Just a dude
Drives: Scion FR-S 2013
AVO front res pipe and over pipe...how come so few using? Updated ill be guinea pig..
Wondering was Avos front pipe and over pipe designed only for TC? Site says for both but don't see any chatter of these offerings so wondering why not I suppose?
I'm not TC or SC but in market to add front pipe and over pipe to my Lachute cat back and res mid pipe. Both bits look real nice
Drives: Passat
I didn't know that AVO made over and front pipes for us. I just checked it out and I think I can see why no one is running them. $$$
I thought Perrin was expensive but $390 for the AVO over-pipe? Ouch! |
Just a dude
Yea there are ceramic coated to though. I phoned in for my own education on the matter and found out reason they were doing there's coated is due to the heat impact on closest surrounding bushings. Apparently in testing they found the bushings to soften up etc. Their front pipe also has the available port for wideband O2 sensors which is a nice future proof thing for FI consideration down the line. Guess ill take the jump and let ya all know once in my mitts.
Drives: vrooom...
If you go through a good vendor you can get a good deal on them
Drives: Passat
#6 | |
Just a dude
Regardless so much of what's out there, is in many ways over priced for our cars anyhow. Ill take some pictures and make some observations on exact fitment when I have it in hands and report back. One things for sure if there's any thought of it being too close I simply won't run it, ill send it back.
Drives: vrooom...
Well That's the thing it's not just a piece of pipe, it takes time and skill welding curved pipe together in order to create a shaped pipe that does not make contact on our vehicles. Not to mention the AVO OP is also ceramic coated.
Drives: vrooom...
Good Luck finding an OP for that price...either you got the greatest deal on the planet, its used or its a piece of junk.
Drives: Passat
I have a hard time paying $100 per whp for typical 86 bolt-ons but ~$600 per whp for the over-pipe is obscene. Unfortunately it's just not an easy piece to make and I don't fault anyone for charging what they are for them. I'm not sure but I suspect PLM is Chinese made and even that costs $200. I just really hate to spend so much for a small section of pipe that makes such a miniscule performance difference. OTOH, I hate to run a 2.5" header collector into the 2" oem over-pipe even if it only costs a couple hp.
I suppose that if the AVO version fits perfectly, it's worth it. Looking forward to your results with it. I already have the Borla UEL and I just ordered the Tsudo HFC front pipe. I'd really like to replace the over-pipe at the same time. |
#10 |
#11 |
Drives: vrooom...
#12 | |
Avo is the only company making ceramic coated overpipes. Personally I'd rather just wrap it. In any case, I've never heard of any issues arising from one not being coated/wrapped. |
#13 |
Just a dude
I won't deny its expensive. But if it fits perfect and all works 100% perfect that's worth something to "me" anyhow.
I surely will be reporting when get my mitts on it.
#14 |
Drives: 2013 Black FR-S
My PLM overpipe rattles like crazy. If I had known that I would not have bought it. I am gonna see what my exhaust guy can do to fix this issue............
| Group Buy: TSUDO Performance Hi-Flow catted Test Pipe/Front Pipe/ Downpipe | JonMotoring | Groupbuys | 65 | 08-27-2013 01:33 PM |
| Agency Power Front/Over pipe (Combo pipe) - Cheap! | seven | Engine, Exhaust, Bolt-Ons | 12 | 03-09-2013 02:40 AM |
| Will a resonated front pipe make alot less noise than test pipe? | Mike86 | Engine, Exhaust, Transmission | 8 | 01-26-2013 08:24 PM |
| Agency Power over-pipe/front pipe combo question... | seven | Engine, Exhaust, Transmission | 11 | 01-13-2013 01:14 PM |
