follow ft86club on our blog, twitter or facebook. Interested in the FT-1? Check out FT1Club
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Suspension | Chassis | Brakes
Suspension | Chassis | Brakes Relating to suspension, chassis, and brakes.
Old 07-28-2013, 06:00 AM   #1
eckoflyte
Drives: Toyota 86 GTS
Whiteline KDT922 (Subframe Bushing Inserts) Grease - Safe to use on Rubber?
So I installed these today but am wondering about the grease that comes packaged with the bushings.
I noticed that Whiteline included grease which is a Lithium base complex grease with moly additive (really just marine grease or multi purpose grease you can get at the hardware store).
Quoting straight from Whiteline's website - "The supplied grease has been formulated from a reinforced No. 2 lithium complex base and selected additives with molybdenum disulphide for mechanical stability extreme pressure qualities for extended life and a high melting or drop point of 230C minimum."
Since the Whiteline poly bushings make direct contact with the stock rubber bushing, is this grease safe to use on rubber?
Now that they are installed, I am worried it may dry out the stock bushings causing them to crack. I can't find any definitive information that it is safe to use on rubber.
eckoflyte is offline   Reply With Quote
Old 07-28-2013, 08:30 AM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
Jan at white line is pretty good at responding, send him an email.
Old 07-28-2013, 08:34 AM   #3
eckoflyte
Sorry mate, i have no idea who Jan is. Tried googling and checking whiteline website but no luck
Old 07-28-2013, 10:01 AM   #4
FastWhite
Drives: Subaru BRZ Limited M/T
Jan@whitelineus.com
Jan@redrangerusa.com
This is what I have on file for Jan
When I had issues with my STI bushings
FastWhite is offline   Reply With Quote
Old 11-09-2016, 02:23 PM   #5
neilvosko
neilvosko's Avatar
Drives: Hyper Blue BRZ
any update on this ?
neilvosko is offline   Reply With Quote
Old 11-09-2016, 03:13 PM   #6
White Knight Squad
Drives: 14 FRS Hot Lava
Lithium or silicone based greases are fine for rubber and plastic. We use lithium grease to install bushing at a plant I work at. Do not use petroleum based greases on rubber or plastics!
Tcoat is online now   Reply With Quote
neilvosko (11-09-2016), wparsons (11-09-2016)
Old 11-09-2016, 04:11 PM   #7
gramicci101
Off Topic
Water-based lube works much better on rubber. Plus it's easier to wash off later.
Old 11-09-2016, 04:15 PM   #8
White Knight Squad
Unless it is on components where you don't want it to wash off!
Search this Thread:
Advanced Search
whiteline rear subframe inserts charged86 Suspension | Chassis | Brakes 16 05-18-2013 09:20 PM
WhiteLine Positive Shift and Rear Subframe Bushings Review @ Pure Automotive Pure Automotive Mid-Atlantic 5 01-16-2013 06:15 PM
Whiteline transmission bushing and Perrin shifter bushing review. Superhatch Suspension | Chassis | Brakes 1 12-09-2012 09:40 PM
Whiteline rear subframe bushing install... fl_speed001 Suspension | Chassis | Brakes 34 11-06-2012 04:24 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
