down the road. To me the BRZ looks fine with the front plate bracket, since we have the black "mustache" anyway. I hate the side-mount brackets. I think in the future, someone will make a repop adhesive cover for the bumper mustache anyway, so you can hide the holes if you want to.
http://www.ft86club.com/forums/showt...t+installation
tobin is offline   Reply With Quote
The Following User Says Thank You to tobin For This Useful Post:
mwy23 (12-27-2013)
Old 12-25-2013, 02:49 PM   #12
Touge_ninja
Evo Killer
When i got stopped i just said my btacket never came in and called my friend who works at toyota and bailed me out. Works everytime.
Old 12-25-2013, 03:39 PM   #13
252actual
252actual's Avatar
This is exactly how i did mine but without the top bolts. On the BRZ it might mount a bit different but the zip ties through the center of the bracket are plenty strong to hold it. mine has been on there for a while and its just fine.
Merry Christmas by the way
Old 12-25-2013, 05:50 PM   #14
Ammunition
Ammunition's Avatar
Drives: 2014 Scion FR-S
I got an $80 citation from a meeter maid for no front plate. I'm actually going into court next week to contest it since it's been over two months since I've sent in my written explanation, and I haven't heard anything back from them despite them withdrawing the money from my bank account for the bail.
I zip-tied mine to the front - like others have said if you fit it right below the solid plastic panel of the upper bumper you can attach it without it resting on, or scraping the paint at the bottom - albeit barely.
Ammunition is offline   Reply With Quote
Search this Thread:
Advanced Search
DIY - BRZ OEM Front license plate mount/bracket no-drill installation shiumai DIY (Do-It-Yourself) Guides 82 01-18-2018 02:00 PM
WTB: BRZ OEM Front license plate mount bracket KayoTrap Canada Classifieds 7 10-01-2013 02:08 AM
Frs Cap and OEM Subaru Front license plate bracket Xdragonxb0i Miscellaneous 1 01-16-2013 01:25 AM
USA front license plate mounting? Slimline bracket mount.. Help across the world :P WTF Scion FR-S / Toyota 86 GT86 General Forum 32 08-23-2012 07:25 AM
2013 BRZ License Plate Bracket Kit Installation Revision‏ taosracer Cosmetic Modification (Interior/Exterior/Lighting) 19 05-26-2012 02:28 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
